Moving to Intranet QM (Quality Manual and Documentation) - Recommendations?
Marc
#11
If you change the navigation 'method' in an html site, I doubt this would be a 'change' issue. But then again - did you give training in accessing documents initially? Many companies do. If so, you will *probably* have to redo the training if the change is not 'intuitive'. Note that often 'training' for using a site to access documents is little more than a pdf file by e-mail explaining the basics. But again - it depends upon your company. This is as much a common sense issue as anything else.
L
lday38
#12
key points for intranet - beyond document control
I was wonderign if anyone had some key points in setting up an internal intranet beyond control of the QMS documentation. But perhaps what to forget and what not to forget. Such as our mother company handles the safety and enviromental policies so I should leave that alone. I am the quality manager and mangement representative. I was planning in the future of using email to notify them by email of revisions to the QMS.
I been thinking whether I could use it for training and access to QMS documentation for outside auditors. I went this way because my company has gone personnel lean and I coudlnt keep up with the seven QM's out there. I still have several work instruction books that are controlled.
In additon, I have designed many databases which several differanat mangement are making use of. All though I've allowed file sharing, there is still some where there is a compatability issue. Then there is the company metrics which I do all the secretarial work now. The person responsible doesn't seem to want in but if I make it a link.I should be all set.
SteelWoman
#13
We have everything on intranet also - have from the start and it's held up very well to usage AND audits. We take all our documents and convert them to PDF format for publication on the intranet - keeps anyone from being able to modify them AND is a format that is available on all the computers on the production floor, can be easily pulled up and doesn't require any special training to do so.
#14
Beyond control of the QMS... Well, we use the intranet for a multitude of information. Since the QMS represents the rules we are supposed to follow, we use the intranet to explain why that is so... Have a look at:
How does your Company Communicate Requirements to Employees
How many of you would say you have or use good visuals in the shop?
Exactly what we do, and it works well. We are not entirely paper free however, so in addition we still use the reciept system... via a form on the intranet.
I suggest the following links to a couple of e-learning threads:
Use of Computer Aided Learning for Quality Topics - E-Learning
E-learning take 2... Is anyone currently, or in the past, tried E-Learning?
Live Training Vs. Software Self-Training - Complete training on 14001
Ouch... Well, if you are personell lean, you will probably be forced to go lean systemwise too. I have been through the same thing, and extensive use of databases and intranet saved my bacon as well.
We have had some great discussions about intranet based systems in the past. Try these links:
Moving to a Paperless Electronic Doumentation System - Seeking Ideas
Document Control and Distribution - How to save paper?
4.2.3d
Notes on equipment
Paperless systems
/Claes
Randy Stewart
#15
One of the easiest ways to for doc control, that I have found is a 1 gig sansdrive. Master copies are stored on it, it is write protected and all I have to do is plug it in to any USB port and the documents are there. No fuss, no muss. We have a published Master List (Excel) that is hyper linked to the intranet library, when I plug the sansdrive in, I receive a message about any changed documents (Word). You can get a 1 gig drive for $80 now, with 2 gig starting at $150.
Think about it this way, I can download an HD movie on it. Take it home and plug it into my TV or computer to watch. I could also save it on the TVo. They're great folks, it is also a very cheep offsite back up.
Wes Bucey
#16
Russ said:
Thanks for all the good ideas. Just out of curiousity, how has everyone handled accessability for each department, especially those with 2nd & 3rd shift and no regular Supervisor.
There are off-the-shelf electronic document management and control systems which provide security levels and audit trails for documents.
Security level determines who may access document and whether the person may read, print, copy, modify, delete, create new, etc.
The audit trail keeps track of who accessed document and what he did with it.
By assigning a security level to each individual, you can allow necessary access without fear of losing control.
L
lday38
#17
Good Ideas- I cant wait to review the links
:applause: yet, this morning. I have something else on my mind. let me try to explain, I used to stamp part prints with a stamp then have the engineering manager and me sign off as a review ( tool , gauge changes,etc. . ) This would be in the master locked document control file. I then would make a copy for the job file, this was used to make copies every time the part was setup.
Now , our mother company and our customer says they want me to access their server at each setup for the current revision and keep no prints in the drawers. They do tell me they will notify me if the print has a change in dimensions or material . Otherwise they feel it is not necessary. I can find some ways around it -like I suppose when they notify me of a change - I'll stamp that print with the review and also stamped uncontrolled. I also listed their revision in a database that shipping uses on their packing list and ceritification. It seems they operate seperately and yet they also ask like we are the same company without any thought to the resources or system at this plant. I tried hard on the spelling and typing.
Wes Bucey
#18
You have several noteworthy points in your post:
  1. Current method of controlling customer prints - very good method of revision control
  2. Customer changes method of providing prints
  3. Not sure how to contol revision level of customer prints in-house (how do we know for sure WHEN to change process to accommodate new revision from customer when we do not receive hard copy and customer has "pull" system of revisions rather than "push" systems?)
  4. Customer is not sympathetic with in-house problems he causes us.
My comments:
  1. You have/had a nice workable system. Do you have more than one customer? If so, keep this system in place for them.
  2. Customer changes are inevitable - you have to have a method to deal with them without throwing the rest of your processes off balance. This is the purview of the wonderful "Contract Review" process - a company reviews its capability and capacity BEFORE accepting new work. It makes sure it is absolutely sure of customer requirements. It negotiates with customer when there are "glitches."
  3. You must negotiate with customer to provide you with NOTICE (email) when each revision of a print affecting your company is posted. In that notice should be a summary of changes and notice whether your company should continue making product to old print or stop and begin on new print. It should also tell you how to handle finished goods to the old print. It should further give a "window of compliance" time for your company to agree or balk and ask for contract change (price, penalty, delivery windows, etc.?) Configuration Management (of your customer) would dictate that you get notice immediately, not at your schedule of "each setup" - I had one setup that lasted for two years for one machine, one product, only changing expendable tooling, not the "setup."
  4. Customer is not expected to be "sympathetic" - you are expected to be self-protective in conducting Contract Review and only agree to things within your cabability and capacity at a price which gives you a profit.
I don't mean this to be harsh or accusatory. The plain fact is, most customers will take advantage of suppliers who don't stand up for themselves. It's tempting to cave-in to big customers, but there are a lot of folks who got burned by Sears when they made Craftsman tools and components for Sears. Sears kept taking more and more of capacity until supplier needed Sears more than oxygen - that's when Sears started demanding concessions on price, etc. which drove supplier to near bankruptcy. Lesson: "think of the 'camel in the tent' story - if you give an inch, soon you'll be giving a mile."
L
lday38
#19
more than one system due to more than one customer
yes, there will be an email becuase I have seen them before but they dont always cover all the areas you mentioned. I'll try to get agreement on that.
What are your thoughts on ISO/TS 16949 requirement on print review?
I mention in the last posting how I thinking of handling it.
L
lrowe
#20
QM Docs on Intranet
We use a system similar to some of the posts here, but in addition the intranet access is really just a set of links that pull up the electrocic versions of the controlled approved documents. THis way you don't have to worry about considering this a change to the document at all. All our controlled docs are password protected (in Word format) so that there is no chance of someone editing the document somhow (even by accident) and THEN printing a copy. A read only set up only keeps the original doc from being over written. Other than that, we give a 7 day drop dead date on the printed version from the day it was printed. Our controlled docs are not terrible dynamic so the chance of 2 revisions of the same doc dated as valid are very slim.
Hope this helps!!
Larry Rowe
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
D Company Moving - Relabelling Question Medical Device and FDA Regulations and Standards News 0
Jen Kirley Moving on - I accepted an offer to be a Supplier Quality Engineer at GE Healthcare Coffee Break and Water Cooler Discussions 42
S Moving from client-server to cloud-based, is that a new submission? Medical Information Technology, Medical Software and Health Informatics 3
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
supadrai What to expect when moving to higher-risk medical devices? Other Medical Device and Orthopedic Related Topics 1
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
N How is documentation affected moving to an electronic system? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Moving from ProArc to IFS Document Management Document Control Systems, Procedures, Forms and Templates 1
K Sister Company Moving to AS - First time "consultant" - Help? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Moving (Transition) From ISO 14001:2004 to ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
P Moving from a Paper based Quality System to an Electronic Quality System Manufacturing and Related Processes 14
S Validation requirement after moving labeling data base to different drive Software Quality Assurance 7
Q REACH due dilligence and meeting the ever moving SVHC target RoHS, REACH, ELV, IMDS and Restricted Substances 5
C Moving to a different Notified Body Quality Manager and Management Related Issues 5
R What Documentation is done by QA in FMCG (Fast Moving Consumer Goods) Misc. Quality Assurance and Business Systems Related Topics 2
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
C ISO9001: Moving from site certification to corporate certification Quality Manager and Management Related Issues 9
T Moving a Calibration/Test Laboratory to a new Location General Measurement Device and Calibration Topics 5
R Moving from ISO 9001 to AS9120A Document Control Systems, Procedures, Forms and Templates 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
N Protective Earthing of Medical Device Moving Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Moving our Distribution Company - ISO 9001 Certification Impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N NCR and CAPA in the FMCG (Fast Moving Consumer Goods) Industry Nonconformance and Corrective Action 1
D A2LA Certification and moving to a new Facility General Measurement Device and Calibration Topics 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
L Moving SPC Data from Variables to an Attributes Chart Statistical Analysis Tools, Techniques and SPC 4
S Advice on moving QMS Documents and Maintaining Revision History Quality Manager and Management Related Issues 9
N Requirements when moving locations - Class 1 Medical Device Manufacturer in the US Other Medical Device Regulations World-Wide 4
D AS9100 Shop Moving to a New Location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Moving On Coffee Break and Water Cooler Discussions 12
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
W Moving M&TE (Measuring & Test Equipment) to New Facility General Measurement Device and Calibration Topics 3
E Moving Window Test - Is this test about determining the Threshold Voltage? Quality Tools, Improvement and Analysis 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
R Moving to an Electronic System - Quality System Software Recommendations ISO 13485:2016 - Medical Device Quality Management Systems 5
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
L Validation Plan Requirements when moving to a new Plant - Medical Device Industry Qualification and Validation (including 21 CFR Part 11) 19
V Supplier Moving Manufacturing Location after original PPAP APQP and PPAP 4
P Statistical Sampling of Packaging Material Testing? Fast Moving Consumer Goods Supplier Quality Assurance and other Supplier Issues 4
