Missing Hardware in Accessory Kits
Milas
Hi
We put together installation and accessory kits in house which are then shipped out to the end customer with a main unit. The kits are made of multiple items and once in a while, we get feedback form the customers, that items are missing from kits when then results in the installation not proceeding (frustrating to both us and the end customer as you can imagine !)
The current process is that we have an A4 sheet which lists all part numbers of the hardware, the quantity as well as a picture of the items for the kits. Once picked, the technician will then sign the sheet which is then inspected and countersigned by a second technician.
This works to some degree but is not fool proof as, due to time and resource constraints, the technician will sign and countersign the sheet ( I know he shouldn't !) and even if he did not, I don't believe its best use of someone elses time to check and countersign what should already be right.
Any suggestions or feedback on how to improve this process would be very much appreciated with the primary aim being not shipping any kits to the end customer with missing parts.
This is a common problem. The best solution is to mistake-proof the entire part selection process using an approach that verifies that each individual part has been selected. See this example. Note: I am not affiliated with the manufacturer in any way.
A less effective approach is to verify that the total weight is correct. This last approach is less effective because you could miss one component and not detect it because you have an extra component that makes up the weight. This would require two different errors on the same cycle, so it would be less frequent than the missing part scenario.
jfbock
First of all, I share your sympathies. We do intermittent/erratic package assembly in a job shop environment. No one likes to settle on this but the number one most important factor I've found is the makeup of the people doing it. We have a guy who is immaculate without any type of complicated system. Is he a speed demon? No, but he will do things correctly each and every time. We have also used the checklists but they are pretty much worthless on their own. Recently, we found a stash of pre-completed checklists someone had squirreled away. This was after some dust up about our customer not getting completed units.
One suggestion, if you have the means, is a shadow board. We have a sheet metal laser we can use but one could stencil the parts needed onto a board. The assembly would first fill this board up and then package. Once again, you can see that it can be bypassed without serious use. It might need some supervision. And once again, we are back to the type of person doing this. I've even had long talks with people who didn't follow protocol and it has little effect unless you have the 'right' mentality. Maybe born not made?
Weighing items will not catch small blunders and here we go, so what does the non-meticulous do then? You're back to the same thing as checklists.
The link to the laser system looks good but that looks suitable for only permanent operations.
yodon
This works to some degree but is not fool proof as, due to time and resource constraints...
(emphasis added)
Might there be a deeper problem? If sufficient time and/or resources were available, might that help? (Not knowing your business, I don't know if that's feasible but your statement did catch my eye.)
Have you asked the folks packing if they have any possible solutions?
Milas
Thanks for the feedback and suggestion to date all of which are valid. Just wondering how effective some Kanban foam would be ////with apertures cut out to reflect the geometry of the part. The bottom layer of the foam in a bright colour so it would stand out if the aperture wasn't filled with a part ?
normzone
[Miner] is correct, this is a common problem. I've worked that post before - shipping are the only people who get less advance notice to do their jobs than the final inspection people. Usually stuff is getting boxed as the truck is pulling in.
Yes, get the packing personnel input. I'm going to assume that the kit varies between shipments and you cannot pre-package this stuff - it needs to be customized to the order. If you could pre-package that would simplify things.
How expensive are the kit items? Can you prepackage a set of everything and provide instructions to the customer regarding which to use, and which to discard? This just shifts the burden to somebody else, I know ...
This doesn't sound like your case, but I've seen where the common items reported missing were consumables the customer would like to have more of. Such negative thinking, I know.
If the large items that ship require specific hardware packages, why not attach the hardware package to the large item in stock? Then it's just pull and ship the large items.
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
D IATF NC Interaction of process diagram - Missing contingency plan Process Maps, Process Mapping and Turtle Diagrams 9
W Error proofing for tightening missing bolts Manufacturing and Related Processes 20
J Contingency Plan missing Utility Interruptions - Root cause support needed IATF 16949 - Automotive Quality Systems Standard 8
Crimpshrine13 Customer Scorecards - Missing Scorecard from one Customer IATF 16949 - Automotive Quality Systems Standard 27
K Addressing Missing Documentation Document Control Systems, Procedures, Forms and Templates 7
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
M Missing measuring equipment General Measurement Device and Calibration Topics 6
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
C Missing routers/documented information Nonconformance and Corrective Action 5
qualprod To raise a NC beyond the audit scope? Two signatures were missing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M What to do about Non Conformance forms that are deleted or missing? Nonconformance and Corrective Action 4
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
N Original signed IQ/OQ/PQ missing - but have data - Do we do it over? ISO 13485:2016 - Medical Device Quality Management Systems 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
Q Practical guide to scan for Risks in all QMS systems without missing any ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O CQE Handbook - Missing Section VII - Risk Management Misc. Quality Assurance and Business Systems Related Topics 1
W AS9100 (8.5.1 j) - Missing Parts when received back from External Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
N "Sterile" missing on the CE Certificate - ISO 13485 Certified Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 5
O New Job 1 Month from Recertification Audit - Missing Documents, no Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
H Incomplete forms and records missing date or a name Records and Data - Quality, Legal and Other Evidence 6
Marc Searching Linkedin Posts - What am I missing? After Work and Weekend Discussion Topics 14
K Revision History of Quality Manual Missing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
E Research or other consents missing from the Donor Medical Chart Document Control Systems, Procedures, Forms and Templates 5
D Missing Document in a TS 16949 Audit - Nonconformance IATF 16949 - Automotive Quality Systems Standard 5
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
W The 2nd printing of the AWS D17.1 2010 which was 2011 - Page missing? Various Other Specifications, Standards, and related Requirements 3
J Eliminating Missing Steps In Manual Operations Human Factors and Ergonomics in Engineering 8
R How to report missing Procedures and Documents Document Control Systems, Procedures, Forms and Templates 9
C Missing Dimensions on the 2D drawings - FAI and 3D Models Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P ISO 9001:2008 - I'm missing page 3 in my copy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Signature Missing from Calibration Certificates General Measurement Device and Calibration Topics 6
E What is missing in the attached Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
S Load Label Missing from Ladders Occupational Health & Safety Management Standards 7
Q Non Conformity in Audit: Missing Deputy Rule ISO 13485:2016 - Medical Device Quality Management Systems 10
M For ISO 9001: Missing Measurement Gage Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Information found missing in a Medical Device Record Other US Medical Device Regulations 4
A Missing expiry date on Class II Medical Device - Recall/Not? What are EU Requirements EU Medical Device Regulations 2
B IEC 60601 Annex D Symbols needed - I am missing Annex D from my standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M What to do about missing Quality Records? Records and Data - Quality, Legal and Other Evidence 11
L Eliminating a Recurring Problem of Missing Weld Nuts/Fasteners Manufacturing and Related Processes 27
Q Focused CAPA on Missing Finished Nonconforming Product ISO 13485:2016 - Medical Device Quality Management Systems 4
L How do you handle missing information? People seem to "forget" to enter information Document Control Systems, Procedures, Forms and Templates 148
Marc Items Missing from the US National Archives World News 0
J U.S. National Archives offers reward for missing hard drive After Work and Weekend Discussion Topics 1
D 21 CFR 820 - Missing Numbers - I have a reference to 820.84 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FDA Audit - Medical Device missing Repair Record General Auditing Discussions 21
