mopar4u
We make plastic injection molded parts for the medical field. GR&R's are a daily item in my lab. Our work insturctions call out a very standard 2 person 2 trial 10 part gr&r template on an excel spreadsheet. We recently got a customer that wanted 2 person, 3 trial, 10 part gr&r on all their parts we are making. We didn't have a template for this so we used minitab to do the gr&r's. We struggle passing the NDC.
Background
tolerance of +/- .002"
vision system accuracy of .0001"
vision system resolution .00001" (i think)
we used the entire resolution when entering data into minitab. The vision system should be more than accurate for this gr&r. Problem is we get less than 5 NDC's, sometimes 0 which leads to high gr&r's. If we take this data into a 2 person, 3 trial, 10 part gr&r excel spreadsheet we pass the gr&r with a total of less than 10%. Problem is our process does not have enough variation to make more NDC's. Is it acceptable to trick minitab by taking a couple of the parts from the gr&r and for ex. add .001" to everyone's reading for that part to make it look like we are using more of the tolerance range? If we do do that the gr&r comes down to below 10% with minitab. In a lot of cases it would be impossible for our process to make parts on the extremes of the tolerance because you would either have parts that have shorts (missing material) or have excessive flash (excessive material). I'm sure this would be like falsifying data but I'm not sure how to get around this.
Background
