Moisture Detection and Measurement in Vacuum Oven (Plastic Dryness)
jjames
Hi
I have a vacuum oven to dry a project plastic tube 0.075in ID and 100in in length. Due to the material of the plastic I intend to dry it at around 80 to 120 degF in somewhere near 30 inHg.
1. My question is how to define dryness of the plastic tube? How long will I have to keep to dry out the entire water content in the tube? What kind of moisture sensor can I use inside the vacuum oven for this purpose?
2. Is it possible to take reading of vacuum gauge to find the deflection in vacuum pressure when there is steam and set a dryness standard instead of using moisture sensor?
3. What is a good position inside the oven for the plastic tube opening to be so that I can get faster rate of evaporation?
I understand the term "dryness" can not be justified properly. I will be doing KF titration after this process to further determine any trace of water.
Ultimate aim of the project is to prove the plastic tube is dry without the need of visual inspection.
Any help is highly appreciated.
Thank You.
*I APOLOGIZE IF THIS IS THE WRONG PLACE TO POST THIS THREAD. I'M NEW HERE AND JUST FINDING MY WAY AROUND*
NikkiQSM
I work for medical plastics compounder so I may be able to help.
The "dryness" you are looking for depends on the grade of plastic that was used to produce the tubing. For example, if they are made from Pebax - the manufacturer recommends 0.100% moisture of lower. If the material is Pellethane or other type of TPU, the manufacturer recomments 0.020% moisture. I would base the "dryness" on what the manufactuer states.
We use 6 vacuum ovens in our R&D department to dry samples for testing. I would not imagine that are 120F you would produce must steam, especcially when drying tubing. Secondly, we have dried material at much higher temps and have seem a fluctuation in the pressure of the vacuum oven. Although, maybe you are using a different kind / type that we are not familiar with.
I would suggest you purchase a moisture analyzer. I am not familiar with any moisture testing that can be conducted inside the vacuum chamber. We have both loss in weight moisture analyzers and a sensor based. The sensor based (Arizona Instruments VaporPro) is much more accurate and is recommended to test moisture sensitive materials like TPU. Whereas the loss in weigh versions(Ominmark Mar 3), less expensive, but great for testing Pebax and other General House resins like ABS, PC, or PP, HDPE.
Besides the use of a moisture analyzer, I can not see how you could determine the dryness accurately.
Just my :2cents:.
Hope this helps in some way.
jjames
Hi NikkiQSM,
Thanks a lot for your help. It sure does answer some of my questions. I will be using Pebax tube inside my oven.
The water pro moisture analyzer you are talking about wouldnt be able to accommodate the whole tube to test the level of moisture presence, I assume. Or if I'm wrong, could you explain how it works? I don't want to destruct my tube while doing a moisture testing. I did think of loss in weight moisture analyzer but I couldn't find any manufacturers that made highly sensitive and high capacity scales.
Also I did come across electrolytic P2O5 moisture sensor which detects moisture and show a deflection in current reading, but could not come across any info on how safe is it to mount in a vacuum oven.
I have a Thermo Scientific vacuum oven with me. Its an older model, and they don't sell that product anymore.
So yea hoping you would have some more answers for me.
Thanks again for trying to help me out.
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
JoCam Moisture Control - Receiving Moisture Sensitive Electronic Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
N Moisture Analyzer Out of Calibration - Easy Way to Confirm Everything Ok? General Measurement Device and Calibration Topics 3
N The Best Moisture Analyzer for Plastics General Measurement Device and Calibration Topics 6
A Moisture Sensitive Device Time in Nitrogen Cabinets Manufacturing and Related Processes 1
Ron Rompen Measurement of Moisture Content of Nylon Pellets (PA12) Calibration and Metrology Software and Hardware 2
A SPC for Metal Foundry Parameters like Metal Temperature, Sand Moisture Statistical Analysis Tools, Techniques and SPC 5
F Moisture Analyzer Calibration Reference Standard General Measurement Device and Calibration Topics 7
S Nylon Moisture Content - Transportation and Seasonal Effects Manufacturing and Related Processes 3
Q SMT Related Issues - Baking Moisture Sensitive Components Manufacturing and Related Processes 13
J Moisture sensitive device - New reel of a BGA with expired shelf life Other ISO and International Standards and European Regulations 5
J Shelf life control - Examples: solder paste, moisture sensitive device, epoxy Nonconformance and Corrective Action 3
A J-STD-033 - Moisture Sensitive Device Various Other Specifications, Standards, and related Requirements 3
T RPN Thresholds and How Detection Fits In ISO 14971 - Medical Device Risk Management 5
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
B Detection of Orange peel Manufacturing and Related Processes 3
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
K Creating together Standard Definition for Prevention and Detection FMEA FMEA and Control Plans 1
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Environmental Gas Leak Detection Equipment Recomendations Miscellaneous Environmental Standards and EMS Related Discussions 2
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
Z PFMEA Detection Controls and Ranking - Prevent Shipment FMEA and Control Plans 3
S PCR suitable for detection of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
T Root Cause - The difference between Occurence and Detection Problem Solving, Root Cause Fault and Failure Analysis 3
G Determining the "Detection" Number Component of the FMEA RPN FMEA and Control Plans 5
X Computer-Aided Detection for Mammography - Class A, B or C? IEC 62304 - Medical Device Software Life Cycle Processes 5
K Are 'Work Instructions' a Detection Control or Prevention Control? FMEA and Control Plans 8
P Removing Detection from DFMEA - Medical Device company using ISO 13485 FMEA and Control Plans 3
G ISO Registrars/CBs citing for use of "Detection" in Risk Management ISO 14971 - Medical Device Risk Management 27
R FMEA Detection Ranking for Testing Machines FMEA and Control Plans 8
