Minumim number of parts to conduct the Process Capability Study
remsqa
#11
Sample Size
Dear Mr steve
Thank you for your info to understand better.
I do have a another Question with me.?WE are using the same formula for the Machine capability and the process capability.Is there is any other unity in this other than we are trying to capture the stablity of the machine /process or the varianblity of the machine/process.
Expecting your reply
REGARDS
R.LS.ATTHISH KUMAR
sathish_801980 at yahoo dot com
Steve Prevette said:
The 25 sets of 5 (or 4) is a "correct" answer, but not for the reasons given. It is not related to a histogram, but to a control chart. Dr. Shewhart originally gave the suggestion that do not declare a process stable until you have 25 stable points from subsamples of 4 on a control chart. And process capability is meaningless unless the process is indeed stable.
P
psavijay
#12
Machine Capability
Dear Sathish I hope you know what is Process sigma in this replace X bar with your Target value to be achieved, remaining calculations are same, incase of unilateal tolerance with tolerance band on both side same then machine capability and Process capability both are same
Regards
A.Vijayakumar
Steve Prevette
Deming Disciple
#13
R.LS.ATTHISH KUMAR
Generally all that the various "process capability" formulae give you is a measure of how likely the variable being monitored will fall within specifications. Stability of the process or machine is judged by the control chart itself, and variability also. Stability and variability are assessed without even needing to know the specifications. Given that the process/machine is stable, I can then take the variability data and use it in the process capability forumulae.
Caster
An Early Cover
#14
(Ir)Rational Subgrouping
The 25 sets of 5 (or 4) is a "correct" answer....
I once got "heck" from a big 3 supplier quality engineer as follows.
We collected 100 plus parts in series order from our machining line. I used Individual and Moving range charts since to my way of thinking there was no subgroup as such. We had all the parts.
The SQE demanded I used X bar and R with subgroups of 3 "because it is better".
To me there is no justifcation for such a grouping. The subgroup of 3 is arbitrary in this case. If I had collected a sample of 3 parts every hour during a long run, his position would have made complete sense to me. But, I had all the parts due to long cycle times.
Any thoughts?
Of course, we did it his way.
Caster
Steve Prevette
Deming Disciple
#15
Of course, if there is some way to "rationally" do the subgrouping, that is best. But I admit oftentimes it is more arbitrary than not.
Shewhart leaned towards 4 or 5. The issue is you want enough data in the subgroup so that the Range gives a reasonable estimate of the standard deviation for the subgroup. You can go down to a moving range, basically the difference between each successive datum. But the difference between two points has a lot of variability. As subgroup size increases, the range (or even the sigma) for the subgroup becomes more "reasonable". But, countering this, as subgroup size increases, I lose sensitivity. It takes longer to get the subgroup before analyzing the result, and a single point change can be "buried" in the subgroup.
I think that Shewhart leaned towards 5, but acknowledged 4 was easier to deal with in the pre-computer days (square root of 4 is 2).
I would not be terribly offended that the customer specified 3. It would be easy enough to run for other subgroup sizes and see if you get a substantially different interpretation.
G
Geese
#16
Bear in mind I'm new to PPAPs, but reading through the manual I found that the standard PPAP Capability Study can be found here. :read: NOTE 4 pg. 6 (100 minimum readings)
The Truck-OEM specific requirements can be found here. :read: II.4.1 Significant Production Run. pg. 47 (30 minimum readings)
Correct me if I'm wrong.
Ron Rompen
#17
Customer requirements will always supercede the PPAP manual or any other 'reference' documentation.
I have convinced our customers over the years that 30 random samples (6 subgroups of 5 pcs) is sufficient to demonstrate initial process capability (or lack thereof) on our parts. There is little part-to-part variation in OUR process....most of it results from outsourced processes (heat treat, plating, e-coating, encapsulation, etc) which is not as controllable as our process (fineblanking).
However, I did have one customer, many years ago, who insisted on the letter of the law; 125 consecutive samples, serialized and tracked through the processes. It was what he wanted to approve my submission, so that's what he got.
Another point to bear in mind (which was already raised) was the number of SC/CC/KC characteristics, and how feasible it is to actually DO capability analysis. As an example, many of our customers now designate material type as an SC/CC. How do you do statistical analysis on a single lot of material?
Oh well....rant off now. (in case you wondered, I'm stuck at home working on 6 PPAP submissions this weekend, and have another 6 to do over the Xmas break...some people get NO luck)
Arvind
#18
Confidence intervals needed decide the sample size
How many parts you need to use for calculating capability depends on how narrow confidence limits you need for capability.
If you look at Chi square tables and find out confidence interval on capability, here are following C.I.
Sample size---------- Tolerance on Cpk confidence intervals
10 ------------- +/- 45 %
30 ------------- +/- 25 %
100 ------------- +/- 14 %
You can then decide appropriate sample size
G
Geese
#19
Just from short experience, I've noticed that if you are the direct supplier to a customer, you can negotiate (develop customer requirements) for your part, but this can be time consuming and you'll need to get documentation that the customer only required 30 pieces for the capability study as to the proposed 100 by the PPAP manual just to cover your bases. Some people I've met in industry tie their shoes twice just so their shoelace loops are symetric. The guy before him might not have, and this new guy might come knocking with dissatisfaction at the 30 readings.
However, for the sake of doing generic processes in quality control when dealing with several PPAPs and distributors to end customers, it is easiest to just do the standard 100 readings, and go beyond that if your customer specifies more. Judge the time required to measure more parts versus negotiating for a smaller sample to study. I could measure 1 attribute on 100 parts in roughly 15 minutes on some devices and 60 minutes on others, and still longer on others.
Plus, when your auditor comes around, he might notice the extra effort and reward you for your diligence...maybe.... Never hurts to be on someones goodside.
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 1
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
Q How is Medical Device Number (MDL) assigned to companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D How to get EUDAMED Single Registration Number (SRN) EU Medical Device Regulations 17
M Informational US FDA – Modifications to the List of Recognized Standards, Recognition List Number: 052 Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
F 2017/745 Article 31 Single Registration Number Medical Device and FDA Regulations and Standards News 5
Z Do we still have to put UDI if we have DI and lot number seperately on our product ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Ed Panek GTIN (Global Trade Item Number) for non CE Mark Other Medical Device Related Standards 4
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
G Belgium - How do I get an enterprise CBE Number Other Medical Device Regulations World-Wide 0
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
M Informational USFDA – FDA Modernization Act of 1997: Modifications to the List of Recognized Standards, Recognition List Number: 051 Medical Device and FDA Regulations and Standards News 0
S How to number and control translated SOPs - Three languages Document Control Systems, Procedures, Forms and Templates 4
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
lilybef Number of lots required for stability testing of a Class II device in the 510(k) Qualification and Validation (including 21 CFR Part 11) 3
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
M Determining number of employees within the "Scope" of the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
M Medical Device News TGA Consultation: Changes to a number of definitions and the scope of the medical device regulatory framework in Australia Medical Device and FDA Regulations and Standards News 0
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
S Is Lot Number required in addition to UDI serial number? Other Medical Device Regulations World-Wide 7
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
shimonv GTIN Number on the Packaging of a Serviced Medical Device EU Medical Device Regulations 0
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
M How to count the number of employees? Other Medical Device and Orthopedic Related Topics 4
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
H FDA product code and regulation number Other US Medical Device Regulations 3
P FDA's DRLM (Device Registration & Listing Module) Listing Number Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
Sidney Vianna High number of certificate suspensions in the IAQG OASIS database AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J GLP Animal Study - Change number of treatment sites Other US Medical Device Regulations 2
S My department inherited a large number CAPAs ISO 13485:2016 - Medical Device Quality Management Systems 4
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
I Number of HEPA filter in a room US Food and Drug Administration (FDA) 3
Mikey324 GR&R - Little to no part to part variation in single part number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
