MSA results on % Tolerance charts
Stuart Andrews
Involved - Posts
We conduct our MSA studies and compute the results on a % Tolerance chart that looks very similar to the % Total Variation charts.
However, I have now fully read and understood the MSA manual, second edition, and it doesn't mention a calcualtion based on tolerance.
Does anybody know what grounds I have for using this calculation because I do get more acceptable gauge results using this calculation.:confused:
Al Dyer
Should a gage be measured against the tolerance when the tolerance has no bearing on the gage?
Ryan????????????????
Ryan Wilde
Here is where my ignorance becomes readily apparent...
I have no idea what an MSA study entails, except what I have gleaned here. I don't actually do any of the QS9000 stuff, I have strictly worked in the calibration arena for some 17 odd years.
But...
From what I have learned (possibly mistakenly) an MSA is the study of a measurement system including short-term variation, drift, etc. In this case, the tolerance of the gauge has absolutely no bearing whatsoever. What does have bearing is the absolute error (bias ± the uncertainty of the gauge), its repeatability (short-term), its drift (those yearly calibrations, with data, on a spreadsheet gives a great baseline), the effect of your specific environment extremes on the gauge (I've been in shops with 39°C seasonal temperature swings and they have no idea why they have problems measuring aluminum), and variation between the petite guy that is oh-so-careful and Gunther-who-uses-a-micrometer-like-a-c-clamp.
General rule of thumb in metrology - measurement is measurement, and tolerance is analysis after the measurement process. Tolerance is not a gauge attribute, it is a (sometimes arbitrary) number a design engineer figured his/her gauge should be able to meet (and possibly even meet over time) when compared to the oh-so-elusive absolute "nominal".
So, on a good note, if your gauge variation as a percent looks just like your total process variation, you have a mighty fine process.
In other words - I use tolerance for 3 things. First, it gives me boundaries for computing the recall cycle of a gauge. Second, it allows me to take a gauge's reading as gospel if the tolerance is sufficiently small compared to what I am testing. Third, it tells me when to adjust/repair/replace a gauge, which means my company makes more money and can give me raises. ;)
I don't know Stuart's application, so it is hard to say if % tolerance gives any indication whatsoever. But, if total allowable deviation of a gauge is specified in the quality system as the same as the tolerance, it would be a very good indication of gauge condition and drift.
I hope I wasn't entirely off-base, as I've never needed to look at an MSA manual. I just have to do those uncertainty studies.
Ryan
Atul Khandekar
My interpretation
MSA studies are conducted primarily to determine if a given instrument is suitable for measuring a certain part. Afterall measurements taken with this instrument will be used for SPC analysis. So MSA studies determine the suitability of an instrument for monitoring and controlling a process. You check the bias, discrimination, stability over time and R&R etc.
The first thing to do is to analyse Appraiser and Equipment variation and correct the problems if any in measurement method, fixturing etc.
There are occasions when your %R&R ( R&R error as a % of Study variation) cannot be brought below 10%. This can also happen if your Process Capability is high. In such cases, one alternative is to scrap the instrument and find a better (and probably more expensive) one. However, you can compare the measurement error with the total tolerance on the part (IMO, not the gage) you are measuring. (Error as % of tolerance) And if this % is low, the instrument may be 'Accepted Conditionally'. An instrument can be conditionally accepted if R&R is between 10% and 30%.
Similarly, you can also compare the bias with tolerance to decide if bias is significant. (This is probably not statistically correct method, may be you should do a control chart with bias study measurements)
-Atul.
Ryan Wilde
Thanks, Atul, that is the kind of straightforward explanation I've needed. Really, it doesn't sound too bad to perform and calculate.
So, from what I can gather, I should revise my statements. Since the MSA seems to be specific to a product, then the tolerance of the product not only needs to be taken into account, but has to be the key factor in decision making as to whether the MSA study has proven or disproven that a measurement system is adequate for a particular function. Therefore, I would have to say that % tolerance of the product should be the last step in the MSA study.
I went at it entirely from the gauge tolerance viewpoint, which was obviously the wrong stance.
Thanks!
Ryan
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Understanding & interpretation of MSA results as per 4th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B MSA for Application Test Results - Supplying liquid raw materials to foam producers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N MSA Calculation - My results do not match those of my customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T MSA 3rd Edition Bias Analysis - p. 86, the new numerical analysis of results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
