MSA Study Types - How to make an informed decision about a gauge
aproddutoor
#11
Since everyone is talking about Gage R&R, I have a question. I heard that the parts need to represent the entire range of possible parts. So should I manually select the parts by measuring it to make sure it represents the entire range of the process? or should I randomly select parts from the process which is collected over different days and shifts? What is the right approach? Why?
bobdoering
Stop X-bar/R Madness!!
#12
Re: Gage R&R (GR&R) Brain Teaser
Manually select the parts by measuring it to make sure it represents the entire range of the process. It is also handy to have some parts just beyond the process limits.
Why?
Because it tests the ability of the gage to detect correctly the measured value throughout its intended use. The concept is not a process capability study - it is a gage study. Randomness is not the point - difference is (to capture "between" variation) If the samples measured are narrower than the process variation, you will not know for sure that any product that might occur outside those specimen values will be detected correctly. Also, as products reach dimensional limits, there may be physical characteristics that affect the gage or user (e.g. more cantilevered load from a 'larger' part)
Now, you might have to run several shifts or days to collect those samples - or force the process to make them for the study.
Hershal
Metrologist-Auditor
#13
One other point, you mention that the gage is calibrated regularly.
What is the measurement uncertainty of its last calibration for the readings you need? Without that information you do not have sufficient input regarding the error contributed by the gage itself.
#14
What is the purpose of the gage (inspection or process control)?
For inspection, selection of samples is not critical. Many will recommend that you select from the entire range of tolerance or the entire range of measurement. If you calibrate the entire range (thus checking linearity), this is not really necessary, but doe not hurt if you want to do it.
For process control, the variation (StdDev) of the parts must represent the variation (StdDev) of the process. The best way to do this is to randomly select parts collected over different days and shifts. The other method may artificially inflate the variation.
#15
Why?
This is okay for gages used for inspection only. However, this is the wrong approach for gages used for process control. It could inflate the variation and make the gage look better than it truly is.
See my post immediately above.
aproddutoor
#16
Thanks Miner for your reply. Can you provide a reference to support your answer? I'm just asking you because it's not written anywhere. I was confused between the two approaches.
The reason why I asked this question was because I wasn't getting a right answer from the books. The gage is used for process control and by forcing the variation by selecting the parts a good approach? Can we do that? But collecting parts from different days and shifts seems right but it would take you ages to get the right parts.
Suppose you randomly collected parts from different days and shifts and you do your gage R&R for process control, what if your %Tolerance is like more 10% or more than 20%? What would you conclude from such a study? Is the gage capable?
Suppose that for the same process you have forced the variation and have collected the parts which represents the entire range of possible parts and you do your gage R&R and the results look good which is less than 10%. What would you do? Which one should I accept?
How will I have confidence in the Gage?
One more thing
Suppose there is an ISO Audit, will they even accept such a methodology?
bobdoering
#17
Good point. For process control (SPC) the other thing to look at is an ndc (calculated using the control limits rather than the tolerance) >10.
#18
You said that your gage is used for process control (e.g., SPC). The answer is very clear (refer to AIAG's MSA manual). The variation of the parts selected for the study MUST match the variation of the process.
If you are comfortable with doing some basic manual calculations, you can substitute the PV (Part Variation) from the parts used in the MSA study with a more accurate Part Variation obtained from a capability study or from SPC charts.
Since your gage is used for process control, not inspection, the %Tolerance is irrelevant. Only %Total Variation (or ndc) is relevant.
I would have no confidence in the gage unless the part variation matched the actual process variation.
One more thing
If you follow the AIAG MSA manual, ISO will accept it. If you substitute the study PV with PV from a capability study or from SPC charts, this will depend on the auditor. Most reasonable auditors should accept it if you can rationally explain and defend it statistically. However, there is always that one auditor that will not accept any deviations.
aproddutoor
#19
Can you please explain the difference between the PV from parts and PV from Capability study or SPC charts?
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O MSA Study for a steel ruler Manufacturing and Related Processes 6
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA Study Requirements for Control Plans FMEA and Control Plans 5
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
C Help with my first MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Meaningful MSA Study on Viscosity Measuring Equipment IATF 16949 - Automotive Quality Systems Standard 14
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Minor NC - No MSA study on Tensile Tester IATF 16949 - Automotive Quality Systems Standard 4
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L How to do an MSA Study on Stopwatches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Is my MSA Study Spreadsheet okay to AIAG MSA Manual 4th Edition? Using Minitab Software 18
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Excel Templates for MSA Study as per 4th Edition Manual Excel .xls Spreadsheet Templates and Tools 11
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
E Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual Capability, Accuracy and Stability - Processes, Machines, etc. 18
J Sampling Method for Stability Study - Implementing MSA Study on Testers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
D Cpk and MSA study for Chemical Production Line Capability, Accuracy and Stability - Processes, Machines, etc. 4
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S TS 16949 MSA Study Requirements - MSA Studies by Family Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
