Minitab macro to add reference line to graph
minit
Hello..
Im tryng to write a macro that can take a number from a column
and draw a reference line on the y axis at that number on a graph.
I have no idea what the command is for drawing a reference line because it does not show in the history when I manually try to do it.
thx
D minitab macro to pull access query with parameters Using Minitab Software 1
V Validation of macro - scripts - programs used in statistical software (Minitab-SAS... Qualification and Validation (including 21 CFR Part 11) 5
F Run Minitab Macro from Excel Using Minitab Software 3
M Writing a Minitab macro that can manipulate data in all columns Using Minitab Software 3
M Insert Empty Column Using Minitab Macro Using Minitab Software 2
B Minitab R14 macro for Power Analysis Using Minitab Software 1
T Minitab - Getting a Minitab Macro to look up a Column Name Using Minitab Software 23
M Minitab Macro-Command 'NUMERIC' to convert a text column to an numeric column Using Minitab Software 8
M Minitab 15 - READ, SET from keyboard or file doesn't work in my macro Using Minitab Software 4
J RANCOVA (rank ANCOVA) macro for minitab Using Minitab Software 2
M Problem creating a Macro in Minitab Using Minitab Software 4
M Macro to connect to Access Database to get to data - Minitab Macro help Using Minitab Software 1
M Minitab macro vs. Layout tool Using Minitab Software 9
M Macro that will perform a normality test and capability analysis - Minitab help Using Minitab Software 1
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
