MiniTab 17 Question-Standard Deviation Default
Coury Ferguson
Moderator here to help
Our company uses Minitab 17 to provide our Automotive Customers with Cpk/Ppk data. I have noticed that Minitab 17 defaults to 6 Standard Deviations. Is there a way to change that default to 3 Standard Deviations or is it going to have to be changed every time when developing Ppk/Cpk data to be submitted to our customer?
I am not an expert in Minitab, so maybe there is a simple way to change the default, that I am not aware of.
jfries2
Using Minitab 18 here, but per the help screen on Capability Analysis:
"By default, the tolerance is 6 standard deviations wide (3 standard deviations on each side of the process mean). "
So, 6 should be what you want. If you do need to change it, go to "Stat"<"Quality Tools"<"Capability Analysis"<"Normal"<Click on "Options", then enter a different K value.
By changing it to 3, Minitab will interpret this as +/- 1.5. Are you certain that is what you intend?
Coury Ferguson
Miner,
Yes.
Our data is within LCL and UCL. When using it at 6 SD our data becomes skewed. Our Ppk/Cpk when using the 6 SD does not meet the 1.66/1.33 that the customer wants, but at 3 SD it does, if not better.
Here is an example: We have a TP UCL .5 mm and LCL .0 when we made the parts the TP (don't ask me why the customer wanted the Ppk/Cpk data for a TP) was reading at .0 mm-.25 mm the data skewed far left. But the process was in control and producing the requirements of the drawing.
Another example would be DIA UCL 12.9 mm LCL 12.6 mm nominal 12.75 mm.
We tried everything to get the data to meet the Ppk/Cpk requirements and using the 3 SD instead of 6 SD bought the process in within the customer's requirements.
It is a shame in my opinion, that we have to manipulate data on good parts.
N Question on 3D-Contour Diagram in Minitab Using Minitab Software 4
Hami812 Normality of Data Question - Minitab Analysis Statistical Analysis Tools, Techniques and SPC 12
T Customizing the order in which the graphs are printed in Minitab question Software Quality Assurance 1
S I am asked to fit 2 lines - Basic Minitab Question - Quick Help needed Using Minitab Software 1
R Question about MINITAB's SQL Syntax Using Minitab Software 2
W How Total Variation is calculated - Minitab Gage Question Using Minitab Software 2
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 9
A One-factor and multiple-response Minitab optimization Using Minitab Software 0
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
