MS Windows XP Pro Hard Drive Defrag (defragmentation) question
Need some help. My PC is getting slower and slower on any task that is heavy on drive read time. I haven't defraged in about 5 years on a 5 year old XP Pro installation. (stupi me) I have about 20% free space and defrag works but seems satisfied to get the job 1/2 done. It reports leaving the drive 16% fragmented with hundreds of files still fragmented, some files exceeding a 1000 fragments. Performance is somewhat up. There are clearly still critical files severely fragmented. How do I get it to completely defrag the drive. I have tried :
regular mode,
safe mode, and
defrag c: -f , from a dos mode start.
I remember from the 80's (dos days) defragging and having it report 0% fragmentation at finish. Any ideas????
Marc
Fully vaccinated are you?
Re: Hard Drive Defrag (defragmentation) question
Defragentation is only a problem on older drives. Since you computer is old, it might help a bit. I know widows 2000 has a defragmentation option in the Get Info for the disk (Disk Properties > Tools tab). Upon restart it will defragment the drive.
But - You would probably get the most out of backing up your data, reformatting the drive and reinstalling your OS, programs and then your data. That clears out the registry and all the 'crud'.
Todays drives are so fast, not to mention cheap, that defrag doesn't do much speed wise. You might want to just put in a bigger hard drive while you're at it. I have an old (7 years?) PC here and that's what I did. I have windows 2000 on it and it's one of my 'house servers'. It's an old Compaq I bought used. The Cheech Wiz house server (scroll down near the bottom).
I tend to agree with Marc in that with the speed and size of modern drives, file fragmentation isn't the issue it once was. You might benefit from backing your data files, reformatting and reinstalling the OS. If you want to give defragging another shot, you can try Diskeeper free for thirty days and see if it helps--it's more thorough than the XP defragger (which is a crippled version of Diskeeper).
Madfox
Going way back, part of the problem might be with the TSR's. (? I believe that meant "terminated, still resident;" like a screen saver program.) So, begin with the control+alt+delete thing to get to the basic 6 or 7, I believe, processes you want to ensure remain active. (Due diligence caveat...find out which exact programs you don't want to end.) Then try the defrag.
But before then, do a "disk cleanup."
Madfox
Clausterphobic
Hello JBar,
I agree with the advises given so far but, i can't help notice when you mentioned that you have 20% free disk space. How much is your actual free disk space in megabytes? If i remeber it correctly, XP requires at least a hundered megabytes available anytime on your disk. Lower than that it performs slower and sometimes gives some error.
Suggestion: you might want to delete/uninstall files/programs that you are not using. then perform defrag. or better back-up your files, format hard drive and re-install OS.
Heavy drive read time means the computer is accessing your hard disk space since your RAM is not enough. this is true when you have a lot of programs running.
Suggestion: you might want to consider increasing your RAM. I have the same problem before. I have a P4 1.7GHz and 125MB memory. I can only run 1 applications at a time. when i run 2 applications it goes way too slow. :nope:
Also try scanning for adaware, spyware, or virus. These programs run on the background thus slowing down your computers performance.
:topic: Another thing is that anti-virus programs running on the background also contributes on slowing down your computer. but you would not want to disable it.:notme:
Hope this helps.
:bigwave: EMTT
You may need to run defrag several times (with the bare minimum of things running in the background) to get a decent result, but what you really need (apart from the previously given advice) is a new and bigger hard drive. 20% free space is in the realm where you can expect performance to start deteriorating.
/Claes
Coury Ferguson
Moderator here to help
Another option you could do is install a "Slave" drive. Keep all the required files in the Main Drive ("C"), like the OS and Office, and place the remaining files in the slave drive ("E").
I run two Hard Drives. My main hard drive "C" is 300 GB and my slave drive "E" is 40 GB.
Just another thought.
Madfox
That's also a good suggestion. "TSR" by the way (terminate, stay resident), is an old DOS term that no longer applies in actual multitasking operating systems. TSR was a type of system call devised to get around the pesky memory limitations of MS-DOS and gave the appearance of actual multitasking, but in actuality MS-DOS is/was only capable of dealing with one program at a time.
Very good advice, Claes. Anything over 50% full on even the most modern systems will begin to degrade hard drive performance on XP boxes, 80% full is going to make you crazy, no matter what size drive you have. You can get a blazing fast 320GB Seagate Barracuda 7200RPM IDE harddrive shipped to your house for US$95. (www.newegg.com). It's time to upgrade.
If you have the XP Pro Software, I would install a new Seagate as IDE Master, put your existing drive on as Slave, and do a clean XP install on the new drive, then copy only what you need from the old drive to the new, thus cleaning out the XP attic and gaining 320GB at the same time. If you don't have the install disc*, drive to drive imaging software is WAY cheaper than XP Pro.
MAKE A BACKUP OF YOUR CURRENT DRIVE BEFORE SWAPPING!
*Before I hear from the infringement crowd, currently most PC mfgs don't provide you with the wherewithal to do a fresh install these days. If you are lucky, you get a small "restore" partition on your main drive.
This might have been true on MS-DOS based systems (anything before Windows 98) but I operated on a ~80% populated system drive for nearly 5 years without any issues, and that was a 5400 RPM drive. When I replaced it with an 80Gb, 7200 RPM drive there was no discernible difference in performance. Heavy disk access is almost always a function of excessive paging, and the best strategy is usually adding RAM. ("Paging" refers to the OS using the hard drive as virtual RAM when actual RAM is limited, and it results in a lot of hard drive thrashing). One way to tell whether excessive paging is going on is by use of the free XP Page File Monitor.
You don't have to have XP pro in order to do this; it will work just fine on XP Home as well. Also, imaging isn't the answer because imaging creates a sector-by-sector copy of the original drive, and will copy all of the problems that might be there (including viruses, worms, adware and fragementaion) to the new one. If a clean install of the OS is desired, just data files should be backed up--there's no sense in backing up programs, including the OS, that will be reinstalled.
Usually, there's no pirating involved because what you've purchased is not the OS, but a license to use it. Thus if your original is an OEM copy (what was on the computer when purchased) you can legally use any OEM disk to reinstall. And most manufacturers do offer a full install disk, but you have to ask for it and pay a little extra for it. I know that HP, for example, has a history of supplying a full install disk if your drive has been trashed and you have no other way of restoring the OS. Under the MS OEM licensing scheme, OEMs are obligated to provide a method of restoring the as-purchased condition of the hard drive, thus the restore partition strategy. But the restore partition is useless if the hard drive crashes, so most OEMs will work with you on restoring the OS in such cases.
Jim Wynne Windows 11 is Coming--Is Your Computer Ready? Coffee Break and Water Cooler Discussions 16
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
G Windows 10 OS build Software Validation US Food and Drug Administration (FDA) 1
Claes Gefvenberg Windows 8.1 - Pros & cons, hints & tips. After Work and Weekend Discussion Topics 5
Jim Wynne Windows 8.1: No Security Updates Without Update 1 After Work and Weekend Discussion Topics 4
Marc Windows XP EOL scamware After Work and Weekend Discussion Topics 1
insect warfare IRS pays Microsoft for Windows XP support After Work and Weekend Discussion Topics 2
insect warfare Windows XP support ends today (April 8, 2014) After Work and Weekend Discussion Topics 2
T Will the End of Windows XP Support affect anything in AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K COTS Validation: Should we validate Windows after each Update? IEC 62304 - Medical Device Software Life Cycle Processes 3
G When to use a flyscreen on windows? Food Safety - ISO 22000, HACCP (21 CFR 120) 8
Jim Wynne Have you tried Microsoft Windows 8? After Work and Weekend Discussion Topics 25
Marc The "I am calling you from Windows" telephone scam After Work and Weekend Discussion Topics 13
Z Tutor For Windows--CMM Software--Is anyone familiar with it? Calibration and Metrology Software and Hardware 2
D Windows CE Operating System - Implantable Blood Pump and a Software Accessory Device IEC 62304 - Medical Device Software Life Cycle Processes 8
Stijloor Importing Address Books (Thunderbird and Outlook Express) into Windows Live Mail After Work and Weekend Discussion Topics 3
Marc 66% of All Windows Users Still Use Windows XP After Work and Weekend Discussion Topics 19
Stijloor Briefcase on Windows 7... After Work and Weekend Discussion Topics 29
S Google phasing out use of Windows over security concerns After Work and Weekend Discussion Topics 0
Claes Gefvenberg Microsoft Windows users: Which windows version are you using? March - April 2010 After Work and Weekend Discussion Topics 37
S Software changes (windows 2007 compatible) notification to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Jim Wynne February 2010 Windows Update Causes BSOD for Alureon Rooted XP Users After Work and Weekend Discussion Topics 8
J Google Offers Peek at Operating System, a Potential Challenge to Windows After Work and Weekend Discussion Topics 2
S Does Windows Service Pack (SP-3) upgrade need supplementary 510(k) submission?? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Marc FSF Attacks Windows 7's "Sins" In New Campaign After Work and Weekend Discussion Topics 1
F Is self-serve password reset for Windows considered for validation under CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
A If you use Magic Windows Professional SPC Software. Please Reply Quality Manager and Management Related Issues 1
Marc Cloning a Windows XP drive and Booting from a Firewire Clone After Work and Weekend Discussion Topics 4
DanteCaspian Looking for Windows Media Player Help After Work and Weekend Discussion Topics 3
bobdoering From MS: Guidance on Windows Deployments for Business Customers After Work and Weekend Discussion Topics 0
Stijloor Microsoft's Ballmer: Windows 7 is nearly final After Work and Weekend Discussion Topics 13
A Critical Windows Patch - All Version - 24 October 2008 After Work and Weekend Discussion Topics 6
Marc NNTP Usenet Readers for Windows - Suggestions and Reviews After Work and Weekend Discussion Topics 4
ScottK Safari for Windows is out today. After Work and Weekend Discussion Topics 9
Stijloor The 20 (Mostly Free) Downloads for MS Windows Computers You Can't Do Without After Work and Weekend Discussion Topics 2
Claes Gefvenberg Upgrading the Windows OS PC? After Work and Weekend Discussion Topics 29
B Which Quality system? Company produces aluminum windows - No automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Claes Gefvenberg So, how about Microsoft Windows Vista? After Work and Weekend Discussion Topics 85
Marc Vinyl Replacement Windows - 'Weeping' condensation at Glass / Vinyl Interface After Work and Weekend Discussion Topics 20
Marc CrossOver public beta: Allows Windows apps to run without Windows on Intel-based Macs After Work and Weekend Discussion Topics 0
Marc Another Windows Vista Feature Bites the Dust - PC-to-PC synchronization After Work and Weekend Discussion Topics 1
Marc Intel-Macs owners now have an official second OS option - Windows XP After Work and Weekend Discussion Topics 10
B Keeping your Windows PC running Smoothly After Work and Weekend Discussion Topics 18
Marc Extremely Critical Windows Security Hole - 29 December 2005 After Work and Weekend Discussion Topics 0
Marc Dell's Open PC Costs More Than Windows Box After Work and Weekend Discussion Topics 5
Q Windows vs. Linux - Just wondering if any Covers use or have tried Linux After Work and Weekend Discussion Topics 6
Marc What is the best 'Windows' laptop (notebook) computer? After Work and Weekend Discussion Topics 19
Marc Hackers Tune In to Windows Media Player - Two new Trojans After Work and Weekend Discussion Topics 4
Geoff Cotton MS Windows - Bagle-A Virus Alert - 18 Jan 2004 After Work and Weekend Discussion Topics 17
