MSA Study Type 1 not capable. We are at the limit. And manufacturing wants to continue producing.
Hello everyone,
I'm new to this website and have benefited from reviews many times.
I would like to describe a problem I encountered with an MSA Study Type 1.
The Cg / Cgk value of the MSA Study Type 1 is less than 1.33. But the production process must also be continued. Manufacturing engineers came to me with two suggestions.
1-Is it allowed to continue using the measuring process with a tolerance reduction (from 5 mu to 4 mu)?
Or
2-In this proposal, instead of individual measurements (for example 25 individual measurements), two or three measurements are taken each time and their mean value is evaluated as one measured value (for example, 25 measured values are obtained from 3 x 25 measurements).
I rejected the first proposal. Because I know that will increase the risks. On the other hand, instead of reducing the tolerance, I recommended an increase in tolerance.
I am also aware that the second suggestion will decrease the standard deviation and thereby improve the Cg / Cgk value.
Is the second suggestion allowed? And should we repeat MSA Study Type 1 according to the proposed solution (two or three measurements taken each time and their mean value evaluated as a measured value)?
I would be very happy if you can enlighten me.
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove, Serra!
Is the tolerance from the drawing? If so, it should not be changed so as to make the MSA study look better.
Nor should we try to normalize inputs by averaging them. The MSA study's statistics are designed to present information in a way that helps drive decisions to improve the repeatability and/or reproducibility of measuring equipment and systems. Its purpose is not to check a box and get busy with the best numbers that manipulation can buy...
The risk of gaming MSA is to produce failing goods without adequate detection. Failure can get expensive. Production needs to be reminded of that.
Ninja
Looking for Reality
FWIW, it sounds to me like the test method is not (precise/accurate/repeatable/reproducible/reliable)...and that you aren't sure if there is an issue in the manufacturing line or not since you don't have good enough data.
The solution here is in the test method...either what method is used or how it is applied.
How do you design a better test, rather than gaming the data as Jen puts it.
Can you tell us a bit about what you are testing, and how the test is being performed?
Ideally, this would have been sorted out before production start. Since that isn't the case, time seems to be of the essence.
Hello Jen Kirley, hello Ninja,
First, thank you very much for the answers.
I had refused the tolerance reduction anyway.
But I find the answer to suggestion 2 valuable :applause:
At least I clearly understood one point. Measuring a component several times (instead of measuring once) and then evaluating its mean value is a manupilation. Although that looked like a solution in theory, it is not the right way to go in practice. That was a pure length measurement on a measuring device. I think I have to dive into the details. I'll be happy to give you more details later.
Best regards
Ninja
Looking for Reality
Trying to help solve the problem...
How long a length (0.0252mm, 47mm, 22m)?
What tolerance?
How are you currently measuring length (what tool)?
Many of the folks on here have measured all sorts of lengths (and most any other attribute).
I, personally, tend to work in micrometers (um, but I'm in America so they are 'microns')...but have had tight tolerances up to 6x6 inches.
Others work in feet or meters...you'll find good steering here for "don't bother with this tool" or "this worked great for me" here if you want it.
Hello Ninja,
This is a CMM and the tolerance is 1 micron. We measure a length (distance between to points) of 50 mm.
To avoid misunderstandings, I would like to repeat suggestion 2.
Here, the repeat measurement meant the measuring process (measuring a component several times, instead of measuring once, and then evaluating its mean value) during the manufacturing process. Not the MSA Study Type 1.
As far as I understand Jen Kirley correctly, a process should go the way it should.
Playing with the mean or standard deviations is just a manupilation.
Tomorrow i will look at the details with a measuring technician on site.
Excuse me. Maybe I haven't clearly described it.
Best regards
Ninja
Looking for Reality
What make/model of CMM?
I have used the MicroVu Vertex 120 and the OGP Flare... neither would pass an MSA study on 50mm with a 1um tolerance.
...but that was over 5yrs ago, I am not familiar with the current models.
Have you explored other tools, such as a laser micrometer?
Welshwizard
Hi Serra,
Repeating measurements is always good practice for obvious reasons, it can also be time consuming and even expensive. When formally trying to understand the impact of your measurement process on your part feature and spec you will need to compute the estimated standard deviation.
Of course, if it is enough for you to just quote good practice and carry on with production then that is your choice.
It would seem that you don't have much leeway here in terms of a specification width of 0.001 mm, you will need to be sure that all or a large part of that specification is not obscured by measurement variation. I have worked in national standards laboratories with very elaborate machines and tightly controlled environments that would struggle to hold a proportion of that specification.
Instead of the run chart of a type 1 study plot the results in time series on an individual moving range chart and check that the process is consistent. If it is compute the estimated standard deviation by: R bar/1.128 and compare what you get to the width of your spec.
Now, if the answers to the previous questions are good/encouraging you can formally estimate the effect of repeating the measurements on the standard deviation by computing: R bar/(1.128 x sqrt of the number of repeat measurements). If this is good/encouraging then go ahead and formally do the study with the number of repeat measurements you can then test out your point 2.
I have tried to plot a path for you taking into consideration what you have already written, computations can't replace common sense its true but I hope I have addressed that with use of the ImR Chart and the fact you cab use the data you have already gathered. What you actually do is based on your own quality needs and the time you have but I hope if it doesn't help now it may help in the future.
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O MSA Study for a steel ruler Manufacturing and Related Processes 6
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA Study Requirements for Control Plans FMEA and Control Plans 5
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
C Help with my first MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Meaningful MSA Study on Viscosity Measuring Equipment IATF 16949 - Automotive Quality Systems Standard 14
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Minor NC - No MSA study on Tensile Tester IATF 16949 - Automotive Quality Systems Standard 4
L How to do an MSA Study on Stopwatches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Is my MSA Study Spreadsheet okay to AIAG MSA Manual 4th Edition? Using Minitab Software 18
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Excel Templates for MSA Study as per 4th Edition Manual Excel .xls Spreadsheet Templates and Tools 11
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
E Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual Capability, Accuracy and Stability - Processes, Machines, etc. 18
J Sampling Method for Stability Study - Implementing MSA Study on Testers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA Study Types - How to make an informed decision about a gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
