MSA Spreadsheet in Spanish - Cohen kappa method (circa 2006)
Marc
Fully vaccinated are you?
----- Original Message -----
To: "Carlos Biarge"
Sent: Tuesday, January 17, 2006 5:01 PM
Subject: Re: Contact Marc Form - Cohen Kappa MSA
> On 1/17/06 10:10 AM, Carlos Biarge wrote:
>> Dear Marc
>> I know your web for 3-4 years and i think is goog becose it's important
>> to can
>> check some documents as your free files.
>> I've made a excel tool to calculate the cohen kappa method of MSA 3
>> Edition.
>> Please, send me your email adrress and i send you it. I'd like this excel
>> tool
>> could be used by everybody that connect with your web
>> BEst Regards
>> Carlos Biarge (from spain)
Dear Marc
As you can see:
The tool is based in a tool of your web for 2 tries/inspector. I've modified
a bit it:
a) Every inspector can make 3 tries in the inspection
b) The tool calculate de kappa
c) The tool compare the kappa with the values of the MSA 3 Edition
d) The password of the sheet is "pepeybruna" if you want to make
corrections. The sheets hava password to avoid carelessness
e) The demo is with the example of the MSA
Best Regards
Carlos Biarge
W
wmeister
Re: MSA Spreadsheet in Spanish - Cohen kappa method
Has anyone converted this file back to English, or have a similar file that uses the 3x3x? format in MSA v3+?
I assume someone must be using an English version since this thread is over 4 years old?
I tried to unprotect the calc sheet but it was not the same "pepeybruna" as the other sheets.
Am I wrong in thinking that this type of analysis is being utilized currently for Attribute Gage R&R?
harry
Are you looking for a worksheet/format?
W
wmeister
Yes, an updated English version template. I would think that others are using this method, is this true?
H Is my MSA Study Spreadsheet okay to AIAG MSA Manual 4th Edition? Using Minitab Software 18
automoto Excel (xlsx) spreadsheet for conducting Type 1 MSA Analysis. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O ANOVA Analysis - Trying to understand MSA analysis- Please review my spreadsheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
J Minitab 14 vs. Excel .xls spreadsheet differences? MSA Manual 3rd Edition Using Minitab Software 4
C Part selection for Faro arm MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA on wire pull & ball shear Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S MSA annual plan Capability, Accuracy and Stability - Processes, Machines, etc. 5
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A MSA samples Preparation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N MSA Frequency related literature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A %AV=0 in the MSA GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M MSA - Dealing with inherent within-part variation in assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Ford Q1 MSA - Virtual Site Visit Hardware Manufacturing and Related Processes 14
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
E MSA Reference Manual 2nd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
W Medical Device - fixture qualification and MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Thermometers and Thermocouple or Transducer's require MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R MSA Studies for chemical analytical instruments in QC Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
Nihls MSA after the device move Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
