Moving and positioning of patient - Mechanical hazard
AbelVV
Good afternoon everybody,
I am currently trying to identify the hazards on a medical device. One of the inputs for that is the hazards identified in the applicable standards. Table 19 in chapter 9 of the general standard lists "Moving and positioning of PATIENT" as one of the hazards addressed by 9.2 Moving parts and 9.4 Unstability.
I think I have a good handle on all the other hazards in table 19, but I don't understand this one. English is not my native language so it could be part of the issue.
My intuition tells me that unexpected movement or position of the patient could cause hazards through interaction with other parts of the ME system or even external sources. Is that correct?
Really thankful about any help!
Marcelo
Yes, however, please note that the term "Moving and positioning of PATIENT" is not exactly a hazard in itself (as the source of the hazard is not the movement or positioning). The thing is, not all things labeled "hazards" in IEC 60601are exactly hazards, depending on the structure you define your hazards to be.
Ronen E
Problem Solver
Moderator
The definition of HAZARD is "a potential source of HARM".
If an ME equipment or ME system moves or positions the patient (e.g. MRI machine) it is a potential (mechanical) source of harm - the patient might theoretically be pinched, scraped, crushed etc. So the fact that moving or positioning the patient is involved introduces a potential for patient harm.
Marcelo
Unfortunately, the definition is so open that it's simply impossible to apply as it is. That's why you need to define a framework for hazard description and categorization. One common, historical framework used in several different fields is to categorize hazards based on the energy source that gives the harm - in this way, patient movement is not a hazard, but for example the impact was a result of patient movement is.
Unfortunately, ISO 14971 does not require a framework for hazard description and categorization, but you really need to do it, otherwise, you will create problems in the risk management process.
Ronen E
Problem Solver
Moderator
I don't see where the problem is.
To me, the purpose of identifying hazards is simply creating starting points / anchors from which scenarios or combinations of conditions that lead to hazardous situations can be laid out. IMO moving or positioning a patient is a very clear such starting point, at least in terms of harm that is brought about mechanically.
If an energy source categorisation is required, it should fall under kinetic energy or potential energy (e.g. lifting the patient to a position they might fall from).
Marcelo
The purpose of identifying hazards is to create a starting point, but the hazardous situation is the exposure of the hazard. If the hazard does not match the hazardous situation, you can write anything you want, it just is not right. That's why you need to define a framework for that.
As I mentioned, a categorization is not required by the standard, but you can't apply the risk management process without it.
AbelVV
But acording to 60601 chapter 9, scrapping, crushing, et cetera are already hazards. Therefore "moving the patient" would be a hazardous situation (seeing that it leads to a hazard), not a hazard. I guess that's what I find confusing. I am inclined to listen to Marcelo and not read this table literally, seeing that it is not a requirement per se, only a list of things to keep in mind for the RMF.
Ronen E
Problem Solver
Moderator
I get the impression that you got your definitions mixed.
You might be mixing harm with hazard.
A hazard is a characteristic of, or an aspect of the nature of the device, that allows some specific harm to even be relevant. The hazard is always there, or it always isn't there, depending on the very nature of the device. It isn't something that something else leads to under specific circumstances. What "leads to" a hazard is the definition of the device's intended use and its high-level design.
A hazardous situation is something that may or may not come about (it's probabilistic), under specific circumstances. It stems from a hazard; if no relevant hazard is there, the hazardous situation can't come about. For instance, if the device may, by nature, move the patient, and there's a pinch point that is accessible, then at some probability the patient's finger will be there. That's a hazardous situation.
Once a hazardous situation comes about, it may or may not lead to a specific harm. This is also probabilistic.
In the current specific context, the fact that a device involves moving or positioning a patient enables the discussion about some hazardous situations. If a device doesn't lift a patient or holds them at a significant height, there's no point discussing the possibility that the patient will fall. If the device is a blood pressure transducer, it can't endanger the patient through scraping or crushing. The probability of that is exactly 0. That device doesn't have hazards related to moving or positioning the patient.
AbelVV
I understand. Then Table 19 in Chapter 9 is not correct when listing "crushing hazard" and others, since the actual hazards are the subclauses associated with them like Trapping zone and overtravel, et cetera.
Marcelo
In this particular example, the patient is exposed to being crushed, so the hazard is a crushing hazard, which is related to the possible harm. The fact that the patient moved or was moved is not related to the harm.
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
D Company Moving - Relabelling Question Medical Device and FDA Regulations and Standards News 0
Jen Kirley Moving on - I accepted an offer to be a Supplier Quality Engineer at GE Healthcare Coffee Break and Water Cooler Discussions 42
S Moving from client-server to cloud-based, is that a new submission? Medical Information Technology, Medical Software and Health Informatics 3
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
supadrai What to expect when moving to higher-risk medical devices? Other Medical Device and Orthopedic Related Topics 1
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
N How is documentation affected moving to an electronic system? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Moving from ProArc to IFS Document Management Document Control Systems, Procedures, Forms and Templates 1
K Sister Company Moving to AS - First time "consultant" - Help? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Moving (Transition) From ISO 14001:2004 to ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
P Moving from a Paper based Quality System to an Electronic Quality System Manufacturing and Related Processes 14
S Validation requirement after moving labeling data base to different drive Software Quality Assurance 7
Q REACH due dilligence and meeting the ever moving SVHC target RoHS, REACH, ELV, IMDS and Restricted Substances 5
C Moving to a different Notified Body Quality Manager and Management Related Issues 5
R What Documentation is done by QA in FMCG (Fast Moving Consumer Goods) Misc. Quality Assurance and Business Systems Related Topics 2
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
C ISO9001: Moving from site certification to corporate certification Quality Manager and Management Related Issues 9
T Moving a Calibration/Test Laboratory to a new Location General Measurement Device and Calibration Topics 5
R Moving from ISO 9001 to AS9120A Document Control Systems, Procedures, Forms and Templates 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
N Protective Earthing of Medical Device Moving Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Moving our Distribution Company - ISO 9001 Certification Impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N NCR and CAPA in the FMCG (Fast Moving Consumer Goods) Industry Nonconformance and Corrective Action 1
D A2LA Certification and moving to a new Facility General Measurement Device and Calibration Topics 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
L Moving SPC Data from Variables to an Attributes Chart Statistical Analysis Tools, Techniques and SPC 4
S Advice on moving QMS Documents and Maintaining Revision History Quality Manager and Management Related Issues 9
N Requirements when moving locations - Class 1 Medical Device Manufacturer in the US Other Medical Device Regulations World-Wide 4
D AS9100 Shop Moving to a New Location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Moving On Coffee Break and Water Cooler Discussions 12
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
W Moving M&TE (Measuring & Test Equipment) to New Facility General Measurement Device and Calibration Topics 3
E Moving Window Test - Is this test about determining the Threshold Voltage? Quality Tools, Improvement and Analysis 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
R Moving to an Electronic System - Quality System Software Recommendations ISO 13485:2016 - Medical Device Quality Management Systems 5
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
L Validation Plan Requirements when moving to a new Plant - Medical Device Industry Qualification and Validation (including 21 CFR Part 11) 19
V Supplier Moving Manufacturing Location after original PPAP APQP and PPAP 4
P Statistical Sampling of Packaging Material Testing? Fast Moving Consumer Goods Supplier Quality Assurance and other Supplier Issues 4
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
