MSA - Hardness Measurements (Rockwell/ Brinnel / Knoop / Vickers) - How to?
krishkaar
MSA stands for " Measurement Systems Analysis" - a requirement referred both in QS 9000 and TS 16949:2002
Bill Ryan - 2007
We do a lot of testing for our semi-solid aluminum parts - almost all with the Rockwell scale. While I've gone through the excersize of a study, I've never submitted the results as they were pretty ugly (even though I used a test standard for the study). One of the reasons (I think) is that you are measuring an average for one point and (at least in our methodology) then measuring two more points and averaging all three of the averages for your "measurement" :eek: . That was a few years ago and I've not attempted another since.
I've not had a customer ask for a study on a hardness tester.
sakkapak
I think you mean non-replicable MSA.
According to MSA 3rd, it requires studies on Discrimination, Accuracy (Bias, Linearity) and Precision (GRR) for a variable gage system to make the system is suitable for a characteristic.
Since, Accuracy and Precision studies are based on repeatable measuring data, it is very difficult to conduct such studies on non-replicable system.
I always ignore Accuracy Study.
I focus on Precision (GRR) and try my best for that. Starting with Homo-genius and Hetero-genius assumption. Then, ANOVA GRR on the data.
Hardness Testing - MSA
We are a commercial heat treating facility registered to TS16949. For many years we have been able to "avoid" performing Gage R&R studies for hardness measurements under the guise that they are destructive tests in nature and it would be difficult to objectively perform such studies. My background is 25 years in the specialty steel business responsible for chemical and mechanical testing labs. Having gone through accreditation experiences to ISO Guide 25/ISO 17025 and NADCAP I have experienced creative ways to deal with the issue relating to Measurement Systems Analysis/Uncertainty of Measaurement and the like.
The primary issue from my experience with respect to Gage R&R specifically regarding hardness measurements is that the challenge is to avoid erroneously determining appraiser and equipment variation when in fact the most significant source of variation is in the material itself (speaking of ferrous materials).
We have started an MSA program where I require our calibration vendor to perform linearity and bias studies using NIST traceable test blocks during one of their quarterly calibration visits annually. We verify hardness testers daily with master test blocks to show stability compliance. I have started a program of Gage R&R studies using both test blocks and homogeneous sample parts. We purchase test blocks specifying that the variability (sigma and repeatability) is as small as possible. We will section off the test block into zones resembling a "test part" for each zone/section. The gage R&R is performed using both these test blocks where a measurement is made in each section by each appraiser over 3 trials. We will in parallel perform a Gage R&R using typical sample parts to differentiate between variation attributable to inhomogenous material and equipment appraiser variability. To date we have had encouraging results. We have performed this procedure for our Vickers and Knoop measurements and will begin a similar study on our Rockwell C and R15N scales.
I'd be interested in any comments, thoughts or suggestions that the group may have. I hope this helps.
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
M MSA - What method should we use for the stability of hardness? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA for Hardness Machine and Tensile/Compressive Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A MSA applicability for Hardness Testers - What type of MSA should be done? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
