MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture
SLEEPYMUM
Hi Folks,
I hope someone can give me their expertise on setting up an MSA on a multi cavity fixture (mold produces 16 parts per cycle, fixture then has 16 stations - 1 for each cavity, parts are measured on a CMM).
I have been trying to research this and I cant seem to find a standard to reference or exact guidelines that I should follow.
Am I right in saying that there are basic guidelines (AIAG), but I need to be able to justify my MSA to auditor?
My questions are:
Can I run a station to station to equivalency study to rule out any issues with my fixture before I complete my MSA (R&R), if so what sample size should I be looking at.
Once this is complete can I then run a normal MSA (3 runs by 3 ops by 2 samples (2 samples of 16)?
Or should I be looking at this differently?, are there any guidelines I should be referencing?
The plastic components are consumer goods (not medical components), would this make a difference,
Thanks in advance for any help offered.....
If the CMM is DCC, you should be able to treat the multiple fixture stations as operators. Reproducibility would represent station to station variation. If the CMM is manual, you should use an expanded R&R study to include this variation in addition to the operator variation.
M Kindly help me to understand MSA Acceptance Level Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Help with my first MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
L MSA in Automatic Equipment - PCB Assembly - Help! Quality Tools, Improvement and Analysis 6
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
B How to do the Control Plan and MSA - Student needs help FMEA and Control Plans 6
P Conducting a MSA - Measurement of plaster by use of a scoop - I need Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
E MSA Reference Manual 2nd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
W Medical Device - fixture qualification and MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Thermometers and Thermocouple or Transducer's require MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R MSA Studies for chemical analytical instruments in QC Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
Nihls MSA after the device move Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 10
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 2
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
