Monitoring and Measurement of Processes - ISO 9001
angievictoria
Greeting to all,
I am a new comer in this forum. Currently I am working in a technical service provider company and our clients are from the oil and gas industry. Our services is to provide competent inspector and equipment to project site to deliver our services. In regards to the company biz, how should i address this monitoring and measurement of processes. Please provide guidance or is there a sample copy of the procedure which i can reference. Thanks
harry
Re: ISO - monitoring and measurement of processes
............Please provide guidance or is there a sample copy of the procedure which i can reference. .................
I am afraid not. This requirement is wide ranging. It is one of those where you or your organization decides on what you want to do to comply and then show or demonstrate that you had done so.
Read this recent thread for a better understanding: Process Measurement - ISO 9001:2008 Clause 8.2.3 - Whats your Interpretation
Welcome to the Cove
Greeting to all,
Hello and welcome:
The simple question you can probably answer for yourself is - how do we measure what we do now? Or, if, by some chance, your management aren't measuring your processes, what would give an indication that you were working effectively for the client and your bottom line (and any regs, of course!).
That would be what you'd define - no 'procedure' required...
John Broomfield
Greeting to all,
Angie,
Please do not copy someone else's procedure. Analyze your process instead.:mg:
Start with how the inspector is briefed on the requirements for the service and the procedures for delivery of that service. Make notes to capture this.
Then capture what the inspector does to monitor (and measure if necessary) the effectiveness of the service delivery process. And capture what the inspector does to correct the service delivery process. How often can the service delivery process be corrected before work has to stop for corrective action (root causes removal).
How often does the supervisor or manager follow-up to see how the work is going? Capture that too.
Then decide if you need to describe what you have captured as part of the procedure used to control the service delivery process.
Please do not assume that process monitoring/measurement is not already happening. If you provide a successful service then it is being done; you just have to look for it.
John
P
prabhatchaddha
Angie,
John
very rightly said:agree:
angievictoria
Angie,
John
Thanks for the guidance.
John Broomfield
Angie,
John,
Angie,
You are welcome.
John
Helmut Jilling
Auditor / Consultant
Greeting to all,
Clause 4.1 addresses some of this. I would encourage you to read it in the ISO 9004 standard as well. More info in cl 4.1 and cl 7.
You need to define each process in your system. You need to decide how to evaluate effectiveness for each process, based on the inputs and outputs.
I have found a useful additional defining step is for the team to define the purpose for each process, even if it seems obvious. For example, the Purchasing process buys stuff. That is obvious. But, as the team discusses it, you find the purpose is actually to identify and develop good, responsive suppliers, who can be depended on to provide consistent service and delivery, good product, and prices that are fair and reasonable. Now, the Purchasing process is defined clearly enough that the criteria for effectiveness become more clear, which can lead to a better defining of what features should be measured.
Stijloor
Greeting to all,
Hello Angie,
Look at this post + attachments. The Process Matrix shows clearly what's being "measured." I use this in my training/consulting work to provide a Client an example of how "Monitoring and Measurement" can be accomplished.
Stijloor.
Q
qualitytrec
Greeting to all,
I would suggest that you need to identify your Key Operational Indicators. These are the measure of how successful you are in meeting customer and company expectations. You need to look at the inputs, process and outputs to find these.
The inputs could include:
Contractual agreements
Company policy
industry standards
government regulations etc...
The Process could include things like:
Yield
WIP
waste
Cycle time etc...
The output could be:
RTY
over or under production
expidited services
ontime delivery etc...
these would define your measurement system. For procedures you could look to Mil-Stds, ISO documentation and professional organization of related fields for guidance. As cautioned earlier make it your own do not copy others it will cause undo pain to your organization.
I hope this helps.
Mark
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 5
H ISO 13485 - Monitoring and Measurement of Processes (Sections 8.2.5 / 8.2.6) ISO 13485:2016 - Medical Device Quality Management Systems 4
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO 9001:2008 Clause 8.2.3 Monitoring and Measurement of Processes Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M 8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement IATF 16949 - Automotive Quality Systems Standard 10
G Monitoring and Measurement of Manufacturing Processes - TS 16949 Clause 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 2
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
K 8.2.3.1 Monitoring and measurement of manufacturing processes - Tool change IATF 16949 - Automotive Quality Systems Standard 5
X What will auditor ask? 8.2.3.1. Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 9
Sidney Vianna Monitoring and measurement of processes - How do you comply? ISO 9001 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Q TS 16969 8.2.3 Does Monitoring & Measurement of Processes include Support Functions? IATF 16949 - Automotive Quality Systems Standard 5
W Objectives of manufacturing - 8.2.3.1 Monitoring and measurement of processes IATF 16949 - Automotive Quality Systems Standard 7
D Measurement and Monitoring of Processes (Section 8.2.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Monitoring and Measurement of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
I 8.2.3 Monitoring and Measurement of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J 8.2.3, Monitoring And Measurement of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 8
D AS9100C Clause 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J 8.3.2.1 Monitoring/Measurement Audit Finding IATF 16949 - Automotive Quality Systems Standard 6
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
H ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
E ISO 9001:2008 Clause 8.2.4 - Monitoring and Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
L Monitoring & Measurement of Product for Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Interpretation of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Monitoring and Measurement of Product in a Shop Selling Frozen Meat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G 4.5.1 Performance Measurement & Monitoring - relevant information and analysis? Occupational Health & Safety Management Standards 3
Q Which 'customer' in 8.2.4 Monitoring and Measurement of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D How to differentiate between monitoring and measurement devices? General Measurement Device and Calibration Topics 23
