MSA and Poison (Red Rabbit) Test
abdul42550
We are doing MSA Attribute on Appearance characteristics like Dent, Scratch, Dull Finish etc. at Pre Dispatch Inspection. Collect 20 pcs OK /NG as per norms with 3 Appraiser and 3 trials and calculate the Effectiveness, Miss Rate and False Alarm. Action initiated accordingly.
Another test is Poison test Selecting 100 pcs in which 10pcs of Not ok and offer to inspector as normal routine inspection and see the result and initiate the action accordingly.
My Question is What is the difference in MSA & Poison Test and Where to use MSA and Poison separately, Or both tools are alternate of each other for the purpose being used. Please help us to understand these. I appreciate in advance for your input.
Please explain what you mean by a "poison test." I have decades of experience with MSA, but have never heard of this poison test.
AMIT BALLAL
@Miner, it is also called a poison cake or red rabbit test. It is used to check the effectiveness of inspectors - mainly training effectiveness. It is done to check whether he/she is able to catch the defect.
The attribute MSA is used to quantify how well appraisers can agree on what good/bad as well as how well they can classify the various types of defects. % Agreement can tell you whether the test is any good, and Kappa scores can tell you where you need to provide better operational definitions and/or training for certain defects.
A Red Rabbit (or poison test) is more of an ongoing audit to detect whether the appraisers continue to perform as expected.
The attribute MSA should be done first followed by the periodic audit. If the audit shows an issue, you may want to repeat the attribute MSA to better determine the root cause.
abdul42550
Thanks for clarify one more key world A Red Rabbit and explaining the things.
A Nested ANOVA MSA - Excel sheet with bilateral tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H AIAG MSA: 4th Edition (Bias Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Attribute MSA with limited test samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
R MSA Multi System Correlation Capability, Accuracy and Stability - Processes, Machines, etc. 21
R MSA Type 3 vs Type 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
Q MSA requirements for IATF IATF 16949 - Automotive Quality Systems Standard 12
C MSA for resistance measurement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Part selection for Faro arm MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA on wire pull & ball shear Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S MSA annual plan Capability, Accuracy and Stability - Processes, Machines, etc. 5
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A MSA samples Preparation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N MSA Frequency related literature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A %AV=0 in the MSA GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M MSA - Dealing with inherent within-part variation in assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Ford Q1 MSA - Virtual Site Visit Hardware Manufacturing and Related Processes 14
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
E MSA Reference Manual 2nd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
W Medical Device - fixture qualification and MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Thermometers and Thermocouple or Transducer's require MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R MSA Studies for chemical analytical instruments in QC Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
Nihls MSA after the device move Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
