MSA Studies on each Equipment, each Measurement System or Family in Control Plan?
V
vanputten
#21
Re: MSA studies: on each Equipment, each Measurement System or Family in Control Plan
Hello Jim:
I think some ideas got lost in the thread.
I agree that MSA and calibration are different things. There was a posting that implied that if tools are under the same maintenance and calibration, then they will behave the same; they will have the same variation in measurement. I am trying to make the point that that is a HUGE assumption about the effectiveness of both calibration and maintenance processes.
Yes I am referring to potential limitation or "problems" within calibration as an input that affects MSA. All I am trying to convey is to think about assumptions made about maintenance and calibration of tools as it might (or might not) have an impact on how one approaches MSA. I am in now way saying anything for certain. I am trying to get people to consider interrelation and interactions of processes. If someone wants a statement of certainty, a statement that there is only one approach, please look to other posters.
I agree that "A GR&R is a study of a measurement system, although it's not the only type of study." But you providing this information still does not tell me what the original poster meant when they used the term "MSA studies."
And finally, after reading all of the postings and the development of this thread, I have another possible conclusion. Qusys may be trying to simply meet the requirements in TS 16949 and not necessarily have an effective MSA process or may not want to understand the variation of the tools listed on the Control Plan. If the goal is to simply meet the requirements of TS and to maintain certification, then do an MSA study on one tool and apply the results to all the tools that can be lumped into that family. If an 3rd party auditor says that is not good enough, then the worst case is that you will get a non-conformance and will have something like 90 days to provide a corrective action.
manasnaik001
#22
Can you exploit me with few examples with files for X-bar R represent?
I did not reproduce if it impoverishment MSA studies for apiece equipment in CP or it is sufficiency
to superior 3-5 equipment in a aggroup of twin equipment for MSA studies.
I was not able to hit this content in AIAG Gamy playscript kin to MSA
_______
manas
manasnaik001
#23
I concord that MSA and standardization are unlike things. There was a notice that implicit that if tools are under the equal mending and activity, then they leave deport the synoptical; they instrument jazz the said angle in activity. I am trying to pretend the punctuation that that is a HUGE theory about the effectuality of both standardization and mend processes.
__________
manas
Stijloor
#24
__________
manas
You lost me....:mg:
Stijloor.
Stijloor
#25
__________
manas
Please translate....:confused:
Stijloor.
LUV-d-4UM
#27
Each equipment described ion the Control Plan.
K
kekoukele
#28
my english is poor,so i first use chinese to replay your question.
1、首先你需要确定运用到产线控制过程中的量具数量,因为MSA的根本目的就是保证生产线上测量出数据的准确可信,如果你用20把,那你这20把必须全部做MSA。
2、在实施MSA之前,你需要制定个MSA 计划,以确定实施测量系统名称、时间、频次、检验员、研究MSA的哪些项目等
3、五性是否都需要研究,这要根据情况来确定,当然分辨力、稳定性是基础,研究偏倚和线性确定数据位置,研究重复性和再现性是为了确定数据的精度, 当然更容易出问题的地方是重复性和再现性。
1、first you should identify the NO of gauge will used on your line, because the purpose of MSA is assure you get the ture date. if you use 20 pieces, you must test all equipments MSA study.
2、before you do the study, you shoule developed a MSA planning, indentifying the item\time\frequency\testor and etc.
3\what you will study about MSA? due to the actual.
good luck!;)
Baheran
#29
How do you interpret the clause 7.6.1?
Should the organization provide MSA studies for each equipment in CP or is it enough for each measurement system?
If there are 20 similar measurement equipment of the same technologies, should the organization provide 20 MSA studies or is it enough to have only one, being these pieces of equipment belong to the same family?
Besides, could the organization select a certain number of samples for this family to do MSA?
:bigwave:
Normally we do MSA on each equipment, in order to define the equipment capability and stability. Is that true?
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Ron Rompen MSA Studies of Instruments in a Paint Shop Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Is conducting of all MSA studies required, even if not required by the customer? IATF 16949 - Automotive Quality Systems Standard 23
B For a measuring instrument, should MSA be done first or the Capability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Best Methods for conducting Shadowgraph MSA Studies Quality Manager and Management Related Issues 2
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How many MSA studies are required and at what interval(s)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Analysis of GRR studies, MSA 4th Ed, Chapter III section B - Rigid Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Dealing with Excessive Within-Part Variation when doing MSA and Cpk studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S What is the Reference Value when we do Attribute MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
S The assessment of ndc figures in MSA studies. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J ANOVA Method for MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S TS 16949 MSA Study Requirements - MSA Studies by Family Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
Ron Rompen MSA to perform Linearity and Stability studies on Variable Gauges with Minitab Ver 15 Using Minitab Software 6
L Is it necessary to carry out all the MSA studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA Studies when not required by a customer Statistical Analysis Tools, Techniques and SPC 6
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
D MSA - Can Regular Calibration Replace Bias, Linearity and Stability Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J What MSA studies do you include in PPAP level 3? APQP and PPAP 2
C What are the minimum required MSA studies for a TS 16949 PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Courier MSA Tools - Excel templates for doing the Linearity & Bias, & Stability Studies Excel .xls Spreadsheet Templates and Tools 13
D Measurement System Analysis (MSA) - Requirement to also do gage stability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
X MSA Studies on a scale that is used in the calculation of Specific Gravity (SG) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Y MSA - Torque Wrenches - Statistical studies that cover requirements of MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
G MSA Studies on heat shock tests - Should we just be calibrating the oven? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B PPK Requirements & MSA Studies for PPAP APQP and PPAP 10
T APQP Control Plans - MSA studies for everything listed on the plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
