Minitab Rank Deficiency Issue - Binary Logisitic Regression
jaywine
I am running binary logistic regression for two factors which can have two possible answers. (Win or Loss). I have been successful running BLR with other two factor combinations. But am having errors with the settings listed below. Non of the cells are empty.
I suspect collinearity is the source of the error. Any suggestions to troubleshoot? Or am I interpreting the error message incorrectly?
Thanks. I am a new user with minitab.
Blogistic 'Outcome Y' = 'VP Code' 'Region Code';
Frequency 'Total';
Factors 'VP Code' 'Region Code';
Logit;
Eprobability 'EPRO8';
Brief 2.
* ERROR * Rank deficiency caused by the term Region Code due to empty cells or collinearity. No storage of results or further analysis will be
done.
It is always easier for us to help if you can attach your data. You can zip the Minitab file then attach that.
R Rank Deficiency Error Minitab Using Minitab Software 7
J RANCOVA (rank ANCOVA) macro for minitab Using Minitab Software 2
C. Tejeda Computer system validation approach for Minitab Statistical software Software Quality Assurance 7
Z Setting the Control limits on Minitab Using Minitab Software 4
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
A One-factor and multiple-response Minitab optimization Using Minitab Software 2
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
