Minitab Multiple Regressions Script Help
rayuk
I would greatly appreciate it if somebody could help me with a scripting problem I am having with minitab.
I have data for over 100 companies with fields such as ticker, profit, share price, debt, cashflow etc. There is also a time field (indicating what year the data row pertains to). The field "ticker" that uniquely identifies each company. Basically what I would like to do is perform an individual regression for each company for the variable "profit".
If done manually this would entail doing over 100 regressions. I was wondering whether someone has a suggestion on how to automate this process with a script? I have a background as a programmer but I can't find much documentation about scripting in minitab.
Barbara B
rayuk,
you can write macros for Minitab. Basic informations are provided in the thread MiniTab Reporting Capabilities (post #11 and #13). The basic steps are the same for R15 and R16, but R16 provides some new useful commands.
To get the results for the companies seperately, I would use the following commands:
  • Split (get a single worksheet for every company)
  • Worksheet (to select a specific worksheet)
  • Regression or GReg (the first being the command for the menu "regression", the other for "general regression)
with the appropriate settings.
The easiest way to get a syntax is to do 1 analysis manually with the menus, click on the yellow pad in the tool bar (-> Show history) and copy the syntax to a text editor (e.g. Notepad, Notepad++).
You can find all commands and the options for them in the Minitab help files:
Help > Help > Reference: Session commands
There are also some useful tutorial on how to use commands and the different kind of macros Minitab provides.
Hope this helps,
Barbara
P How to do Multiple Regression Analysis in Minitab 16 Using Minitab Software 8
C Creating a Multiple Table SQL (Structured Query Language) Query in Minitab Using Minitab Software 10
A Displaying Multiple Graphs in the Same Plot with Minitab Using Minitab Software 4
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
