Shawnann, you stated this as your procedure:
There is some subjectivity in there which might lead, IMHO, to an auditor possibly observing a NC. Is it possible the auditor was viewing a particular job that should have had a process sheet? Was there some items left to interpretation that could produce bad product, that should have been documented on a process sheet? Who makes the call about quality being affected?
I think you might want to better define when a sheet is implemented, and when it is not, maybe.
Process Sheets are only created for production jobs, after the purchase order is approved and when the absence of such process sheet would affect the quality of the product or service, or when requested by the customer. Process Sheets, if required, should be created within one month of the production job taking off and Company is sure as to how the parts are to be processed and packed.
, but aside from the finding, I still might change or modify the one line in the procedure so that it is a little more clear how the organization determines when a sheet is needed or not.
Since I write the procedures, I will definitely take another look at modifying it.
