MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab
cj80f
We are struggling internally if MSA is due also for non production area. We have labs for design validation, characterization and qualification. I checked many forums/articles and is always referring to production. Thanks to anyone helping.
Re: MSA for Non Manufacturing - Design Validation, Characterization and Qualification
Part of this will depend on any customer specific requirements that you may have.
The key question to ask and answer is whether any of the measurements or test results are used to make a decision regarding whether the quality of the product is acceptable. If they are used in that manner, an MSA should be performed.
You mentioned design validation. In my mind design validation test results are used to make a decision on whether that design meets requirements (i.e., is it acceptable?). In many cases that may be the last time that test is performed unless an engineering change is made, or it is done as part of troubleshooting a problem. Therefore, it is important and an MSA should be performed.
On the other hand, you may have test equipment that is strictly used for failure analysis that would not need an MSA.
cj80f
Thank you for the reply.
I agree on the added value of doing but I'm not understanding if the automotive standard is asking to have it mandatory as going thru the TS seems to be more production related.
Ninja
Looking for Reality
A thought (based on one of the ways I "use" GRR data)...
For a production area, GRR answers the question "Is my test technique adequate to tell good parts from bad?"
For design, or for analytical, the same approach can answer the "My technique is THIS accurate."
Instead of comparing your gathered data against spec range, or tolerance, or variation.....see what tolerance band gives you a result of "10".
Now you have a tolerance band finer than which you know you should start being cynical about your data.
If a customer proposes a spec range to me...I compare it to my "I can trust my test to here" number and I know what ballpark I'm playing in...
Not what MSA intended I figure...but a pretty useful tool for analytical methods. All in all, it's a good capture of what the noise level is.
HTH
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S MSA with Non Replicable Samples Measured at Detection Limit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Non-Replicable MSA when using digital multimeters or oscilloscopes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Miner Intro to MSA of Continuous Data – Part 6: R&R for Non-Replicable Measurements Imported Legacy Blogs 18
D TS 16949: 2002 section 7.6.1 - MSA non conformity at registration audit IATF 16949 - Automotive Quality Systems Standard 2
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
E MSA requirements for testers running software IATF 16949 - Automotive Quality Systems Standard 2
R ANOVA MSA GR&R in ATE replacing operators (Error Design is not balanced) Using Minitab Software 6
J Using MSA instead of calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA for wire crimp pull test. Lean in Manufacturing and Service Industries 0
A MSA for wire crimp pull test Lean in Manufacturing and Service Industries 1
T Attribute MSA-AIAG 4th How to calculate sample size IATF 16949 - Automotive Quality Systems Standard 12
A Nested ANOVA MSA - Excel sheet with bilateral tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H AIAG MSA: 4th Edition (Bias Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Attribute MSA with limited test samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
R MSA Multi System Correlation Capability, Accuracy and Stability - Processes, Machines, etc. 21
R MSA Type 3 vs Type 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
Q MSA requirements for IATF IATF 16949 - Automotive Quality Systems Standard 12
C MSA for resistance measurement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A MSA and Poison (Red Rabbit) Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Part selection for Faro arm MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA on wire pull & ball shear Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S MSA annual plan Capability, Accuracy and Stability - Processes, Machines, etc. 5
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A MSA samples Preparation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N MSA Frequency related literature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A %AV=0 in the MSA GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M MSA - Dealing with inherent within-part variation in assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Ford Q1 MSA - Virtual Site Visit Hardware Manufacturing and Related Processes 14
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
E MSA Reference Manual 2nd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
W Medical Device - fixture qualification and MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Thermometers and Thermocouple or Transducer's require MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R MSA Studies for chemical analytical instruments in QC Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
Nihls MSA after the device move Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
