Monitoring Gauge Accuracy throughout the year using SPC
#11
bmccabe said:
:applause: Very good observation. :applause:
I have looked at, and devised many tests, to quantify the influence of form errors to measurement data and R&R analysis. What you and I know, but have yet stated, a GR&R will not attribute form error to part variation. When encountered, form error will be assigned to equipment variation (most likely) or operator influences.
Correct. If it is significant, you try to minimize the effect through consistent fixturing, or subtracting the variance from the MSA variance.
bmccabe said:
:This however was not the case with the data collected. The pin was not moved throughout the entire run: The program was set to auto-cycle, and produced a new data set every 40 or so seconds. What you are seeing in the data is the resolution and accuracy of the equipment only (by the design of data collection, not voodoo arithmetic.)
The cyclic behavior in the data is normal for these types of things. It's cause could be changes in dew point (the room is fairly temperature controlled, but relative humidity does change some.) It could be caused by changes in ambient light, or external vibrations, or even phase variations in the electric supply. Who knows... It's under a micron! ...Who cares!!!
After rethinking the periodicity of the data, I agree that it is probably in the machine itself or the environment. Try subgrouping the data (XBar/R) and spacing the time between subgroups such that the period effect is randomized. You should end up with an in-control XBar/R chart with limits close to the manufacturer's stated accuracy.
bmccabe - 2006
#12
Well, that definitely opened the control limits.
We are still about half the stated accuracy
(or my ability to care about improving).
Still, that’s a good point: Randomizing the data will open control limits.
Another question, if you’d care to answer. Do we want to randomize serial data? – Ever?
I’m sure the stats cops here will start whooping and swinging from the trees if we do.
#13
I wasn't clear enough. Do not randomize the data.
Use the data that you have already collected.
Pick a subgroup size. For the sake of clarity, I will use n=5. Take the first 5 data points, calculate average and range.
Pick a sampling interval. Again, for the sake of the example, use 30 minutes. Ignore the data points you collected between the first subgroup and the first reading at t=30 minutes. Take the next 5 data points, calculate average and range and repeat at 30 minute intervals until you run out of data.
Use these subgroups to create an XBar/R chart (not I-MR) in actual time sequence. Since the sampling frequency is significantly greater than the period shown in your data set, your subgroups should be taken when the "sine wave" is at a random amplitude. This will eliminate the pattern from your chart.
If the limits are still not quite right, there is a possibility that some degree of autocorrelation exists between successive data point for a small time interval. You could take every second or third data point when creating a subgroup as a test.
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
K Monitoring the identified side-effects and contraindications ISO 14971 - Medical Device Risk Management 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
E Insulation diagram for ECG monitoring and diagnosis system. IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
S HIPAA-compliant monitoring software (advice needed) Hospitals, Clinics & other Health Care Providers 1
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
qualprod Monitoring of lead time - Good KPI identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Textiles needed for home monitoring device - any suggestions? Other Medical Device Related Standards 1
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
Q AS9120B - ESD monitoring devices part of 7.1.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
P IATF 16949 - Monitoring Suppliers for Premium Freight IATF 16949 - Automotive Quality Systems Standard 12
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
chris1price Cleanroom Monitoring Plan - ISO14644-2:2015 - Risk Assessment Other Medical Device Related Standards 3
dhuot1990 Issues with REES Environmental Monitoring System Manufacturing and Related Processes 1
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
I FDA requirement for 0.5 and 5 micron particle monitoring US Food and Drug Administration (FDA) 0
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc New Posts and New Threads - Monitoring (aka "Watching") Elsmar Xenforo Forum Software Instructions and Help 1
L Monitoring transmitted data from a bluetooth medical product IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T How to plan the monitoring of suppliers ISO 13485:2016 - Medical Device Quality Management Systems 1
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
qualprod ISO 9001:2015 Cl. 4.1 and 4.2 - Evidences for Monitoring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 5
qualprod ISO 9001 Cl. 4.1 and 4.2 - What does monitoring and review mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Supplier monitoring - The meaning of "8.4.2.4 " Customer disruptions IATF 16949 - Automotive Quality Systems Standard 1
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
E IATF 16949 Cl. 9.1.2 - Monitoring Process Performance IATF 16949 - Automotive Quality Systems Standard 1
C Method of Monitoring our Internally Produced Non-Conforming Products Quality Tools, Improvement and Analysis 7
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
renenatasha MDD Classification for Pressure Monitoring Set CE Marking (Conformité Européene) / CB Scheme 1
