MSA on Part Specific Attribute Fixtures
jackerman64
Corp Quality Sys *****
We do MSA studies by gage "type".
For example: One R&R for all 6" calipers, One R&R for all 12" calipers etc
In my past experience (24 years), an R&R has been performed on each individual custom check fixture.
However, in my past, the parts were very different from each other and the custom fixtures were a combination of attribute and variable measurements.
Our QM is challenging that although the various check fixtures we have are part specific, they are still 1 gage type because they all function the same and measure the same type of part. For example, a LH wheel well splash guard and a RH wheel well splash guard and also for various vehicle models)
They are all attribute fixtures. A part is laid on the base and and then clamped. Stab pins ensure proper position. A profile site line is visually checked around the perimeter of the part and various plugs are used to check hole sizes.
Would you consider this one gage type?
In my past I would have said no but I'm trying to be open and explore the possibility that perhaps my trainer misinterpreted the requirement.
Your thoughts?
Ninja
Looking for Reality
My two cents...not sure there is a "right" answer.
I would remove the concept of "gage type" from your thinking...you have a TEST METHOD, not a gage.
When running a GRR, I would test the same characteristic, "A profile site line is visually checked around the perimeter of the part" using the various calibrated fixtures used in that test method(s). Same with plugs.
You use a set of plugs to measure hole size. That's a test method you are verifying via GRR. Right or left is immaterial.
You use a set of fixtures to measure (a profile shape?). That's a test method you are verifying by GRR. right or left is immaterial.
If you are looking at ensuring your TEST METHOD is adequate, many of your finer distinctions disappear...and life gets easier for all.
howste
Thaumaturge
Assuming we're talking about IATF 16949 here, this is the relevant text of the standard:
Clause 7.1.5.1.1 said:
Statistical studies shall be conducted to analyze the variation present in the results of each type of inspection, measurement, and test equipment system identified in the control plan.
Since the standard uses the word "type" of system it's hard to remove that word from our thinking in this case. Is a type of inspection/measurement/test system the same as a test method? Maybe. I would at least think that right-hand and left-hand fixtures that mirror each other would be the same type.
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
L MSA - Stability - Part of our PQ (performance qualification) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Miner Advanced MSA of Continuous Data Part 4: How to Sample Parts Imported Legacy Blogs 2
Miner Advanced MSA of Continuous Data Part 3: Are 3 Operators or 2 Replicates Enough? Imported Legacy Blogs 0
Miner Advanced MSA of Continuous Data Part 2: Are 10 Parts Enough? Imported Legacy Blogs 0
M Using an earlier MSA on a different but similar part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA with Inadequate Part Variability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Dealing with Excessive Within-Part Variation when doing MSA and Cpk studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Advanced MSA of Continuous Data - Part 1: Within Part Variation Imported Legacy Blogs 4
Miner Intro to MSA of Continuous Data - Part 10: Creating gauge families Imported Legacy Blogs 10
Icy Mountain TS 16949 Requirement for New MSA for Identical Replacement Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Miner Intro to MSA of Continuous Data - Part 9: %Tolerance for One-sided Specs Imported Legacy Blogs 3
Miner Intro to MSA of Continuous Data – Part 8: Comparison of Two Gages Imported Legacy Blogs 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Miner Intro to MSA of Continuous Data – Part 6: R&R for Non-Replicable Measurements Imported Legacy Blogs 18
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 5
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 4: Stability Imported Legacy Blogs 2
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 3: Linearity Imported Legacy Blogs 15
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 2: Bias Imported Legacy Blogs 4
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 1: What and Why? Imported Legacy Blogs 22
B Operator*part interaction - AIAG MSA manual indicates ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N MSA - How do I perform a Stability Study as a part of Measurement Systems Analysis? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
