SBS - the best value in QMS software
MSA requirement for 5 Micrometers + CP changes need customer approval?
I am working on matching the Control Plan details with the Equipment/gages to be used and document simplifications. My questions are:
1. I have 5 sets of Micrometers. This set can be used interchangeably by our 3 inspectors during In-process and FQC. Am I required by IATF16949 or VDA6.3 standards that each of the 5 micrometers for the same Part Number and characteristics needs individual MSA / GR&R study?
2. Previous Engg team had submitted the PPAP package with CP- Control Plans, Process Flow, FMEA, etc. to our customer. When we reviewed the control plans, there were several steps inside that reflects how the raw material is undergoing the step-by-step machining process inside the CNC machine considered as "sub-process" (chasing, turning, drilling, chamfering, etc). Each sub-steps, as per submitted CP, needs taking off samples for the dim & vis monitoring that required impractical stopping the process to get samples from inside the machine. However, the final piece coming from the said CNC machine is the final dim outline of the finished product (except Washing and FQC steps) which is more critical to the Customer application. We recognized this "mistake" of over-documenting this impractical steps within the CP.
Now, we simplified the CP reducing from 17 steps to 10 steps. Do we need customer final approval before execution of the CP and documents alignment? Same Material, Same Machine, Same Process, Same Set of Operators, Same Production Line environment, except the documented CP unnecessary steps were deleted.
Your valuable inputs and sharing of experiences are more than welcome.
Best regards,
Iman
1. Quote from IATF 16949 FAQ 2018 :
A complete statistical study on each single piece of equipment is not required. Instruments with the same characteristics (e.g. measurement range, resolution, repeatability, etc.) can be grouped and a sample instrument (representative of the gauge family) can be used for the statistical study.
2. IATF 16949 par. 8.5.1.1 :
If required by the customer, the organization shall obtain customer approval after review or revision of the
control plan.
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Requirement to complete an MSA when doing Comparative Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
J CMM MSA - Can you use 1 GRR to satisfy requirement for all Key Features? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
Icy Mountain TS 16949 Requirement for New MSA for Identical Replacement Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P ISO/TS16949 MSA Requirement for Product Testing - Gloss and Grain Pattern IATF 16949 - Automotive Quality Systems Standard 3
E MSA requirement for destructive Pull out test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Measurement System Analysis (MSA) - Requirement to also do gage stability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 8
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
