Minitab and Crystal Ball Statistical Analysis Software
supreecha
I'm not sure Minitab have option like as Oracle Crytal Ball & Optquest simulation ?
Pls. advise me .
supreecha
I just heard Minitab and Crystal Ball are two powerful and user-friendly software tools to create and use mathematical models.
- Minitab helps to plan experiments, analyze data and visualize the meaning within the data.
- Crystal Ball simulates system performance, helping the user understand risk and optimize the system very rapidly.
Do your organization have Crystal Ball and Minitab provide a comprehensive statistical automation toolkit for technical professionals in DOE fields. ?
supreecha
Simulation with Design of Experiments
Length
LSL
USL
Target
59.0
67.0
63.0
Factor
Name
Actual Value
Nominal Value
Std Dev
Dist.
1
MoldTemp
155
155
10
Normal
2
CycleTime
100
100
5
Normal
3
HoldPres
130
130
3
Normal
Response:
Length
63.732
Transfer Function:
Length = 0.05755MoldTemp + 0.09025CycleTime + 0.4565HoldPres + -0.0002825MoldTemp*CycleTime + -9.18
Results from Minitab
Estimated Coefficients for Length using data in uncoded units
Term
Coef
Constant
-9.18
MoldTemp
0.05755
CycleTime
0.09025
HoldPres
0.4565
MoldTemp*CycleTime
-2.83E-04
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
G How to create a mixed OAs in Minitab Using Minitab Software 1
V Looking for advice on Pooled Standard Deviation between Minitab and MS Excel Statistical Analysis Tools, Techniques and SPC 1
