MSA (measurement systems analysis) on several CMM's - Correlation issue
Scary Bird
Good day to you all ;)
Here’s my problem: We currently use 2 CMM’s on site to measure aerospace fan blades. We then ship the blade to our customer at another location; they are also part of our company. As the foot of the blade is a critical area to them they re-measure the blade on their CMM. Our results are no were near theirs, so we have a correlation issue. None of the CMM’s in question have had an MSA conducted. What’s the best way to proceed? Also this is a new product with its own unique challenges.
Conducting an MSA on 3 CMM’s, taking 10 blades measured twice by two operators for each machine would be a huge resource issue, and for two of the machines we would be able to have the machine for that length of time.
Another factor to throw into the pot is the way the blade is located on the CMM, our site and our sister site (customer) are different.
One person has suggested that we take an artefact and each site measures it a couple of times per operator and then analyse the data using nested Anova. Would this show repeatability and reproducibility to a statistically significant level to allow us to have confidence in the results?
Really, what would be the best way to proceed without doing a full-blown MSA on every CMM, but giving us the confidence in the results of the machine?
Thanks for your assistance.
:whip:
I see your problem. Let's start with some questions:
Could you providee us with some data on what is being measured and how?
Are the CMM's in question identical? Model, manufacturer, software, and so on... They all have their quirks, particularly when it comes to software. Machines from different manufacturers may very well evaluate identical data differently, and in some cases even incorrectly. Manufacturers do cut corners when they develop software, and they may be using different formulas. This is particularly evident in the case of form and position tolerances.
The operators present another obvious potential for differing results. They may measure the same thing in two different (but correct) ways and come up with different results. The way the blade is located on the CMM is one example of such differences. Have the operators been able to meet and discuss this? There is a fair chance that that would sole your problem.
Could the transport affect the product? It's been known to happen...
/Claes
David Hartman
Do your drawings use GD&T dimensional standards (it seems to me that this would limit some of the variances in measurement methods)?
bmccabe - 2006
We have the same issues here. My solution is that we make a surveillance master and perform an anova on it, from each machine. I set the tolerance for the measurements at 1.3X (allowing for a 6sigma curve to fit therein) the OEM’s published performance specs.
[Here we measure such things from a program, and have concluded the operator has no influence on the performance of the gage by pressing the run button. I mention this because the anova will attribute some error to operator – And this variation is actually a “form error”, on the part.]
If the anova fails, the field tech is called to calibrate the machine. If it passes – We establish processes capability by re-measuring the artifact (surveillance master) at regular time intervals, and plotting the results on a pre-control chart. The spec limits for the pre-control chart were set at 1.7X OEM specs (allowing for process drift, and reducing the tendency to over-react to normal variation.).
When the control chart violates one of the “rules”, we re-calibrate. In the meanwhile, we document the systems ability to perform within specifications, and archive the data in the SPC database.
I know this seems like alot of work, but so far, it's proven robust. Hope it helps.
r/b
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Measurement Systems Analysis (MSA) for Trading Industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA (Measurement Systems Analysis) Process template - ISO TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Any MSA (Measurement Systems Analysis) classes in the Chicago area? Training - Internal, External, Online and Distance Learning 1
kedarg6500 MSA (Measurement Systems Analysis) Fourth Edition Excel Sheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Alan Miner's Measurement Systems Analysis (MSA) Blog Article Series Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S AIAG MSA (Measurement Systems Analysis) Manual 3rd ed. Chapter IV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) for Idiots - Software Quality Assurance and Compliance Software Tools and Solutions 6
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
B MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q MSA (Measurement Systems Analysis) Internal Audit checklist vs. TS 16949 Internal Auditing 4
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MSA - Is Measurement Systems Analysis required in R&D? TS 16949 Clause 7.6.1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Information about MSA (measurement systems analysis) software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Fish Oil Capsule Weight MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Is MSA (Measurement Systems Analysis) only required for SC characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Format / Template of all MSA (Measurement Systems Analysis) studied Document Control Systems, Procedures, Forms and Templates 3
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
U How to do MSA (Measurement Systems Analysis) - I need to know the basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA (Measurement Systems Analysis) for Visual Standards? IATF 16949 - Automotive Quality Systems Standard 3
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Measurement Systems Analysis - Effect on Process Decisions - MSA Manual page 19 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Measurement Systems Analysis) Positional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A How do i start implement MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
