Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity"
Jafri
Our company uses go/no plug gages at several locations. As per control plan, the operators are required to measure product at least 3 times a shift using these gages.
Our Quality System Coordinator thinks that it is necessary to keep record of operators using go/no gages at required intervals. And that is why every operation has a form to fill in the "ok/ not ok" field for the use of plug gage.
I talked to her today and told her that it doesn't look right to me that the operators fill out forms only for plug gages. An ok/not-ok field in a form does not give us any information about process, and only gives an opportunity for auditor to find nonconformance when these forms are not filled in 100%.
She told me that it is a requirement of ISO 9001, and she cited 8.2.4 for it:
"Evidence of conformity with the acceptance criteria shall be maintained."
So she said if we don't record use of plug gage in forms then what evidence would we have for conformity with our control plan?
I had no answer to this. But it still sounds weird to me. I see no use of keeping so much data. I always thought that ISO system is very logical and uses common-sense. So I don't what to make of this interpretation.
I also remember the last company I was working it, where control plan did call for inspections using plug gages, yet they were not recording the use of plug gage anywhere. It was a given.
Please help me understand it, friends. We are accumulating loads of paperwork due to this, and to me it is for no reason.
Stijloor
Re: 8.2.4 "Evidence of conformity"
Welcome to The Cove Forums! :bigwave: :bigwave:
The standards requires what you quoted in your post. It does not require that you record all the inspections. But you must show that the product meets the acceptance criteria. It can be a simple initial on a the router. What do you currently do?
Stijloor.
Jafri
Stijloor:
Where does standard says that we don't need to record ALL inspections?
If I could convince her that we really don't need to keep record of EVERY inspection then I think the problem will be solved.
We don't use travelers/ routers.
We have a 100% final inspection station (awful), and the inspector there typically uses all plug gages which are used in in-process inspection. So that's how we can confirm that part is good before sending it to customer.
Stijloor
Stijloor:
The standard only spells out the requirement. It does not provide you with implementation guidelines. Your organization needs to determine in what manner the evidence will be provided.
I only used the router as a possible example.
It looks to me a battle of the minds. You need to come to an internal agreement about what would work best for your organization and at the same time meet the Standard requirement.
A search in the "Post Attachments List" on the word "inspection" revealed this.
More on "Evidence of Conformity."
Search, click, and take your pick. ;)
Stijloor.
Marc
<snip> It does not require that you record all the inspections. But you must show that the product meets the acceptance criteria. It can be a simple initial on a the router. What do you currently do?
Stijloor.
This is stretching it. If an inspection is made, my expectation would be evidence of it. If a variable, I would expect the measurement as well. ISO 9001 may not specifically call it out, but I would call it on 8.2.4 as well. The results of the inspection must be recorded somewhere on some document/record.
If there is no *evidence* that something as important as an inspection was done (and if it isn't 'important', why is there an inspection?), then I would have to assume it wasn't done. And that doesn't begin to address the issue of what is the company doing with inspection data? If inspections are being done the results should be available for analysis. If they are not, the value of an inspection is virtually useless.
Improvement is based upon analysis of data. EOS
Jafri
Hello Marc. Like I said earlier, the previous automotive company I was working at did not keep record of the use of plug gages at any machining operation. And yet they were ISO certified.
My p.o.v was that inspection is important, but keeping a yes/no record is not. If inspection is not done then it would be caught at final inspection.
About keeping record of every inspection, what if this inspection with plug gage is filled out just once in first-piece-inspection sheet? In this case the operator may not have to fill out any form every time there is need for inspection. Thus the first-piece sheet will give the evidence of inspection of that feature.
However, one can make argument that inspection of feature may have been recorded but inspection done by the operator is not!
Well, I think there is this gray area, and before making any decision I would have to talk to our external auditor in his next visit ... which is next week. :)
He is kind of a customer in this case.
Marc
They can do that, but in my opinion it is a very bad (as in stupid) business practice unrelated to a specific ISO 9001 requirement. If an inspection is identified (whether it is attribute data or discrete {aka 'variables'} data), it should be recorded and used in analysis (ultimately as a Management Review Input).
Think about the phrases: "Analysis of Data" and "Improvement".
Edit add: OK - Let's say it is a setup sheet. Are you doing 'Last Piece' for comparison?
Whether or not you do a lot of inspections and whether you record them is dependent upon the importance of the inspection(s). If you're making plastic duckies for kids in the bath tub (injection molding process), the importance of various checks will be different than if you're manufacturing High-Rel electronics equipment for the military.
Jafri
Ok. I think I am going to maintain the status quo ... except if the external auditor has no objection.
Many thanks.
JuneFoo
Wonder could we just fill up inspection form or reject data only once we found reject issue? (If control plan spell clearly this is the organization control). Hope some one can explain further.
D AS9100C Clause 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
E ISO 9001:2008 Clause 8.2.4 - Monitoring and Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Monitoring & Measurement of Product for Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Interpretation of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Monitoring and Measurement of Product in a Shop Selling Frozen Meat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Which 'customer' in 8.2.4 Monitoring and Measurement of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Explain the meaning of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J 8.2.4 Monitoring and measurement of product - Do I need to record every serial number Records and Data - Quality, Legal and Other Evidence 4
M Monitoring & Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C ISO 9001 - Monitoring and measurement of product - What is product in Transportation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Exclusion of 7.5.2 when the product can be verified by monitoring or measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Monitoring and measurement of product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 5
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H ISO 13485 - Monitoring and Measurement of Processes (Sections 8.2.5 / 8.2.6) ISO 13485:2016 - Medical Device Quality Management Systems 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 8
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J 8.3.2.1 Monitoring/Measurement Audit Finding IATF 16949 - Automotive Quality Systems Standard 6
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
S ISO 9001:2008 Clause 8.2.3 Monitoring and Measurement of Processes Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M 8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement IATF 16949 - Automotive Quality Systems Standard 10
G Monitoring and Measurement of Manufacturing Processes - TS 16949 Clause 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 2
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
A Monitoring and Measurement of Processes - ISO 9001 Service Industry Specific Topics 9
G 4.5.1 Performance Measurement & Monitoring - relevant information and analysis? Occupational Health & Safety Management Standards 3
D How to differentiate between monitoring and measurement devices? General Measurement Device and Calibration Topics 23
G Cl 8.2 Monitoring and measurement - articles & related reading material? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Monitoring and Measurement of Finished Goods with a Better Method IATF 16949 - Automotive Quality Systems Standard 2
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
