Misinterpretation of requirement acceptable as root cause?
Sidney Vianna
Post Responsibly
#11
Let us say you have provided justification for why the PMCF (Post Market Clinical Follow up) is not necessary and that the requirement has already been fulfilled by the existing documentation. Perhaps your phrasing is not clear and you just need to do a better job of explaining that. The auditor writes a non-conformity that the justification is not enough or adequate.
One must ALWAYS remember that an organization is not audited and certified by "Billy Bob Auditor". You are audited by a CERTIFICATION BODY and it is critical that such CB is concerned with CONSISTENCY. So, the feedback to the CB about inconsistency of auditors is very important.
Having said that, it is ALWAYS important to remember that even regulatory requirements change over time, so one should try to clarify if the "surprise" rejection of the justification has anything to do with recent positioning by regulators.
indubioush
#12
You say it isn't necessary, but then you say you fulfilled the requirement. Contradictory statement. Not sure if this was the actual nonconformity.
AMIT BALLAL
#13
IMHO, there can problems in 2 areas:
On auditor's side:
The NCs should be explained at the audited area (Process), in daily feedback meeting and to top management & management coordinator prior to the closing meeting and in the closing meeting. These levels help to make sure the NC is understood, to seek necessary explanation and evidence in case not acceptable by the audited organization and to make sure NC is accepted prior to leaving the premises. Raising NCs directly at the closing meeting results in conflict.
Although most of the norms & good practices (for Eg. IATF) specify conducting daily feedback meeting & closing meeting (at least) to discuss NCs, it is not being completely & properly followed by auditors which result in such situations.
On the organization's side:
Poor explanations can happen due to a lack of understanding of the process owner/auditee or he/her not being able to explain it properly. And in such case, his/her statements can be considered as objective evidence for raising NC.
I'll share my experience: In one of the organization (I was working in & was handling systems), the auditee was not able to explain our current practices to the auditor, even though it was specified in the procedure. I thought it was a problem of he not being able to explain, but after investigation, I got to know that neither he understood the requirement and nor he implemented it properly.
The procedure was also just specifying what needs to be done and not how it needs to be done.
Therefore we just revised the procedure to incorporate additional guidelines to ensure it's easy to understand so that it can be followed.
Check if such a situation exists at your organization. And I would suggest incorporating the practices in procedures/instructions to ensure it is understood by the process owners for implementation and it will also be self-explanatory to the auditor to prevent such problems of poor explanation, if possible.
Weeder
#14
Yes, that is exactly right, the recent positioning of the regulators sometime results in such actions. I think a lot of regulators are now so focused on the MDR that they are using that position to evaluate MDD audits as well. Although it may be beneficial to the company in the long, it is an unfair practice.
Weeder
#18
Well it is possible to satisfy the requirements of the PMCF without actually performing it (through clinical data directly relevant to your device, etc.) and showing that your device is safe and effective. In this case the justification is that you have already satisfied the purpose of the PMCF and therefore the actual PMCF is not necessary.
D Nonconformance or Misinterpretation - When an operator does a Nonconformance Report Nonconformance and Corrective Action 31
Marc Misinterpretation of ISO9K-2K - Not much has really changed (Discussion) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 6
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 1
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Label Placement Requirement in MDD/MDR EU Medical Device Regulations 1
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 5
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Clinical Evaluation - Is this an ISO 13485:2016 requirement? ISO 13485:2016 - Medical Device Quality Management Systems 4
S ISO17020 - Equipment calibration requirement General Measurement Device and Calibration Topics 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv IEC 60601-1 Essential Performance - Is the signal accuracy specification an essential requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
M EU MDR - Annex II 3b - What documents fall under this requirement? EU Medical Device Regulations 3
D Vietnam requirement of CE mark for medical devices CE Marking (Conformité Européene) / CB Scheme 4
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
A Microbial exposure during use - Requirement 11.1(c) EU Medical Device Regulations 1
D Requirement of Pharmacovigilance (Drug Safety) Risk Based Strategic and Tactical Audit Plan General Auditing Discussions 0
S Device name change and label color change EU requirement? Other Medical Device Regulations World-Wide 6
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A EU-MDR Annex I Requirement 10.1(d) EU Medical Device Regulations 3
padraick63 REACH and ROHS Requirement for a Molded Part REACH and RoHS Conversations 1
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
D FDA Date Format Requirement US Food and Drug Administration (FDA) 0
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
