MSA Gage R&R - Destructive Test with One Sided Specification and One Operator
optomist1
A Sea of Statistics
Hi To All,
I've read several great postings especially Intro To MSA of Continuous Data, yet I do not find an answer to my dilemma;
I previously posted a open question regarding this process;
I am conducting the following test/inspection at the beginning and middle of each day or batch:
20AWG wire/terminal crimped connection, using a digital force gauge to assess the acceptability of the crimped connection. This is a destructive test, with a one sided spec (test result>13 lbs), and one operator.
I have yet to locate a suitable method to conduct such a test or analysis. Using Minitab's Gage R&R Nested design allows use of one-sided spec, yet how do I accommodate one operator? And how does one replicate wire/contact specimens that are destroyed?
Given this scenario, the reproducibility would seem to of no value...
Thank you for your assistance.
Regards,
Marty
optomist1
A Sea of Statistics
Good Day Miner,
Thank you for the input....unfortunately the link in comment #4 appears to be broken. I'll try again later. During the interim, do you know of another method to obtain this info?
I've read your great blog. yet none of these work arounds appears to be suitable. What am I missing....the tensile test destroys the specimen, and homogeneity of samples is anything but assured.
  • Split specimens
  • Consecutive specimens
  • Regression approach
  • Stabilized parts
Thank you again for your assistance.
Regards,
Marty
optomist1
A Sea of Statistics
Hi Miner,
This is a great resource....your blog is great. Yet I do not have financial resources or time to secure known value springs or similar loads. I will certainly keep this in mind for future application.
Thank you again for your assistance....
Marty
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Gage R&R Criteria on page 78 MSA Reference Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
C Gage R&R/MSA for PPAP - Our product has no variance Statistical Analysis Tools, Techniques and SPC 9
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
2 MSA when neither Nested nor Crossed Gage R&R is Applicable Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Runout Gage R&R - MSA on Roundness Tester - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
bobdoering Dr. Wheeler is back with his thoughts on MSA and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
E Gage Run Chart Analysis - Page 105 MSA manual 3th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA and Gage R&R for Measuring Microscope Capability, Accuracy and Stability - Processes, Machines, etc. 5
T Are MSA?s (Measurement System Analysis) Process or Gage Based? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
M Output of Nested MSA Gage R&R - Is this possible? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P AIAG SPC Manual (ver.1) Interpretations related to Gage R&R (GR&R) and MSA IATF 16949 - Automotive Quality Systems Standard 8
Q Internal Testing and Calibration Laboratories - MSA, Gage R&R and Control Plans IATF 16949 - Automotive Quality Systems Standard 2
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Significance of X chart in AIAG MSA sheet for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Z Determining how many measurement devices need gage R&R? MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
H MSA Excel .xls worksheet that includes GR&R (Gage R&R), Bias, Linearity, etc. Excel .xls Spreadsheet Templates and Tools 15
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D When is MSA (Measurement System Analysis) appropriate on a custom built gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z MSA - Gage R&R Study Analysis - SAMPLE - Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
R MSA and Gage Tracking Software that complies with MSA 3rd Edition Quality Assurance and Compliance Software Tools and Solutions 6
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K MSA 3rd Attribute GR&R (Gage R&R), no operators - Air decay test systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA (Attribute Gage R&R) on our process monitoring points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
