Minitab GRR crossed Xbar and r method macro needed
Step 1: Setup and run the R&R as you want to see it run.
Step 2: Click the Show History button (looks like a spiral notepad with a > icon.
Step 3: Copy the stored commands. Looks like 1568646427185.png
Step 4: Create a macro and paste these commands into the macro.
I am trying to use this macro from the minitab library but need the output in xbar.
Gage R&R on multiple measurement columns
I tried the
xbar;
under GageRR;
in the macro but got different results than if I chart it manually.
Manually I get this.
with the macro i get this.
I need the Percent tolerance column as well in my output.
Make sure that you included the Tolerance sub-command.
we work in plastics so we need a little bit of leniency. what is the code for tolerance sub command? is there a list of commands somewhere? I haven't done any coding since the 90's so I am a little bit behind on knowledge here. LOL
this is the main code for my macro. where and what do I add to get the %Tolerance to show?
kkset K1 "Gage R&R Study - Xbar and R Method for "
kkset k5 "Tolerance = "
if lsl = 1 and usl = 1
let tol = high - low
text tol ttol
do i=1:n
let tmp=tol
let tmp2=ttol
kkname k3 x.i
kkcat k1 k3 k4
kkcat k5 tmp2 k6
brief 2
###mtitle k4
###endmtitle
###mtitle k6
GageRR;
XBar;
Parts part;
Opers op;
Response x.i;
Studyvar 6;
Toler tmp;
GToler tmp2.
enddo
elseif usl=0 and lsl=0
do i=1:n
kkname k3 x.i
kkcat k1 k3 k4
brief 2
###mtitle k4
GageRR;
XBar;
Parts part;
Opers op;
Response x.i;
Studyvar 6.
enddo
elseif lsl = 1 and usl = 0
text low ttol
do i=1:n
let tmp=low
let tmp2=ttol
kkname k3 x.i
kkcat k1 k3 k4
kkcat k5 tmp2 k6
brief 2
###mtitle k4
###mtitle k6
GageRR;
XBar;
Parts part;
Opers op;
Response x.i;
Studyvar 6;
lsl tmp;
GToler tmp2.
enddo
elseif lsl = 0 and usl = 1
text high ttol
do i=1:n
let tmp=high
let tmp2=ttol
kkname k3 x.i
kkcat k1 k3 k4
kkcat k5 tmp2 k6
brief 2
###mtitle k4
###mtitle k6
GageRR;
XBar;
Parts part;
Opers op;
Response x.i;
Studyvar 6;
usl tmp;
GToler tmp2.
enddo
endif
endmtitle
endmacro
Why do you want the Xbar method? ANOVA is more accurate. Xbar is an approximation that was easier to manually calculate. With Minitab, manual calculation is a non-issue.
Hi Miner, thanks for your great replies for gage r&r analysis macro. I successfully create and modify macro for gage r&r in Minitab with your help.
I would like to ask you where you find all those comands (Gage "name",Xbar;, Gtolerance"tolerance",... and others) for creating macro for gage R&R ?
I ask because I want to create macro for Type 1 gage study using multiple measurement colums in Minitab and I want to use base code of macro Gage R&R on multiple measurement columns.
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Minitab Type 1 Repeatability & GRR% of Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 7
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
