Monitoring & Measurement of Product
SteelWoman
#11
Depends on what the COA says and what YOUR own internal requirements are. For instance we require suppliers to certify the steel they send us, and we take that information, but we only use it as a comparison, because we then turn around and test it ourselves in house. In that scenario OUR test is what matters, so we must maintain records of our test. If we didn't do that - if we brought in steel and used the vendor's test as the gospel for what that material is, then yes we'd have to keep a copy of that test. No, we wouldn't have to know how to perform the ASTM test it REFERENCES - that burden is on the vendor UNLESS I happen to have a customer who requires that I show my material has been tested to a PARTICULAR ASTM spec, in which case I'd have to know that that requirement is being met by my vendor.
RoxaneB
#12
You mean you don't trust us steel mills to put the right information on the mill certificate? ;) Just kidding!
mshell
#13
Specs Again
If I decide to purchase a product based on the manufacturer's datasheet, I obtain/archive a copy of the datasheet and the product works well for me. Do I have to create internal purchasing specifications or can my purchase order state that the product must be produced per the manufacturers requirements and it must be product XXXX.
Also, can I use a COA that states that product XXXX meets the manufacturing specifications of my supplier as proof of material conformance?
#14
We purchase a many, many semiconductors by manufacturer's name and number. We match only name, number and quantity to the parts received at incoming. We'd go broke testing every spec we're interested in. We expect Motorola, Texas Instruments, et al. to make their parts correctly. I, too, archive product spec sheets (gotta love those websites and pdfs). A distributor recently sent us 2 year old transistors. Our design was based on 1.5 year old data sheets and samples that met the specifications of the data sheet. The 2 year old parts were a previous design (with a 4 year old data sheet, we knew about these, they didn't work in our design). They did not meet the specifications of the new parts. Distributor convinced by evidence to pay for resulting scrap.
Mike S.
Happy to be Alive
#15
Your answer will no doubt partly depend on the situation, the type of parts, their criticality, industry practice, # of different parts involved, etc. But, for sure sometimes manufacturers put out data sheets, then later revise the data without you knowing it. If you have a data sheet with a revision indicator, you should be okay saying something like "P/N 123-C as per mfr. data sheet ABC Rev. 12/13/02". If there is no rev. indicator, or to be extra-safe, you could call-out the data from the mfr's. data sheet that you have in front of you on your PO, so even if the data sheet was revised, the vendor still knows what you want.
D AS9100C Clause 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
E ISO 9001:2008 Clause 8.2.4 - Monitoring and Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Monitoring & Measurement of Product for Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Interpretation of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Monitoring and Measurement of Product in a Shop Selling Frozen Meat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Which 'customer' in 8.2.4 Monitoring and Measurement of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Explain the meaning of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J 8.2.4 Monitoring and measurement of product - Do I need to record every serial number Records and Data - Quality, Legal and Other Evidence 4
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C ISO 9001 - Monitoring and measurement of product - What is product in Transportation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Exclusion of 7.5.2 when the product can be verified by monitoring or measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Monitoring and measurement of product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 5
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H ISO 13485 - Monitoring and Measurement of Processes (Sections 8.2.5 / 8.2.6) ISO 13485:2016 - Medical Device Quality Management Systems 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 8
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J 8.3.2.1 Monitoring/Measurement Audit Finding IATF 16949 - Automotive Quality Systems Standard 6
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
S ISO 9001:2008 Clause 8.2.3 Monitoring and Measurement of Processes Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M 8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement IATF 16949 - Automotive Quality Systems Standard 10
G Monitoring and Measurement of Manufacturing Processes - TS 16949 Clause 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 2
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
A Monitoring and Measurement of Processes - ISO 9001 Service Industry Specific Topics 9
G 4.5.1 Performance Measurement & Monitoring - relevant information and analysis? Occupational Health & Safety Management Standards 3
D How to differentiate between monitoring and measurement devices? General Measurement Device and Calibration Topics 23
G Cl 8.2 Monitoring and measurement - articles & related reading material? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Monitoring and Measurement of Finished Goods with a Better Method IATF 16949 - Automotive Quality Systems Standard 2
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
