MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers
bpillar
Hello, :bigwave:
I'm quite in trouble to understand which kind of MSA study I can perform in our metrology, considering only one operator that works using a CMM or common callipers. Can someone help me to choose the right method and suggest me a worsheet to perform it? :truce:
Thanks a lot.
Regards.
:thanx:
Re: MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Callip
Are you only interested in the repeatability and bias of the gage?
This is a Type 1 Gage study. See Rationale and Methodology for the Type 1 Gage Study from Minitab. If you do not have Minitab, you can analyze bias and repeatability using the file attached to my blog entry on MSA Part 3. See row 43 of the Stability tab.
bpillar
Thanks a lot for your answer.
I think that study Type 1 is the right one, considering only one operator.
I'll try to perform the study using your excel worksheet (I know Minitab, but we haven't got any license).
Is it certified and conform to AIAG MSA 3rd edition? This only to be sure if I present it to ISO/TS certification body.
Thanks again.
bpillar
:applause::biglaugh:
The R&R section of my spreadsheet was validated against the Ford SW validation data set. I am not aware of a validation data set for the stability sheet.
Please note that my spreadsheet was not initially designed to be a Type 1 study, so it may not provide the exact same results. I will try to find the time to run a data set through Minitab's Type 1 study and the same data set through mine for comparison purposes.
I can confirm that the calculations are the same as those shown in the MSA manual, 3rd edition for estimating repeatability using a stability study.
Re: MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipe
I ran a comparison between Minitab's Type 1 study and the estimate of Repeatability in my spreadsheet.
The calculation of bias is identical as is the test used to determine significance. The main difference lies in the calculation of the repeatability standard deviation.
Minitab calculates the overall standard deviation of the entire set of measurements. My spreadsheet calculates the standard deviation based on the subgroup ranges.
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
C MSA (Measurement Systems Analysis) Case - A little help? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Measurement Systems Analysis (MSA) for Trading Industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA (Measurement Systems Analysis) Process template - ISO TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Any MSA (Measurement Systems Analysis) classes in the Chicago area? Training - Internal, External, Online and Distance Learning 1
kedarg6500 MSA (Measurement Systems Analysis) Fourth Edition Excel Sheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Marc Alan Miner's Measurement Systems Analysis (MSA) Blog Article Series Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S AIAG MSA (Measurement Systems Analysis) Manual 3rd ed. Chapter IV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) for Idiots - Software Quality Assurance and Compliance Software Tools and Solutions 6
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q MSA (Measurement Systems Analysis) Internal Audit checklist vs. TS 16949 Internal Auditing 4
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MSA - Is Measurement Systems Analysis required in R&D? TS 16949 Clause 7.6.1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Information about MSA (measurement systems analysis) software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Fish Oil Capsule Weight MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Is MSA (Measurement Systems Analysis) only required for SC characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Format / Template of all MSA (Measurement Systems Analysis) studied Document Control Systems, Procedures, Forms and Templates 3
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
U How to do MSA (Measurement Systems Analysis) - I need to know the basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA (Measurement Systems Analysis) for Visual Standards? IATF 16949 - Automotive Quality Systems Standard 3
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Measurement Systems Analysis - Effect on Process Decisions - MSA Manual page 19 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Measurement Systems Analysis) Positional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A How do i start implement MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Question Regarding MSA (Measurement Systems Analysis) - Pass / Fail Criteria tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
