Hi all,
I have just moved to an engineering services company which has a really old fashioned QMS, totally paper based. I am planning a rehaul and am fine with most of it.
Where I am unsure however and would appreciate some guidance is in the area of process and approval sign offs. I am trying to move entirely away from paper and physical signatures but right now the company fill in forms for most steps performed and sign them off. Then after most tasks some form of QA will be performed and people sign off these same sheets and then towards the end a senior engineer will sign off a form saying they have reviewed the report and that are happy with it. So at the end you typically have up to 10 sheets of different colours which get put in different boxes and when filled get put offsite.
What I would like to do is create a single .xls spreadsheet to house all project function information, each step/function would have a separate tab. Per function the analysis work, the QA and the rework would be on a single tab. Then for senior review and sign offs there would be another. As most projects are similar it only needs to be set up once and anything unique could be just added in. One of the main reasons is to allow me get some metrics and useful outputs as I have no benchmarks for anything.
If I go this route then I don’t want to have to get physical signatures so if anyone has any ideas as to what I can do here which will also allow us to comply with ISO I would appreciate it. I am guessing maybe electronic signatures would be an option but I don’t know how this would work with excel and I don’t know much of this area either.
Apologies if this is covered somewhere, I have looked about but did not find anything specific to this issue.
Thanks in advance for your help.
Mark.
Mark.
