suhananyc
Hi all,
Need some input on my enquiry below
My process is to repair aircraft blades. The blades have different stages (example stage 1-7) and the blade at different stages vary in size. When we measure at different stages we will be using different fixtures. My questions are as below
1) Do I select the parts based on process variation or product tolerance?
2) If I select to do on product tolerance, do I have to do the GRR on all the different stages since different stages uses different fixtures? Or can I just select one range to do and just do a linearity test for the other stages?
