MSA - Is Measurement Systems Analysis required in R&D? TS 16949 Clause 7.6.1
bobdoering
Stop X-bar/R Madness!!
#12
Even for basic research which is governed by GLPs, i think there are definite requirements in place for controls/evaluation of compliance of equipments.
I would hope so. I think it is important to understand that even though the standard may not require MSA on R&D, it just makes sense - even more so in medical. The medical ISO standard is not quite as rigorous as the automotive standard. But for both standards, not including any process that uses measurement systems to make decisions (design decisions - even for recipes) is just poor judgment. On top of that, in medical your liability can exceed the ISO standard, so pointing at it and saying it does not require it may not hold up in later disputes.
Please, do not get caught up being a standards minimalist (Quality Level TCE)...put the right processes in place for your firm. :tg:
K
Kevin H
#13
From a quality system view point does it really make sense not to pursue a rigorous MSA and calibration program within a research facility whether it's pharma, food, aotomotive, aerospace, or any other type of research? Over the years, I have run into research engineers/scientists (not many, but 1 is too many) who kept there personal measuring instruments outside of calibration systems and made dmeasurements during development research because "their measurements came in".
Funny, the process never seemed to work in real life when the item in question wasn't measured by them with their "unique" measuring instrument. :rolleyes:
K
kat.k.
#14
Required? Probably not. Worthwhile? One would think so. After all, don't you make decisions based on your measurement equipment? How do you answer if your gages are the right ones for the work you are doing? I hope you do not use the traditional urban legend approach that was popular on the shop floor...
Out of curiosity, what do you mean by "traditional urban legend approach that was popular on the shop floor"?
I am a calibration supervisor for an auto parts maker. We follow the TS 16949standard. I have been asking the same question you asked - "How do you answer if your gages are the right ones for the work you are doing"? If an auditor asked me this question, I wouldn't have a good answer. For standard gages such as calipers, we will do an R&R just checking an O.D. It passes with flying colors. When we issue them out to the shop floor, we don't know how they are going to use them. We have ran accross production checking an O.D. chamfer with the inside jaws of calipers, which is just crazy. This is what engineering listed on the control plan.
We got nailed on our first TS audit for not calibrating our depth rods on calipers. Two Quality Managers got together and decided to remove all the depth rods and inside jaws from calipers because it's hard to get all three mechanisms to calibrate every year.
Do you have any suggestions:
On how to control how the gages are being used on the shop floor?
How to calibrate & use calipers without removing half the parts just to use the outside jaws?
Thank you
Kat.k.
bobdoering
#15
Here are a couple urban legends:
1. If the gage reads in the increments of the tolerance, it is good enough (e.g. if a caliper reads in .001" increments, you can use it for a .000 - .003" tolerance)
2. The micrometer is the best gage for anything. (Actually, it can be the worst - you can get any answer you want if you crank it a little more. Is has chronic bias and gage pressure issues)
Neither of these - or similar urban legends - are supported by any MSA approach. But, they still live on...
To answer the question "How do you know if it is the correct gage for the job?" you provide a correctly prepared Gage R&R. To answer the question "How do you know the gage is still reading correctly?" you provide calibration information.
When we issue them out to the shop floor, we don't know how they are going to use them. We have ran across production checking an O.D. chamfer with the inside jaws of calipers, which is just crazy. This is what engineering listed on the control plan.
I agree, that approach would not likely fare well if the question had been answered with a gage R&R of that approach with that dimension, I suspect.
:jawdrop: (first time I used this smilie...rightfully so...)
If the depth rods are used for shop floor measurements - especially if they were called out on the control plan - then they need calibrated. If not, a note that they are not used in the calibration record, and training records that the operators have been told not to use them, should be sufficient.
Wow. I really do not understand the approach they used to eliminate their "problem." It is not that hard, unless they are using the gages for can openers. And, how many hundreds of these calipers do you have to calibrate to make it an issue?
Make sure the operators are trained on how to measure with the device.
Have the supervisors supervise the operators.
Last resort: make the operators pay for damaged gages.
I am right up there with the next guy on picking your battles, but this seems pretty extreme. I have seem some rude stuff - like people using the castings of a snap indicator to pound steel rule dies back into their backing boards...but...you really got me on this one! :nope:
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Measurement Systems Analysis (MSA) for Trading Industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA (Measurement Systems Analysis) Process template - ISO TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Any MSA (Measurement Systems Analysis) classes in the Chicago area? Training - Internal, External, Online and Distance Learning 1
kedarg6500 MSA (Measurement Systems Analysis) Fourth Edition Excel Sheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Alan Miner's Measurement Systems Analysis (MSA) Blog Article Series Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S AIAG MSA (Measurement Systems Analysis) Manual 3rd ed. Chapter IV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) for Idiots - Software Quality Assurance and Compliance Software Tools and Solutions 6
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
B MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q MSA (Measurement Systems Analysis) Internal Audit checklist vs. TS 16949 Internal Auditing 4
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Information about MSA (measurement systems analysis) software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Fish Oil Capsule Weight MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Is MSA (Measurement Systems Analysis) only required for SC characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Format / Template of all MSA (Measurement Systems Analysis) studied Document Control Systems, Procedures, Forms and Templates 3
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
U How to do MSA (Measurement Systems Analysis) - I need to know the basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA (Measurement Systems Analysis) for Visual Standards? IATF 16949 - Automotive Quality Systems Standard 3
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Measurement Systems Analysis - Effect on Process Decisions - MSA Manual page 19 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Measurement Systems Analysis) Positional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A How do i start implement MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Question Regarding MSA (Measurement Systems Analysis) - Pass / Fail Criteria tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
