MSA (Measurement System Analysis) on a Photospectrometer
mcammaert
Dear members,
I was wondering if it is possible/useful to conduct a MSA/GR&R on a photospectrometer used for color measurements (L*,a*,b*) of plastic parts.
If yes, could somebody explain me how to conduct this MSA?
Thank you in advance for your help!
Best regards!
Ninja
Looking for Reality
Re: MSA on photospectrometer
Hello mcammaert,
Welcome to the Cove :bigwave:
Lots of previous posts on GRR of just about anything...you might want to do a search on the forum.
That said, a photospectrometer is a tool.
You want to do your study on the test method.
There is a huge difference between the two.
How you use the tool likely imparts more variation than the tool itself.
Test your test method the same way as you would test your dimensional tests...(not the tool, the test method).
Have multiple operators test multiple parts multiple times and compare the results.
Ron Rompen
Yes, you can perform a GR&R study on your photospectrometer - this would be done in the same way as any measuring instrument (i.e. 3 operators, 10 parts, 3 measurements per operator per part). HOWEVER because of the nature of the instrument you need to take special steps to ensure that your test series is valuable.
Ensure that there is a clearly-understood written instruction on how to measure the sample parts - particularly regarding what location, and how to use the instrument. Ensure that the lighting conditions for the test series are the same (ideally you would want to do this in the lab, to minimize variation). Between each measurement, the part surface should be cleaned of fingerprints and accumulated dust/dirt (this process also needs to be in the work instruction).
Now you need to determine WHICH value(s) you want to calculate your GR&R on - L a b doesn't really mean much, what you are really looking at is either your deltaE or deltaEcmc. I don't know what your customer accepts as a variance, but that value would be your 'tolerance band' for measurement.
Hope this is of some help. I am also in the painted plastics industry (automotive components) so if I can be of any more assistance, don't hesitate to contact me directly here, and I will do what I can.
Be alert to the possibility of within part variation in the results. While this is a legitimate part of measurement variation is is also somewhat controllable by the measurement method.
mcammaert
Dear cove members,
Thank you for the replies you already provided. They are very helpful.
It is clear for me now that is is useful to conduct a MSA (GRR) on the photospectrometer while following the instructions described in the Work Instructions. It is actually about color measurements of plastic parts for automotive purpose. I would like to ask my supplier to deliver some MSA results (because of some color mismatch problems) but since it seemed like they never conducted a MSA in the past, I was thinking if it was indeed useful to ask.
To go a little bit more into detail, especially for the comments that Ron Rompen had.
I would actually use L*,a* and b* values to calculate my GRR. It seems strange for me to use deltaE or deltaEcmc values because you are including the variance of the reference part and the variance of the actual part you are measuring.
My customer has only tolerances for deltaL*, deltaa* and deltab*.
What are your opinions about this?
Best regards!
Ron Rompen
Your customer does, as always, have the final say in what they want, however if you are evaluating L, a, and b you are now evaluating 3 separate characteristics of your gauge, and the potential for failure is increased. In our plant, we report the 3 values, (L, a, b) but the final determination of 'good' or 'bad' is based on deltaEcmc.
As for your supplier providing results, I would be very surprised if they have not conducted GR&R studies in the past (presuming they are a manufacturer of the paint you are purchasing, and not just a distributor). We deal directly with one supplier, who is also registered to ISO 17025, and have that type of information readily available.
N
notadog
That doesn't look like anything that I would want any part of. Thank you for your quick response.
Ron Rompen
Please define (L, a, b)?
L = Lightness or darkness
a = hue or color
b = saturation or shade
It is a standard method of mathematically describing a particular color. Based on a concept devised by Munsell many years ago.
That is the basics of it, as was posted afterwards, you can go on the CIELab website for much more information if you are interested.
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M How to Stack for MSA (Measurement System Analysis) in Minitab? Using Minitab Software 1
V Is MSA (Measurement System Analysis) required for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Linearity Problem (MSA - Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Weighing Scale MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q MSA Studies on each Equipment, each Measurement System or Family in Control Plan? IATF 16949 - Automotive Quality Systems Standard 35
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Measurement System Assessment (MSA) - Water Crackle Test General Measurement Device and Calibration Topics 2
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
S MSA (Measurement System Analysis) for Medical Device Manufacturers Other US Medical Device Regulations 3
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Width and location errors in MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Measurement System Analysis (MSA) Procedure template Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 11
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 4: Stability Imported Legacy Blogs 2
