Mother bobbin final inspection criteria
I am responsible to build a final inspection criteria for supplier of bobbin based paper. I am studying on ISO 3951 sampling procedures for inspection by variables. I hope you can guide me.
Here is a little bit of background;
1) At first, the batch is produced at supplier along web application.
Imagine a `mother reel' wrapped on a tube with 100cm width and 2000meter of web plastic in length.
2) Then, each mother reel is slit into 20 smaller bobbins which we receive into factory.
Each bobbin is now with 5cm width and 100meter length. In other words, 400bobbin per each mother reel.
3) We let supplier to release/ship the batch based on 5 different variables (numeric value, not attribute) with sampling plan AQL 2.5%, Normal Inspection, General Level II.
For 400 bobbin, we ask suppliers to take 30 bobbin (with k factor=1.471) and measure first 50cm from the end of the each bobbin. (I know the last part is a bit modified version of ISO).
Everything works well and there are also some incoming inspection process in place.
(By the way, please let me know if there is something can be improved).
However, nowadays some supplier suggest to perform the inspection of some variables on the mother reel itself, not necessarily on slitted bobbins - which make sense while considering the workload behind for them. This is also fine for me based on some experiments show that those variables are not affected by sliting/converting process.
Final width must be measured on slited smaller bobbins, but thickness can be also measured on mother reel. It is not affected by cutting process.
My question is how I should define the final inspection criteria at mother reel level. - for thickness for instance?
There are some limitations;
-It can't be inspected 100% of mother reel. Not only because of cost/time, also since winding/rewinding will most likely cause some problem(destructive).
-Unfortunately, not all supplier can measure the thickness via automated control, etc a sensor to measure web thickness continuously. (It would be perfect, then!)
Thank you for your time to read,
toniriazor
Hello
Have you audited your suppliers example the ones without automatic sensor to check their processes - how capable are they at producing the product you want, scrap rates and etc. For those without poke-yoke there should be strong process behind in my opinion. In fact a capable process is always better than inspection.
Ask your suppliers what alternatives equipment to automatic sensor can propose to measure this characteristic. This should be part of their MSA I think.
Is this inspection at your facility something extra you are doing or its mandatory ? I had some troubles understanding that.
Steve Prevette
Deming Disciple
For random sampling, we do desire to have any portion of the production be capable of being chosen to be sampled. There is a risk when only sampling the last (or is it first) 50 cm of the mother bobbin material. If the mother bobbin cannot be unwound and rewound without risk of damage, about the only way to do this is to sample the material as it is wound onto the mother bobbin. During the process of winding the bobbin, could the process be stopped at random time(s) in order to do a measurement? Or would that also cause damage?
I'll give credit to Dr. Deming for a similar situation unloading ore ships. They used to just pull a bucket of material when the hatch was opened, but that was not representative of the ore as the heavier (higher ore content) chunks settled to the bottom during transport. So they developed a random process for determining when to stop the unloading and go to a certain point on the conveyor belt and grab a bucket there.
John Predmore
I have not seen your equipment but is it possible to measure thickness of the paper as it passes over a roller with a digital test indicator? The ones I looked up are accurate to 0.00005", for less than $500. Maybe you have a clever engineer who can mount the test indicator in a way so the probe can be extended/retracted to the paper without stopping the machine, and moved cross-web to sample different points.
M Case study - If the restaurant (ISO 9001:2015 certified) was run by 2 persons covering cooking and purchasing processes (Mother and Father) supported ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Jen Kirley Risk Based Thinking and acts of God/Mother Nature Business Continuity & Resiliency Planning (BCRP) 1
V Examples of investigation or root-cause categories - Mother Nature (Environment) Problem Solving, Root Cause Fault and Failure Analysis 3
Stijloor Happy Mother's Day!!! May 2012 Coffee Break and Water Cooler Discussions 5
P 25 Reasons why I owe my mother Funny Stuff - Jokes and Humour 0
M Happy Mother's Day 2006 Coffee Break and Water Cooler Discussions 10
tony s Does RFQ from mother plant enough to initiate TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 2
L To all Cove mothers! Happy Mother's Day - 2005 Coffee Break and Water Cooler Discussions 3
alonFAI Gaps between the Bobbin and the Ferrite Core in a Transformer Manufacturing and Related Processes 1
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final and update guidances – Software Medical Device and FDA Regulations and Standards News 2
M Informational USFDA final guidance – Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
M Informational Final guidance – GUIDELINES on the benefit-risk assessment of the presence of phthalates in certain medical devices covering phthalates which are carc Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Acceptance Review for De Novo Classification Requests Medical Device and FDA Regulations and Standards News 1
M Informational US FDA Final Guidance – Humanitarian Device Exemption (HDE) Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
V Removing final inspector for medical device manufacturing Lean in Manufacturing and Service Industries 4
M Informational US FDA Final guidance – Postmarketing Safety Reporting for Combination Products Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Requests for Supervisory Review of Certain Decisions Made by the Center for Devices and Radiological Health – Final Rule Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance – Marketing Clearance of Diagnostic Ultrasound Systems and Transducers Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance Characterization of Ultrahigh Molecular Weight Polyethylene (UHMWPE) Used in Orthopedic Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA final guidance – Unique Device Identification: Convenience Kits Medical Device and FDA Regulations and Standards News 0
M Informational USFDA final guidance – Recommended Content and Format of Non-Clinical Bench Performance Testing Information in Premarket Submissions Medical Device and FDA Regulations and Standards News 0
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
M Informational IMDRF final document – Assembly and Technical Guide for IMDRF Table of Contents Submissions Medical Device and FDA Regulations and Standards News 4
M Informational USFDA Final Guidance – Medical Devices Containing Materials Derived from Animal Sources (Except for In Vitro Diagnostic Devices) Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Rule – Human Subject Protection; Acceptance of Data From Clinical Investigations for Medical Devices Medical Device and FDA Regulations and Standards News 0
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M FDA News USFDA Final Guidance – Intent to Exempt Certain Unclassified Medical Devices from Premarket Notification Requirements Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Guidance – Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 2
M Informational USFDA Final Guidance – Coordinated Development of Antimicrobial Drugs and Antimicrobial Susceptibility Test Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Guidance – The Least Burdensome Provisions: Concept and Principles Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Report – MDUFA IV Independent Assessment of FDA’s Device Review Process Management Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA – Breakthrough Devices Program final guidance Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Guidance – Manufacturing Site Change Supplements: Content and Submission Medical Device and FDA Regulations and Standards News 1
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
M Medical Device News FDA News - 03-10-18 - CDRH FY 2019 Proposed Guidance Development and Focused Retrospective Review of Final Guidance Other US Medical Device Regulations 0
M CE / FCC Compliance for components + final product CE Marking (Conformité Européene) / CB Scheme 2
JoCam Medical Device Final Assembly Labelling EU Medical Device Regulations 2
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
T Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Serialization at Final Quality Check ISO 13485:2016 - Medical Device Quality Management Systems 3
S Final Medical Device Regulations replacing MDD 93/42/EEC, etc. EU Medical Device Regulations 15
