Minor non-conformance for not receiving a CofC from a heat treater
We have been ISO Certified for over 20 years and AS certified for 6. We have had the same Auditor for 5 years. During our most recent recertification we were issued a Minor non-conformance for not receiving a CofC from a heat treater- for the Rockwell hardness test - indicating the readings. We have never required the heat treater to supply CofCs unless required by our customer. This additionally applies to really any CofCs including material certs. We receive many CofC when required by our customers or suppliers who send them to everyone. The Auditor was surprised he had not caught this before - apparently he only happen to audit parts we had certificates for.
He said this requirement that all material, plating heat treatment and other outside processes are required to meet the requirements of 8.4.2 Type & Extent of Control. He said this is an ISO requirement not just an AS. Does anyone have any insight on this?
Randy
ISO requirement? Like ISO 9001? I can't find a specific reference to CofC in ISO 9001 8.4.2. You are supposed to ensure that externally provided stuff doesn't adversely effect you ability to consistently deliver conforming customer stuff by doing a-d but hey you get to figure that out in conjunction with your customers and not the auditor...So if everyone has been happy with what's been happening CoC's or not then continue to march I guess.
Golfman25
I don't know about AS, but ISO has no specific requirement to receive a CofC from vendors. I suppose it's an easy way to show control of vendors, but many charge $30 for the cert. No thanks, not needed.
Sidney Vianna
Post Responsibly
Heat treatment is a process that needs to be validated (in most cases), a.k.a. special process. Heat treatment is meant to alter metallurgical properties and surface hardness measurements will only give you a limited indication of all such mechanical/metallurgical properties, but won't tell you the whole range of physical characteristics of the parts. So, the question becomes: how do YOU ensure that the outsourced heat treatment processes delivers the expected results and has been performed in accordance with the (supposedly) validated process?
A (RELIABLE) supplier CoC can be understood as evidence of successful heat treatment, but, as I said before, the heat treatment process itself needs to be validated.
somashekar
Type and extent of control is indeed clearly said in the standard.
Now that C of C must be your type of control. Have you defined it in your procedures this type and extent of control on this specific process ?
If you have not defined the C of C as a type of control, can you detail what are the types of control you have been exercising over this specific process.
As far as I know, the C of C is one of the widely used (misused too) type of control.
Certainly you can have many other types of controls exercised on outsourced process, including third party inspection.
Can you give us the entire nonconformity statement, verbatim, including references to the standard?
UncleFester
I'd also be interested to see the exact wording of the minor N/C. It may suggest that your company documentation - not the requirement in 8.4.2 alone - suggests that the level of control you have stipulated includes receipt of C of Cs.
Is your organisation an automotive supplier? There are further requirements regarding type and extent of control, but the minor N/C should have been written regarding those sub-clauses anyway so probably answered my own question.
Also be aware that CQI-9 is a special process audit for heat treatment which may be worth a look into if you're looking at determining what level of control you want to place on heat treatment sub-contractors.
mattador78
As a special process here we are only accredited to iso9001;2015 so for any work we provide to our customers to an AS9100d level we are expected to show our chemical analysis on request our validation of timings and calibration of equipment on request as well as test results on the product/samples and CofCs because we are changing the properties of the material due to our processes. We have always had this information available for non aerospace customers as well on request or if audited. As Sidney said we run on what it says in 8.4.2 iso and AS that we can and will be asked to show how effective our controls are on the product.
JeantheBigone
Irrespective of ISO9001, does the material specification call out a hardness range, minimum, or maximum? If not, why would you need it? If so, why would you accept it without the CofC?
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
P Minor Non-Conformance - Maintenance Records Not Fully Completed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod Minor non-conformance for not controlling local regulation laws? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
L Root Cause for Minor Non-conformance regarding Supplier Delegation Nonconformance and Corrective Action 5
M Definition Major vs. Minor Non Conformance Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 14
T External Communications - Should this have been raised as a Minor Non-Conformance? Miscellaneous Environmental Standards and EMS Related Discussions 12
I TS 16949 Audit Minor non conformance - Outside Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 15
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 6
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
C Show cause letter given as a result of a minor non-conformity raised by CB Quality Manager and Management Related Issues 6
S Can a registrar recommend with minor non-conformities closed before end of audit? General Auditing Discussions 7
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
M Major vs. Minor for Internal Audits? Internal Auditing 10
Q ISO 14001:2015 accredited but import most product - CB Raised minor NC on Life Cycle Perspective ISO 14001:2015 Specific Discussions 2
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
M "Minor" Address Change Implications on Product Labeling Requirements Misc. Quality Assurance and Business Systems Related Topics 2
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Classification of Major & Minor Defects AQL - Acceptable Quality Level 10
Hershal Minor quake in So Cal - 17 March 2014 Coffee Break and Water Cooler Discussions 4
M Is a New Revision Required for Minor Document Changes? Document Control Systems, Procedures, Forms and Templates 15
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S What constitutes Major and Minor changes in Software Software Quality Assurance 7
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
E Short Case Studies - Major/Minor Nonconformance, Observation or OK? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Audit Plan MNC (Minor Nonconformance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Is a Corrective Action required for each major/minor Tool Repair? Quality Manager and Management Related Issues 7
S Minor Nonconformity for Lack of Job Descriptions in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 62
M Minor/ Major Change - Japan - When you have to notify the PMDA of a change? Other Medical Device Regulations World-Wide 1
J Major NC downgraded to Minor by Registrar during Re-Visit Nonconformance and Corrective Action 7
S Minor NC for Not Having Management Review When Scheduled Management Review Meetings and related Processes 12
S MBA Finance major & HR minor job opportunity in TQM field Career and Occupation Discussions 1
S Auditor says a Minor Nonconformance will become a Major Nonconformance General Auditing Discussions 8
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
J Minor NC - No MSA study on Tensile Tester IATF 16949 - Automotive Quality Systems Standard 4
N Minor Concern - Medical Device Software and Risk Management ISO 14971 - Medical Device Risk Management 2
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
J Minor Corrections to Documented Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M ASME B1.13M Standard - Specification of a Plug Gage of Minor Diamateter Various Other Specifications, Standards, and related Requirements 3
2 Minor Document Change Control - Minor text changes to work procedures Document Control Systems, Procedures, Forms and Templates 9
