Moving a Calibration/Test Laboratory to a new Location
tacom
According to clause 5.4.2 of 17025 Lab. must confirm that it can properly operate standard method before introducing the tests. So, to fulfill this requirement some studies (precision, bias etc..) must be done.
İf laboratory ( using instrumental analysis ) moves to new place All the work (precision, bias, etc..) done should be renewed ?. if not what work should be done ?
Do you share your thoughts with me please?
Thanks in advance
TACOM
BradM
Hello Tacom! :bigwave:
If I understand your question, you have a current calibration/ test laboratory with existing measurement uncertainties calculated. You are wanting to move that calibration/test laboratory, and you are wondering if new tests need to be performed in the new location.
Have you performed a validation of the new facility, and the installation? Are environmental factors controlled to the same level (or tighter) than in the existing location?
tacom
We have a chemical lab. We are doing chemical analysis using gas chromatography (GC). İn order to confirm that we properly operate standard method we did some studies called method verification.That is repeatability , LOD;LOQ; Recovery ,…studies.
Now we are planning to move another location where it’s laboratory facilities better than existing one . After moving all balances will be calibrated and GC will be subjected to performance and operational calification ( PO and OQ) test by vendor again.
My question is after moving new lab. all verification studies (repeatability , LOD;LOQ; Recovery etc..) should be done from beginning to end again? Or to what degree these studies should be done?
Thanks again
TACOM
dwperron
Thanks in advance
TACOM
Have you checked with your accreditation body?
The body I work with (A2LA) has a policy document concerning moving a lab, and can let you know what they would expect from your organization.
BradM
We have a chemical lab. We are doing chemical analysis using gas chromatography (GC). İn order to confirm that we properly operate standard method we did some studies called method verification.That is repeatability , LOD;LOQ; Recovery ,?studies.
Now we are planning to move another location where it?s laboratory facilities better than existing one . After moving all balances will be calibrated and GC will be subjected to performance and operational calification ( PO and OQ) test by vendor again.
Thanks again
TACOM
Tacom, sorry to ask another question. :D But does your organization have established Change Control? Hopefully you have some language already established for this type of move.
To answer your question, I would say it would depend on how the initial validation was conducted and the IQ of the equipment/instrumentation. For example, if you are moving an analytical balance, I would suggest that all the measurements should be repeated, as there are so many variables related to the environment that could affect those.
However, I would probably guess that the GC is less prone to IQ factors as the analytical balance. However, you have to disconnect hoses/lines, and individually move all those components. When you move it all back in the new place, hopefully you can have the vendor perform some type of maintenance/re-qualification on it. I would perform a system suitability on it to assure everything is OK. Within that suitability, you could verify repeatibility and such.
IMO, the level of activity required after the move depends on the accreditation body (as mentioned), existing Change Control documentation, Risk, and how well/thorough the original IOQ was performed. Saying, it may have a chart or something in it to demonstrate what actions are needed for a particular change.
Jerry Eldred
We recently moved a lab under ISO17025. It was a fairly simple process. We discussed with our accreditation body, and detailed what ever changed. So if moving, I think it is a matter of considering that in the move, what things may have changed? If environmental conditions are critical, could be you need to analyze its impact. Many aspects of lab operation are unchanged in the move. Without knowing particulars of your lab operations, I can't comment on what those implications are.
I would say to have a good discussion with your accreditation body to find mutually agree on what things that could impact your measurement results/uncertainties have or may have been changed (and need to be evaluated).
B Effect of Calibration Laboratory Changing Ownership & Moving on ISO17025 registration ISO 17025 related Discussions 4
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
D Company Moving - Relabelling Question Medical Device and FDA Regulations and Standards News 0
Jen Kirley Moving on - I accepted an offer to be a Supplier Quality Engineer at GE Healthcare Coffee Break and Water Cooler Discussions 42
S Moving from client-server to cloud-based, is that a new submission? Medical Information Technology, Medical Software and Health Informatics 3
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
supadrai What to expect when moving to higher-risk medical devices? Other Medical Device and Orthopedic Related Topics 1
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
N How is documentation affected moving to an electronic system? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Moving from ProArc to IFS Document Management Document Control Systems, Procedures, Forms and Templates 1
K Sister Company Moving to AS - First time "consultant" - Help? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Moving (Transition) From ISO 14001:2004 to ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
P Moving from a Paper based Quality System to an Electronic Quality System Manufacturing and Related Processes 14
S Validation requirement after moving labeling data base to different drive Software Quality Assurance 7
Q REACH due dilligence and meeting the ever moving SVHC target RoHS, REACH, ELV, IMDS and Restricted Substances 5
C Moving to a different Notified Body Quality Manager and Management Related Issues 5
R What Documentation is done by QA in FMCG (Fast Moving Consumer Goods) Misc. Quality Assurance and Business Systems Related Topics 2
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
C ISO9001: Moving from site certification to corporate certification Quality Manager and Management Related Issues 9
R Moving from ISO 9001 to AS9120A Document Control Systems, Procedures, Forms and Templates 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
N Protective Earthing of Medical Device Moving Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Moving our Distribution Company - ISO 9001 Certification Impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N NCR and CAPA in the FMCG (Fast Moving Consumer Goods) Industry Nonconformance and Corrective Action 1
D A2LA Certification and moving to a new Facility General Measurement Device and Calibration Topics 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
L Moving SPC Data from Variables to an Attributes Chart Statistical Analysis Tools, Techniques and SPC 4
S Advice on moving QMS Documents and Maintaining Revision History Quality Manager and Management Related Issues 9
N Requirements when moving locations - Class 1 Medical Device Manufacturer in the US Other Medical Device Regulations World-Wide 4
D AS9100 Shop Moving to a New Location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Moving On Coffee Break and Water Cooler Discussions 12
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
W Moving M&TE (Measuring & Test Equipment) to New Facility General Measurement Device and Calibration Topics 3
E Moving Window Test - Is this test about determining the Threshold Voltage? Quality Tools, Improvement and Analysis 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
R Moving to an Electronic System - Quality System Software Recommendations ISO 13485:2016 - Medical Device Quality Management Systems 5
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
L Validation Plan Requirements when moving to a new Plant - Medical Device Industry Qualification and Validation (including 21 CFR Part 11) 19
V Supplier Moving Manufacturing Location after original PPAP APQP and PPAP 4
P Statistical Sampling of Packaging Material Testing? Fast Moving Consumer Goods Supplier Quality Assurance and other Supplier Issues 4
