MSA for Destructive Tests - Tensile test as an example
O
omolina
Hi !. Does anybody out there know about MSA studies for measurements systems based on destructive tests.
O. MOLINA
Spaceman Spiff
As far as I know there is no MSA for destructive testing. However, when I went through with my Shainin training, they advocated the use of an ISOPlot. Sorry I don't have time to get into the technical aspect of it right now, but if interested, I can post more later.:bigwave:
N
Destructive MSA
If you think about MSA it makes perfect sense on destructive tests. Let's use a tensile test as an example. You can test both low an high strength samples so it seems to me that one would benefit from knowing if the tensile machine were exhibiting any deviations from linearity over its working range. Is a tensile test subject to seaonal variability in the electronics due to temperature and humidity or are any of the mechanical components subject to wear? In our case the answer is yes, so stability studies are most definitely appropriate. Are you always testing at the same strength level, if so linearity is not needed but bias(accuracy) must be known. Finally, there are most definitely methods for doing destructive R&R's. The only challenge to destructive MSA is getting working standards. These can be obtained by participating in an ASTM round robin test or the like. In our case, we have taken samples and annealed them to reduce variation in strength as much as possible. We pull one of these"master" samples at the beginning of every shift and plot them on an SPC chart. Using the standard SPC methodology it becomes immediately apparent if there is a potential problem with the tensile machine. Sure the load cells and the tensile machines are calibrated annually but that does not go far enough. You need confidence that these machines are working properly every day when you are certifying material. BTW, MSA is a hot topic at audit times these days so be warned!
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Method S4 Stability Study for Destructive Tests - MSA third Edition page 148 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S MSA for prototypes laboratories - What about Destructive tests? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W MSA for Destructive Testing - Tensile tester - Welding Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E MSA requirement for destructive Pull out test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA Study for tensile tester - Its difficult to do an MSA study on a destructive test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G How to conduct destructive measurement system analysis (MSA)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Destructive Test MSA's - Mechanical properties of adhesives Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
