Monitoring & Measurement of Product
mshell
I am in the process of reviewing our Receiving Specifications and have found that we have specs that say "No Inspection Necessary" and that we require:
labels on a roll to be counted
parts in a bag to be counted (sometimes up to 5000)
Is acceptable to identify items that require inspection and perform inspection on only those items?
Are we required to count every nut or bold purchased or is our current documentation too detailed?
CarolX
I have many items that we don't "inspect" in the traditional manner.
For example.....
Hardware is verified for count and condition only. In other words, if it is packaged properly and no obvious damage, and the count seems right (no, we don't physically count), parts are accepted.
Does this help?
CarolX
Is acceptable to identify items used to manufacture product and require inspection on only those items?
The first question is why do receiving inspections at all? Because ISO says so, or because you want to make sure you got the right stuff? 7.4.3 requires that you "implement the inspection or other activities necessary for ensuring that the purchased product meets specified purchase requirements."
So, how do you ensure that the roll has enough lables? (I would laugh if you told me to unroll it, count the lables, and roll it back up --doesn't make sense does it?) How do you know how many parts are in the bag? Is is important to know these things?
It is your system, develop a method that suits your needs.
mshell
Thanks Guys,
As a result of our discussion, I have began the spec elimination process. We are a small organization with over 300 specs. I have now eliminated 31 Receiving Specs and am looking at a potential elimination of 162 in manufacturing. :)
Bob_M
mshell said:
Thanks Guys,
Just be careful not to eliminate a spec that you NEED. We all want to make things easier on ourselves and the production employees, but make sure the product quality will/can not suffer as a result of reducing or eliminating a spec.
Mike S.
Happy to be Alive
For things like labels, bolts, office supplies, etc. that are not being directly re-sold to a customer we let the receiving party "inspect" it. This usually involves them checking to see that it is the right stuff, the count looks about right, and initialing the PO and sending it to accounting. Depending on the order size it might take 30 seconds to 5 minutes, and the "procedure" is about 2 lines in our overall "incoming inspection" procedure. Keep it simple and effective -- the two are not mutually exclusive.
Good advice given in this thread.
I'd just like to add that the word inspection can have many meanings. When I was last involved in inspection activities in a previous job, we split the flood of incoming goods in this way:
Everything was subject to Identification (including a condition check), some of it also to counting and a small percentage to more "traditional" Inspection against specs (The latter accounted for about 3-4% of the incoming goods If I remember correctly).
The important and sometimes tricky part (mistakes will and must be allowed to happen) is to pick the stuff you need to inspect more thoroughly. This is where I recommend a written procedure.
/Claes
RoxaneB
Change Agent and Data Storyteller
For us, there are incoming materials and KEY incoming materials. The amount of inspection conducted is dependent upon their role in the quality of the end product and the nature of the product.
While I would love it if we could verify that the lime is the perfect compostion and size, we don't have the time nor resources to do that. Besides, the nature of our business allows to adjust the "recipe", taking into account variations in lime shipments. So, while a Key Incoming Material, the inspection is paperwork-oriented, certifcate of analsyis, bill of lading, timeliness, etc.
Where I buy my pens from is rather irrelevant, so our facility just ensures that the paperwork with the office supplies matches that of the purchase order.
The scrap metal we purchase is 100% inspected to ensure that we are melting only the proper materials. If a propane tank or shock absorber were to inadvertently make it into our furnace...well...the results could be devastating to our personnel.
To compensate for what seems to be a rather cumbersome inspection process then, we allowed each department to develop their own inspection matrix. They list the products, whether they are key, and the inspection process. If key, the process leads a person to the Approved Vendor List, where it is clearly recognized if the supplier is consistently and adequately meeting our requirements.
mshell
ASTM Standards
I have been reviewing product data sheets and I have a question. If we require a COA as proof of testing (receiving inspection) and the COA references ASTM tests, do we have to have to know how to perform the test? Do we need a copy of the test for our records?
Thanks,
mshell :confused:
howste
Thaumaturge
I don't believe so. Think about calibration labs. If I send my cages out for calibration to an ISO 17025 certified lab do I need to have a copy of ISO 17025 and know all of the requirements? Do I have to know all of their methods of calibration? You don't have to be experts in everything that your suppliers do.
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
D AS9100C Clause 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
E ISO 9001:2008 Clause 8.2.4 - Monitoring and Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Monitoring & Measurement of Product for Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Interpretation of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Monitoring and Measurement of Product in a Shop Selling Frozen Meat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Which 'customer' in 8.2.4 Monitoring and Measurement of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Explain the meaning of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J 8.2.4 Monitoring and measurement of product - Do I need to record every serial number Records and Data - Quality, Legal and Other Evidence 4
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C ISO 9001 - Monitoring and measurement of product - What is product in Transportation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Exclusion of 7.5.2 when the product can be verified by monitoring or measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Monitoring and measurement of product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 13
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
armani Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H ISO 13485 - Monitoring and Measurement of Processes (Sections 8.2.5 / 8.2.6) ISO 13485:2016 - Medical Device Quality Management Systems 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 15
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J 8.3.2.1 Monitoring/Measurement Audit Finding IATF 16949 - Automotive Quality Systems Standard 6
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
S ISO 9001:2008 Clause 8.2.3 Monitoring and Measurement of Processes Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M 8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement IATF 16949 - Automotive Quality Systems Standard 10
G Monitoring and Measurement of Manufacturing Processes - TS 16949 Clause 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 2
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
A Monitoring and Measurement of Processes - ISO 9001 Service Industry Specific Topics 9
G 4.5.1 Performance Measurement & Monitoring - relevant information and analysis? Occupational Health & Safety Management Standards 3
D How to differentiate between monitoring and measurement devices? General Measurement Device and Calibration Topics 23
G Cl 8.2 Monitoring and measurement - articles & related reading material? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Monitoring and Measurement of Finished Goods with a Better Method IATF 16949 - Automotive Quality Systems Standard 2
