MSA (Measurement Systems Analysis) Positional Tolerances
bernchan
I'm stuck, can't figure out how do to this..
I have a machine that measure a component and then as a result gives what shim is needed to obtain the wanted result.
The components can vary from 600 to 900 micrometers. But as long as the correct shim is chosen by the system that does not matter.
Say that the tolerance would be +-1 shim(+-12 micrometers), how would I conduct an MSA on the gauge?
I did a "normal" Gauge R&R which gave a result of 30% study variation, that does not really mean much though..how can I set the tolerance? If I set the tolerance to 24 micrometers the part to part variation would be about 1000% which is to little use..
Would appriciate your help!
/Mike
Marc
Re: MSA Positional Tolerances
Anyone with any thoughts / information on this question?
To do the study "right", you should break it into two sections.
First, perform a variable MSA on the actual measured values obtained by the machine, not on the shim selected.
Second, validate the software by performing an attribute MSA on the machine's selection of a shim based on that measured value. That is based on the measured result, did it select the correct shim.
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Measurement Systems Analysis (MSA) for Trading Industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA (Measurement Systems Analysis) Process template - ISO TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Any MSA (Measurement Systems Analysis) classes in the Chicago area? Training - Internal, External, Online and Distance Learning 1
kedarg6500 MSA (Measurement Systems Analysis) Fourth Edition Excel Sheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Alan Miner's Measurement Systems Analysis (MSA) Blog Article Series Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S AIAG MSA (Measurement Systems Analysis) Manual 3rd ed. Chapter IV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) for Idiots - Software Quality Assurance and Compliance Software Tools and Solutions 6
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
B MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q MSA (Measurement Systems Analysis) Internal Audit checklist vs. TS 16949 Internal Auditing 4
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MSA - Is Measurement Systems Analysis required in R&D? TS 16949 Clause 7.6.1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Information about MSA (measurement systems analysis) software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Fish Oil Capsule Weight MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Is MSA (Measurement Systems Analysis) only required for SC characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Format / Template of all MSA (Measurement Systems Analysis) studied Document Control Systems, Procedures, Forms and Templates 3
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
U How to do MSA (Measurement Systems Analysis) - I need to know the basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA (Measurement Systems Analysis) for Visual Standards? IATF 16949 - Automotive Quality Systems Standard 3
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Measurement Systems Analysis - Effect on Process Decisions - MSA Manual page 19 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A How do i start implement MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Question Regarding MSA (Measurement Systems Analysis) - Pass / Fail Criteria tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
