MSA Study for a Leak Testing Device
N
nikqualityone
Hello dear Forum members,
I would need your help/advice regarding Measurement System Analysis of a leak testing device. I come from automotive industry - assembly process, production of plastic pipelines and systems - SCR lines.
Since I am on beginning of a project, I have a PPAP requirement to perform a capability study of my measurement equipment (in my case control gauge - attributive MSA, but also leak testing device - ATEQ).
According to receipt that I currently have loaded on my ATEQ f 420device, and few tests that I have made, we are testing the parts on pressure of 8.5 bars...
The maximum allowed pressure decay is 2.5 mbars...
Could you help me with following:
-How to prepare the whole study
-Which parts to take (only OK with pressure decay up to 2.5 mbars or also NOK parts
- How many appraisers should be there ?
- Is this MSA study conducted by simply testing the 10 parts and recording the results?
- Is there anything particular that I should take care of when preparing for this?
I should also perform MSA study for Helium leak tester, for same application, according to customer spec. leak should not exceed the value of 1*10^-5 l*mbar/s.
Thank you for your help, any advice would be appreciated!
N
nikqualityone
We are measuring pressure decay.
Part has to be attached to the testing spigot and afterwars start the program for testing.
optomist1
A Sea of Statistics
ok, so this is an operator executed test? The operator reads a dial, meter? How is the test period timed? Manually or by test equipment? These all effect how the MSA is structured and conducted...I can provide an excel template, or there are some available within this site...at attachments search above
N
nikqualityone
Exactly as you descriped, the test is partially performed by an operator (part connection and triggering of the test), the rest is controlled by leak testing device...Filling time, stabilisation time and testing time is device controlled feature, and those parameters are given by testing program , created by an engineer.
At the end the device displays the result on the screen (leakage 1.1 mbars) and gives to the operator green or red signal, depending on the result of the test.
Any excel forms or examples would also be helpful...
N
nikqualityone
Someone who can help on this topic?
Please if you need more information just let me know.
Thank you in advance!
Are you interested in testing the continuous output (mbars) or just the categorical result of pass/fail (green/red)?
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O MSA Study for a steel ruler Manufacturing and Related Processes 6
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA Study Requirements for Control Plans FMEA and Control Plans 5
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
C Help with my first MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Meaningful MSA Study on Viscosity Measuring Equipment IATF 16949 - Automotive Quality Systems Standard 14
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Minor NC - No MSA study on Tensile Tester IATF 16949 - Automotive Quality Systems Standard 4
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L How to do an MSA Study on Stopwatches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Is my MSA Study Spreadsheet okay to AIAG MSA Manual 4th Edition? Using Minitab Software 18
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Excel Templates for MSA Study as per 4th Edition Manual Excel .xls Spreadsheet Templates and Tools 11
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
E Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual Capability, Accuracy and Stability - Processes, Machines, etc. 18
J Sampling Method for Stability Study - Implementing MSA Study on Testers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA Study Types - How to make an informed decision about a gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D Cpk and MSA study for Chemical Production Line Capability, Accuracy and Stability - Processes, Machines, etc. 4
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S TS 16949 MSA Study Requirements - MSA Studies by Family Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
