MSA (Measurement Systems Analysis) in Chemical Processing
Darius
#11
answering customer in the CpK and MSA study. 1 day we only produce 2 batch and chemical itself quite sensitive to the heat. pH or viscocity will be varies when chemical temperature raise up or down.
The Cpk for the customer must reflect the final product properties. You can meassure the pH or viscocity at the end of each batch (atemperated to a certain temperature if needed), that's what the customer must worry about (variation of the end product properties).
Note: if the viscocity and pH depend on temperature, you can obtain the viscocity (and pH) at a certain temperature with regression analysis and chart if needed the "atemperated" values to a SPC chart.
To conduct an MSA,
* Take some samples (it will be better if are taken from different batches and in different steps of the process <maximize different values of pH / viscocity>)
* divide the samples in several subsamples ( to say something; 5 for each lab operator)
* identify the subsamples so the operators don't know from wich group is each subsample.
* test each subsample by each operator
desqae
#12
HI All
Thanks for the info. I had trial it and post it here. I'm wondering, due to production might run different type of product everyday, should i take the data as 1 day production or let it continue roll until 30 data complete (it might take 1-2 months time to fill up).
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Measurement Systems Analysis (MSA) for Trading Industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA (Measurement Systems Analysis) Process template - ISO TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Any MSA (Measurement Systems Analysis) classes in the Chicago area? Training - Internal, External, Online and Distance Learning 1
kedarg6500 MSA (Measurement Systems Analysis) Fourth Edition Excel Sheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Alan Miner's Measurement Systems Analysis (MSA) Blog Article Series Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S AIAG MSA (Measurement Systems Analysis) Manual 3rd ed. Chapter IV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) for Idiots - Software Quality Assurance and Compliance Software Tools and Solutions 6
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
B MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q MSA (Measurement Systems Analysis) Internal Audit checklist vs. TS 16949 Internal Auditing 4
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MSA - Is Measurement Systems Analysis required in R&D? TS 16949 Clause 7.6.1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Information about MSA (measurement systems analysis) software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Fish Oil Capsule Weight MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Is MSA (Measurement Systems Analysis) only required for SC characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Format / Template of all MSA (Measurement Systems Analysis) studied Document Control Systems, Procedures, Forms and Templates 3
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
U How to do MSA (Measurement Systems Analysis) - I need to know the basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA (Measurement Systems Analysis) for Visual Standards? IATF 16949 - Automotive Quality Systems Standard 3
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Measurement Systems Analysis - Effect on Process Decisions - MSA Manual page 19 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Measurement Systems Analysis) Positional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A How do i start implement MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
