MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension
Prashant G
Hello Gentlemen,
Can some one advice how we can read across MSA study.
AS 9100 and and our customer want us to do MSA study for their parts dimension, Is there any chance that we can read across MSA study instead of doing it on dimension basis.
John Predmore
Prashant-
You say your customer wants an MSA study. If you have a recent MSA study on similar parts, and you believe the results "read across" to the new customer's parts, you have to ask the customer whether he accepts the earlier study. It will be necessary to give your customer more details to make that decision, than you provided us here.
Prashant G
HI John,
My question was like see if I have prepared MSA on 10+/-0.20mm dimension and then on other parts dimension is 8.0+/-0.15 mm in this case can i read across first one with second or not?
if yes on what basis and if no then does it mean that i have to MSA for all the dimension mentioned on parts drawings?
Golfman25
I'm not a fan of MSA study overkill. So if you have similar parts checked the same way with the same instrument, then IMO one msa is good for all. Sometimes the customer listens. Sometimes they don't.
The general concept of MSA is to make sure the variation from measurement (people, equipment and technique combined) is much less than the variation of objective/attribute being measured so the measurement is trustful. So even similar dimension of which the variation could spread because of manufacturing process itself or the way it could be measured.
Usually we won't do MSA for all dimension except for those characteristics need special control like SPC or would be used in Design of Experiment.
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O MSA Study for a steel ruler Manufacturing and Related Processes 6
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA Study Requirements for Control Plans FMEA and Control Plans 5
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
C Help with my first MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Meaningful MSA Study on Viscosity Measuring Equipment IATF 16949 - Automotive Quality Systems Standard 14
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Minor NC - No MSA study on Tensile Tester IATF 16949 - Automotive Quality Systems Standard 4
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L How to do an MSA Study on Stopwatches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Is my MSA Study Spreadsheet okay to AIAG MSA Manual 4th Edition? Using Minitab Software 18
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Excel Templates for MSA Study as per 4th Edition Manual Excel .xls Spreadsheet Templates and Tools 11
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
E Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual Capability, Accuracy and Stability - Processes, Machines, etc. 18
J Sampling Method for Stability Study - Implementing MSA Study on Testers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA Study Types - How to make an informed decision about a gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
D Cpk and MSA study for Chemical Production Line Capability, Accuracy and Stability - Processes, Machines, etc. 4
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S TS 16949 MSA Study Requirements - MSA Studies by Family Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
