Moving from a Paper based Quality System to an Electronic Quality System
Ninja
Looking for Reality
#11
Consider open architecture software that you can control yourself.
A rapid deployment dbase such as Filemaker Pro leaves you in control of when it is worth upgrading..(and thus validating)...
We moved electronic in Filemaker for less than 1% of what it would have cost for a closed system ERP...and we can customize as we see fit...IF we see fit.
It took longer to scan the documents than to make the pdf's accessible and govern restrictions on each.
(I do not work for Filemaker)
#12
At least there is more to choose from today than when we first decided to go paper free. We had more or less one choice: To build it ourselves.
So we did cobble something together, and I have to say that the end result left something to be desired. I think it is called user friendliness :rolleyes: Well, the end users actually could live with it, but the admin side of it was an all hands on nightmare. Time better used to develop the system disappeared into an admin quagmire.
What I am trying to say is that given the choice between putting something together myself again and buying something off the shelf, I would shy away from building it myself. There are pretty decent alternatives on the shelves today.
Sebastian
#13
We have some procedures driven by forms.
Problem we had, which was caused by establishment of second plant, was flow of these forms between plants. Initially, people signed forms with pen, than scanned and forwarded them by e-mail. So readability was poorer and poorer even file size gone up.
I have decided to buy Adobe Acrobat. There is Livecycle Designer embedded with it, which is particularly designed to make pdf forms.
Now we have pdf forms and every Adobe Reader user can create own signature and sign them free of charge.
Problem is price of Acrobat and getting knowledge how to use it.
mattador78
#14
I'm a dinosaur, I know. :)
I use MS Excel for our form 0001 - Master Doc List.
There is an active and an obsolete tab.
In the active tab, each row lists a form/procedure/work instruction and I have columns for Form, Rev., Rev. Date, Doc Title, Reason for Creation/Revision, Date of Review, Reviewer, and Notes.
In the Doc Title column, I link the correct document to my form 0001.
I have someone test the link as part of the document acceptance process (in case I thought I did it and just checked the box).
The Master Doc List obsolete tab is not linked.
Current revisions are on a shared network drive with appropriate network permissions (read only, full access...). Obsolete revisions are moved to a drive that is only accessible by doc control and upper management.
I also keep (*gasp*) three ring binders for the Quality Manual, the Procedures, Work Instructions, and Forms. Each doc has a hard copy in the book with the hard copy of the approval\training form. The fields on the approval\training form are the same as on the Master Document List, to make copy and paste easier.
To access documents, employees go to the Master Doc List and click or they go to the forms folder and go to form 0024 - ASL, because it is easy to get to. It is also cool to see people go to a folder and type "0-0-2-4 enter" and see their form pop up. It has impressed an auditor before.
I don't class that as a dinosaur way of doing it as ive just started something similar myself. I think its a system that works and isn't over complicated. Extremely glad I read somebody else works on a similar principal, :agree1:
UncleFester
#15
I'm old school - rather like most of the clients I work with - there's nothing you can't digitise these days and as already suggested, most of the templates are forms you're already using.
I tend to help clients organise their documentation, either on an intranet or within a local folder whereby document controllers have write access.
The folders are simple to organise in a tiered structure: policies, procedures, work instructions, forms and records.
Whether or not there's an intranet, I help the client create a dashboard, usually in PowerPoint that links Policies, Procedures, Work Instructions, Forms and Records in a pictogram format, showing how all processes are interlinked. The PowerPoint is saved as a pdf and a shortcut sent to everyone. So everyone can use the dashboard to understand how their processes are mapped and users can locate documents by navigating the dashboard.
Updates are easily made to the Master PowerPoint which is then saved over the existing pdf. As everyone has a shortcut there's no need to send out updated documents, merely update the change history on the PowerPoint.
Easy to manage and control, just how clients like it.
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
D Company Moving - Relabelling Question Medical Device and FDA Regulations and Standards News 0
Jen Kirley Moving on - I accepted an offer to be a Supplier Quality Engineer at GE Healthcare Coffee Break and Water Cooler Discussions 42
S Moving from client-server to cloud-based, is that a new submission? Medical Information Technology, Medical Software and Health Informatics 3
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
supadrai What to expect when moving to higher-risk medical devices? Other Medical Device and Orthopedic Related Topics 1
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
N How is documentation affected moving to an electronic system? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Moving from ProArc to IFS Document Management Document Control Systems, Procedures, Forms and Templates 1
K Sister Company Moving to AS - First time "consultant" - Help? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Moving (Transition) From ISO 14001:2004 to ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
S Validation requirement after moving labeling data base to different drive Software Quality Assurance 7
Q REACH due dilligence and meeting the ever moving SVHC target RoHS, REACH, ELV, IMDS and Restricted Substances 5
C Moving to a different Notified Body Quality Manager and Management Related Issues 5
R What Documentation is done by QA in FMCG (Fast Moving Consumer Goods) Misc. Quality Assurance and Business Systems Related Topics 2
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
C ISO9001: Moving from site certification to corporate certification Quality Manager and Management Related Issues 9
T Moving a Calibration/Test Laboratory to a new Location General Measurement Device and Calibration Topics 5
R Moving from ISO 9001 to AS9120A Document Control Systems, Procedures, Forms and Templates 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
N Protective Earthing of Medical Device Moving Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Moving our Distribution Company - ISO 9001 Certification Impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N NCR and CAPA in the FMCG (Fast Moving Consumer Goods) Industry Nonconformance and Corrective Action 1
D A2LA Certification and moving to a new Facility General Measurement Device and Calibration Topics 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
L Moving SPC Data from Variables to an Attributes Chart Statistical Analysis Tools, Techniques and SPC 4
S Advice on moving QMS Documents and Maintaining Revision History Quality Manager and Management Related Issues 9
N Requirements when moving locations - Class 1 Medical Device Manufacturer in the US Other Medical Device Regulations World-Wide 4
D AS9100 Shop Moving to a New Location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Moving On Coffee Break and Water Cooler Discussions 12
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
W Moving M&TE (Measuring & Test Equipment) to New Facility General Measurement Device and Calibration Topics 3
E Moving Window Test - Is this test about determining the Threshold Voltage? Quality Tools, Improvement and Analysis 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
R Moving to an Electronic System - Quality System Software Recommendations ISO 13485:2016 - Medical Device Quality Management Systems 5
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
L Validation Plan Requirements when moving to a new Plant - Medical Device Industry Qualification and Validation (including 21 CFR Part 11) 19
V Supplier Moving Manufacturing Location after original PPAP APQP and PPAP 4
P Statistical Sampling of Packaging Material Testing? Fast Moving Consumer Goods Supplier Quality Assurance and other Supplier Issues 4
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
