Missing value of Uncertainty B
fahimk
Dear Fellows,
In my lab, while estimating one of the Type B uncertainties, i have to consult the uncertainty value provided in the calibration certificate. However, in some cases the relevant uncertainty values are not given in the certificate.
Example:
For instance, for AC Current @ 50 Hz the certificate provides me uncertainty for the following values:
1 mA
10 mA
100 mA
5 A
10 A
What should i do if i intend to insert Type B uncertainty for the following values?
5 mA
55 mA
200 mA
500 mA
7 A
Thanks and looking forward....
dgriffith
Your manual should explain the MU for your DMM (or similar). Usually that's a % of Range +a % of reading, added. The range for 5 mA is 10 mA, and the % of reading is % of 5 mA. The two are added.
Sorry, posted this quick. It may not be exact, but it should be similar.
Added: What instrument do you have?; what were the values tested at 1,10,100 mA and 5,10 A?
The vendor should have made sure the instrument was in tolerance for each range and condition. The uncertainty stated on the cert is their uncertainty for the measurement, not necessarily the instruments..
fahimk
Thanks mate for the detailed response.
Well, from your reply, i think you are talking about the uncertainty as stated in the Calibrator's manual. In my case that's UB1 uncertainty. For UB2, i am supposed to consult the Uncertainty values as stated in the certificate, issued to my lab from the upper body in the trace-ability chain. Unfortunately they haven't listed the results against a range of input values but rather for fixed values. I hope you understand what i mean.
dwperron
Typically you would use the calibration uncertainty from the report for the closest value larger than the value you are calculating uncertainty for.
So for your 55 mA value you would use the 100 mA calibration uncertainty value.
BradM
Typically you would use the calibration uncertainty from the report for the closets value larger than the value you are calculating uncertainty for.
Agreed. That was my suggestion. I would also consult the calibration provider and make a suggestion that they make it more clear on their calibration certificates what the measurement uncertainty estimation is for all the applied measurements.
dgriffith
I have another point of view on this. In my post above I responded before reading fahimk's other post on a similar topic. I believe he is referencing a Fluke calibrator.
The calibrator has a (usually time-related) specification that already includes the uncertainty of measurement using the laboratory's primary or corporate standards. The certification uncertainty is Fluke's uncertainty in the measurement (which is also the uncertainty in the error); they are telling the customer the range of values within which their reported measurement lies with stated probability. It isn't the uncertainty in the calibrator's output, it's the combined uncertainty in their instrument(s).
Ex: My Fluke 8508 Ref DMM, 10Vdc on 20V range, the uncertainty spec is given as 4ppm rdg+0.25ppm rng @99%CL, reducing to [email protected]%. But, the Fluke cal cert says at 10V the MU was [email protected]%. Would I dare say every time I measure ten volts for the next year the uncertainty was six micro-Volt?
There are of course exceptions-- gage blocks, DC Volt standards, etc. where a single value is assigned or predicted with stated uncertainty.
Sorry for rambling, and my boss says I must now do real work for a while if I want to get paid....
dwperron
Fluke says this in their Extended Specifications document:
"The Absolute specifications include the uncertainty of the standards used to perform calibration of the 8508A at manufacture and may be used to determine the uncertainty of measurements made with the 8508A for periods up to 1 year and over a temperature range of ±5 °C from calibration. If the user has their 8508A calibrated with different uncertainties, the Relative specifications can be combined with the uncertainties applicable to that calibration to determine the effective absolute uncertainty following that calibration. "
So that means that the Fluke Calibration Uncertainty is included in the Absolute specifications, so you don't need to add the 6 µV to it.
If you have it calibrated somewhere else you need to use the Relative specifications and add the Calibration uncertainty that your lab provides.
This is kinda like what HP/Agilent/Keysight did with their 3458A specifications. They had a column on the outside of the specifications page that showed the Calibration uncertainties that needed to be added to their specifications if you had it calibrated by Keysight, otherwise you added your own numbers.
fahimk
Thanks for the response. I got it now.
So, what should i do when i am supposed to write uncertainty for the reading 200 mA when the maximum range, in the calibration certificate, is 100 mA?
dwperron
1 mA
10 mA
100 mA
5 A
10 A
So the next range would be the 5A range. I'm really surprised that there were no results provided between 100 mA and 5A (I would check on that), so you can only use what was provided to you.
fahimk
Thanks a lot for your elaborate responses.
Taking the discussion further, what am i supposed to do if the Calibration Certificate, from the NMI, provides me Uc for values at a single frequency, i.e. 50 Hz while a client desires Uc for values at 5k Hz and 40 Hz for instance?
FYI
In order to calculate the combined uncertainty for electrical measurements, i have used following B type uncertainties:
UB1: Calibrator's Inaccuracy
UB2: Calibration Certificate (based on the Calibration Certificate from the upper body in traceability chain)
UB3: Hysterisis
UB4: UUT Measurement Limitation (Resolution)
This time i am having issues with finding the value of UB2 at Current and Voltage frequencies other than thoses stated in UB2.
Hope you understand what i mean...
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
D IATF NC Interaction of process diagram - Missing contingency plan Process Maps, Process Mapping and Turtle Diagrams 9
W Error proofing for tightening missing bolts Manufacturing and Related Processes 20
J Contingency Plan missing Utility Interruptions - Root cause support needed IATF 16949 - Automotive Quality Systems Standard 8
Crimpshrine13 Customer Scorecards - Missing Scorecard from one Customer IATF 16949 - Automotive Quality Systems Standard 27
K Addressing Missing Documentation Document Control Systems, Procedures, Forms and Templates 7
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
M Missing measuring equipment General Measurement Device and Calibration Topics 6
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
C Missing routers/documented information Nonconformance and Corrective Action 5
qualprod To raise a NC beyond the audit scope? Two signatures were missing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M What to do about Non Conformance forms that are deleted or missing? Nonconformance and Corrective Action 4
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
N Original signed IQ/OQ/PQ missing - but have data - Do we do it over? ISO 13485:2016 - Medical Device Quality Management Systems 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
Q Practical guide to scan for Risks in all QMS systems without missing any ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O CQE Handbook - Missing Section VII - Risk Management Misc. Quality Assurance and Business Systems Related Topics 1
W AS9100 (8.5.1 j) - Missing Parts when received back from External Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Missing Hardware in Accessory Kits Manufacturing and Related Processes 5
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
N "Sterile" missing on the CE Certificate - ISO 13485 Certified Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 5
O New Job 1 Month from Recertification Audit - Missing Documents, no Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
H Incomplete forms and records missing date or a name Records and Data - Quality, Legal and Other Evidence 6
Marc Searching Linkedin Posts - What am I missing? After Work and Weekend Discussion Topics 14
K Revision History of Quality Manual Missing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
E Research or other consents missing from the Donor Medical Chart Document Control Systems, Procedures, Forms and Templates 5
D Missing Document in a TS 16949 Audit - Nonconformance IATF 16949 - Automotive Quality Systems Standard 5
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
W The 2nd printing of the AWS D17.1 2010 which was 2011 - Page missing? Various Other Specifications, Standards, and related Requirements 3
J Eliminating Missing Steps In Manual Operations Human Factors and Ergonomics in Engineering 8
R How to report missing Procedures and Documents Document Control Systems, Procedures, Forms and Templates 9
C Missing Dimensions on the 2D drawings - FAI and 3D Models Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P ISO 9001:2008 - I'm missing page 3 in my copy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Signature Missing from Calibration Certificates General Measurement Device and Calibration Topics 6
E What is missing in the attached Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
S Load Label Missing from Ladders Occupational Health & Safety Management Standards 7
Q Non Conformity in Audit: Missing Deputy Rule ISO 13485:2016 - Medical Device Quality Management Systems 10
M For ISO 9001: Missing Measurement Gage Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Information found missing in a Medical Device Record Other US Medical Device Regulations 4
A Missing expiry date on Class II Medical Device - Recall/Not? What are EU Requirements EU Medical Device Regulations 2
B IEC 60601 Annex D Symbols needed - I am missing Annex D from my standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M What to do about missing Quality Records? Records and Data - Quality, Legal and Other Evidence 11
L Eliminating a Recurring Problem of Missing Weld Nuts/Fasteners Manufacturing and Related Processes 27
Q Focused CAPA on Missing Finished Nonconforming Product ISO 13485:2016 - Medical Device Quality Management Systems 4
L How do you handle missing information? People seem to "forget" to enter information Document Control Systems, Procedures, Forms and Templates 148
Marc Items Missing from the US National Archives World News 0
J U.S. National Archives offers reward for missing hard drive After Work and Weekend Discussion Topics 1
D 21 CFR 820 - Missing Numbers - I have a reference to 820.84 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FDA Audit - Medical Device missing Repair Record General Auditing Discussions 21
