[Minitab] DOE Output vs. Actual Data
rdolan2
I am running multiple 3 factor DOEs and each one of my model outputs fits very well, all above an 80% fit. The problem I am having is that when I plug our recorded values into my model for parameters x,y and z my model outputs a significantly different/unfeasible value when compared the the actual recorded measure.
Although, when I check using response optimizer I get a value that does resemble the actual recorded output.
I know this is somewhat vague, but my question is regarding if there are any simple fixes or anything that I might be missing in my DOE that would cause my model to appear to have a great fit but not be able to predict values close to my real values. Thanks,
details and posting your data is the best way to get useful advice. otherwise we are just really guessing.
so my guess would be that your DoE structure is too restricted - your high and low levels aren't far enough apart and/or you don't have enough sample size and replication. Models can have great fits if your data are sparse...
rdolan2
Yeah, I wish I could post the data but its confidential in nature, my assumption was it might be due to the little amount of replications I have.
But just as an example lets say my actual values range from something like .3-.7 and my model is outputing like -100 or something. Clearly, something is wrong here, the model has a fit of .83 but yet spits out these absuredly negative values.
.83 isn't a very good r square value if you don't have many replicates.
no amount of analysis will save a flawed design...if your levels are too close and you don't have enough reps your acuals won't match the model
S Asterisk in DOE minitab software Using Minitab Software 23
J Including Repeats in DoE using Minitab Using Minitab Software 5
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
D Minitab - Design combinations (DOE) Using Minitab Software 4
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Injection Moulding Minitab DOE - All P Values are 0 Using Minitab Software 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
H Minitab DOE Analysis of Data and Transforming Using Minitab Software 4
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
J 3 Level Custom DOE in Minitab Using Minitab Software 3
Q DOE (Design of Experiments) for Accounting - New to Minitab need help Using Minitab Software 5
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
smryan Graphing Sigma Lines - DOE / MiniTab Using Minitab Software 4
K DOE - Variable and Discrete Data - Minitab Using Minitab Software 11
B Validation of DoE (Design of Experiements) Model - Minitab 15 Using Minitab Software 3
P Taguchi method using Minitab - DOE (Design of Experiments) Help Quality Tools, Improvement and Analysis 7
T Minitab - Mixture DOE (Design of Experiments) - Sandability of a Gelcoat Using Minitab Software 5
D Minitab DOE - 4-factor, 2-level, 8 trial, level IV fractional DOE help needed Using Minitab Software 5
S Multilevel Design in Minitab to conduct a DOE - 4 factors and each has 5 levels Design and Development of Products and Processes 4
T Minitab Coding Help Using Minitab Software 0
B Minitab factorial design regression equation center point term Manufacturing and Related Processes 1
G Acceptance sampling by variables - Do Minitab use one sided k only? Why? Statistical Analysis Tools, Techniques and SPC 0
C. Tejeda Computer system validation approach for Minitab Statistical software Software Quality Assurance 11
Z Setting the Control limits on Minitab Using Minitab Software 4
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
A One-factor and multiple-response Minitab optimization Using Minitab Software 2
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
