MSA for titration
Hi Elsmar Users,
In our chem lab we are checking sulfuric acid concentration for anodazing process and using titration method to obtain density. After the density is obtained the acid concentration is calculated. Do you have any experience with conducting MSA study for titration?
Thanks in advance for your help.
Peter
William55401
This is a throwback question for me. (Chemical engineer-- took my fair share of Chem classes). For MSA, can you do a simple error analysis in a root mean square fashion? What measurements go into the calculation? Accumulate the impact using an RMS approach?
Alternatively, can you buy a standard off the shelf with a known concentration and density and then see how your in house lab results stand up? (Statistical test of differences. You will need some replication. You could do routine GRR here with multiple analysts / techs).
This is my first pass and I am sure those more in the know will refine this or completely blow it up. Have fun. Enjoy the ride.
Hi William55401,
Thanks for answer. Can you describe more detailed RMS approach? For the second approach you have mentioed (standard with a known concentration and density... how to measure this standard? At least 25 times and calculate bias? We have 3 operators in our lab. For GRR I need to have ca 10 parts taken in whole tolerance. Sorry, but I'm not familiar with chem methods like titration and don't know what is the best way to start up.
Once again thanks :)
Peter
William55401
Error analysis was done by estimating uncertainty in a given measurement. Running those uncertainties through the calculation and seeing the impact. It was an estimate not a true measure.
MSA principles, IMHO, would be applicable to titration. Buy a standard (an off the shelf solution of known assay-- you will probably have to pay extra for this to get the supplier to provide a cert of analysis that the sulphuric acid is X.XX % / molarity / molality / whatever. Have your analysts test that standard and see how close they get. Google is your friend. Read about titration Wet chem labs have many opportunities for error. Your MSA participants will have their own error rates / tendencies that will show up in the final results. You should be able to get a GRR as well as an accuracy to standard element. Which analyst had the most accurate results? Which had the least variation? Titration is adding one solution to another, at the end, in a drop by drop fashion, to get a color change when an indicator is triggered at a certain concentration. Some will overshoot; some may undershoot. Plan your statistics BEFORE sending your team to the lab. Have a pre determined analysis plan and, if possible, acceptance criteria for accuracy to the standard. Will you introduce equipment variation? Different pipettes? Scales? Glassware? Etc. Or, will you keep the equpment the same and focus on the operator / tester differences.
Hope this helps
This would be a non-replicable R&R study, which means that you need to use a nested study, not a crossed study.
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
